SwanStream 64 Posted April 21, 2019 Posted April 21, 2019 (edited) Hey all, New problem for me (meaning it worked fine for a long time, then after recent update...) I'm getting this error in auto sort Failed to move file from /volume1/Sort/Sort_TV/Wentworth.S04E09.1080p.mkv to /volume1/tv_1/Wentworth/Season 4/Wentworth - S04E09.mkv: Access to the path is denied. Problem is it IS doing the 'copy' part of the move, just not getting the verification (guessing) so not doing the delete and throwing the error. The associated bit from log: *** Error Report *** Version: 4.1.0.26 Command line: /volume1/@appstore/EmbyServer/releases/4.1.0.26/EmbyServer.dll -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -ffdetect /var/packages/EmbyServer/target/ffmpeg/bin/ffdetect -restartexitcode 121 Operating system: Unix 3.10.105.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///volume1/@appstore/EmbyServer/3rdparty/netcore/2.2.1/runtime/System.Private.CoreLib.dll Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/4.1.0.26 System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path is denied. ---> System.IO.IOException: Operation not permitted --- End of inner exception stack trace --- at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) at Interop.CheckIo(Int64 result, String path, Boolean isDirectory, Func`2 errorRewriter) at System.IO.FileSystem.CopyFile(String sourceFullPath, String destFullPath, Boolean overwrite) at Emby.AutoOrganize.Core.EpisodeFileOrganizer.PerformFileSorting(TvFileOrganizationOptions options, FileOrganizationResult result) Source: System.IO.FileSystem TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[interop+ErrorInfo,Interop+ErrorInfo]) InnerException: System.IO.IOException: Operation not permitted Source: TargetSite: Edited April 21, 2019 by bikesquid
SwanStream 64 Posted April 22, 2019 Author Posted April 22, 2019 From "my plugins" page looks to be 1.3.8.0.
SwanStream 64 Posted April 22, 2019 Author Posted April 22, 2019 @@Luke - In case it's relevant... Just found that after the last firmware update of my switch the LACP setup was buggered.... so Synology's bonded LAN ports were likely spasming.... If this feels like a likely contributor to the problem above, I can just report back if the problem persists. If it's not likely related, let me know if you need anything else to track it down. Cheers.
SwanStream 64 Posted April 23, 2019 Author Posted April 23, 2019 @@Luke - Nope, that didn't help... I did have to do a restart today due to a notice that AutoOrganize was updated, now on 1.3.9 and getting the same error. The file does in fact copy to the proper location with the proper name, etc. But obviously isn't getting deleted from source location. From auto organize page: Failed to move file from /volume1/Sort/Sort_TV/Wentworth.S04E12.mkv to /volume1/tv_1/Wentworth/Season 4/Wentworth - S04E12.mkv: Access to the path is denied. and the log: 2019-04-23 12:55:17.860 Error App: Failed to move file from /volume1/Sort/Sort_TV/Wentworth.S04E12.mkv to /volume1/tv_1/Wentworth/Season 4/Wentworth - S04E12.mkv: Access to the path is denied. *** Error Report *** Version: 4.1.0.26 Command line: /volume1/@appstore/EmbyServer/releases/4.1.0.26/EmbyServer.dll -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -ffdetect /var/packages/EmbyServer/target/ffmpeg/bin/ffdetect -restartexitcode 121 Operating system: Unix 3.10.105.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///volume1/@appstore/EmbyServer/3rdparty/netcore/2.2.1/runtime/System.Private.CoreLib.dll Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/4.1.0.26 System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path is denied. ---> System.IO.IOException: Operation not permitted --- End of inner exception stack trace --- at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) at Interop.CheckIo(Int64 result, String path, Boolean isDirectory, Func`2 errorRewriter) at System.IO.FileSystem.CopyFile(String sourceFullPath, String destFullPath, Boolean overwrite) at Emby.AutoOrganize.Core.EpisodeFileOrganizer.PerformFileSorting(TvFileOrganizationOptions options, FileOrganizationResult result) Source: System.IO.FileSystem TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[interop+ErrorInfo,Interop+ErrorInfo]) InnerException: System.IO.IOException: Operation not permitted Source: TargetSite:
Luke 42242 Posted April 25, 2019 Posted April 25, 2019 Ok, unfortunately I don't know the answer to this, sorry. What's happening is the error is being thrown by the .net core runtime. The transfer may not have failed, but for some reason it thinks it did and it is erroneously raising an error. I'll try to look through issue reports to see if I can find anything similar to this. Thanks.
SwanStream 64 Posted April 25, 2019 Author Posted April 25, 2019 Thanks dude. appreciate getting info back even if it's not clear what the fix is. To be clear it's not every file, it's not most files, it's now and then... and MAYBE tied to the NAS being busy with other activities, so maybe a time out rather than access denied? just a thought. Let me know if there's something I can help with from this end to track it down. Cheers.
