Recording not working
Hi,
I have sent a log at 08:02 BST from my android TV server. Server name is samboy.
Issue is nothing will record? I click on record and go to recordings and nothing is showing or recording. Why is this?
Another log sent at 09:33 BST. can't get any live channels to play and guide won't refresh. I have no idea why it is doing this. I haven't changed anything and it was working last night. Nothing will play today and I'm annoyed that my scheduled recording didn't record last night.
maegibbons
You need to post your SERVER logs.
What tuner are you using?
Krs
Mark
I sent my logs via the android TV way. I don't use a tuner, I use a nvidia shield. I have recorded in the past like this.
maegibbons
If you are talking about "in app" logs then that is the client app. Not the server.
To record in emby you will have to have defined some sort of tuner within emby server or be using a plugin.
A shield on its own cannot record without some "source" of thevstream.
Krs
Mark
maegibbons
How do you manage your server? Through a browser?
Are you sure you are not using someone elses server?
Krs
Mark
Edited by maegibbons
maegibbons
From your previous posts, it looksvlike you use an m3u tuner?
Krs
Mark
Yes I use m3u tuner. It has recorded in the past but it is no longer. Ok I will have to provide a server log then.
I'm using my own android server on my shield using the apk off emby github.
I think I know what the issue is, subscription must have ran out on the day I bloody needed it lol typical! Just seen that I need to renew again. It was working last night but must have reset at midnight.
