Pucciano 0 Posted April 21, 2019 Posted April 21, 2019 I have some Streams where is needed to enable autoloop. If i use the m3u Tuner under TV sources, the Stream ends after 10-60 seconds or jump back to the beginning. In the Stream Description is written, that autoloop is needed. If i try the Stream under VLC with loop enabled, the Stream run fine. After a huge time of googeling and reading many russian forms, i find the changelog of 3.2.20.12. But related to this Posting, Autoloop is not able to force enable. If i understand it right, it is now automatic. Now i pleading for support to find out why my Streams quit after few seconds. Lets get started: First things first, the Server: I use the public docker image from here. I Try also installing the .deb file. emby Version: 4.1.0.26 OS: Ubuntu 18.04 LTS Kernel: 4.15.0-47-generic CPU: Intel® Xeon® CPU E31245 @ 3.30GHz Used Playback Apps: FireFox 66.0.3 (64-bit) @ Ubuntu 18.10 Desktop Android App 3.0.45 @ Oxygen OS 9.0.12 with Radioactive Kernel 4.9.162 Android TV App @ 7.0 # docker info Containers: 1 Running: 1 Paused: 0 Stopped: 0 Images: 1 Server Version: 18.09.5 Storage Driver: overlay2 Backing Filesystem: extfs Supports d_type: true Native Overlay Diff: true Logging Driver: json-file Cgroup Driver: cgroupfs Plugins: Volume: local Network: bridge host macvlan null overlay Log: awslogs fluentd gcplogs gelf journald json-file local logentries splunk syslog Swarm: inactive Runtimes: runc Default Runtime: runc Init Binary: docker-init containerd version: REMOVED runc version: REMOVED init version: fec3683 Security Options: apparmor seccomp Profile: default Kernel Version: 4.15.0-47-generic Operating System: Ubuntu 18.04.2 LTS OSType: linux Architecture: x86_64 CPUs: 8 Total Memory: 15.6GiB Name: REMOVED ID: REMOVED Docker Root Dir: /var/lib/docker Debug Mode (client): false Debug Mode (server): false Registry: https://index.docker.io/v1/ Labels: Experimental: false Insecure Registries: 127.0.0.0/8 Live Restore Enabled: false Product License: Community Engine WARNING: No swap limit support docker ps CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES REMOVED emby/embyserver:latest "/init" 3 days ago Up 2 hours 1900/udp, 0.0.0.0:8096->8096/tcp, 7359/udp, 0.0.0.0:8920->8920/tcp laughing_snyder Thanks embyserver.txt ffmpeg-transcode.txt
Luke 42246 Posted April 22, 2019 Posted April 22, 2019 Hi, that's strange. The command line we're using should be basically the same. And you're saying it worked fine in 4.0?
