Efontaine 0 Posted April 21, 2019 Posted April 21, 2019 HI, I am new to Emby and i am premiere member. I set up the live TV using the M3u tuner with no issue but whenever I go to a channel, it takes a longtime for me see anything from the channel, and when the channel do come up it only plays for like 5 minutes and then stop. Can someone educate me on why is that happening? PS I had read a couple forms online about this. seen like a lot of people are having the same issue. have any one figure out the cause of that
Luke 42245 Posted April 21, 2019 Posted April 21, 2019 Hi there, can we look at an example? Please attach the information requested in how to report a media playback issue. thanks !
maegibbons 1287 Posted April 21, 2019 Posted April 21, 2019 What happens after the 5 minutes? Have you tried playing the same stream in VLC to see if it is a stream or internet stability issue? Krs Mark
Efontaine 0 Posted April 21, 2019 Author Posted April 21, 2019 Thanks guy's for the response I had took a look at the log's it seen like my server it getting a access denial from the downstream server. question, would the downstream server be my server or the server that is streaming the channel. and i did try the M3u files in VLC is work fine with no issue. i posted the information from the log file below. 2019-04-20 14:41:47.775 Application version: 4.1.0.26 http://192.168.1.63:8096/emby/videos/153516/stream.mkv?DeviceId=3e2cd412bad6e239&MediaSourceId=f746353bebd9602724c2bc6c86060c14&PlaySessionId=9b315d409a4040b0a41f32354e061222&api_key=4f46ba8ce5d1454c8e0103e5fca9edbf&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_f746353bebd9602724c2bc6c86060c14&VideoCodec=h264&AudioCodec=aac,mp3,ac3&VideoBitrate=79808000&AudioBitrate=192000&AudioStreamIndex=-1&CopyTimestamps=true&TranscodeReasons=ContainerNotSupported {"Protocol":"Http","Id":"f746353bebd9602724c2bc6c86060c14","Path":"http://aika.dreamiptv.net:8080/live/QT1XLyk08v/70tOfMt6qG/104106.m3u8","Type":"Default","Container":"hls","Size":2856,"IsRemote":true,"SupportsTranscoding":true,"SupportsDirectStream":false,"SupportsDirectPlay":false,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"LiveStreamId":"06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_f746353bebd9602724c2bc6c86060c14","RequiresLooping":true,"SupportsProbing":false,"MediaStreams":[{"Codec":"h264","TimeBase":"1/90000","CodecTimeBase":"1001/120000","VideoRange":"SDR","DisplayTitle":"720pH264","NalLengthSize":"0","IsInterlaced":false,"BitRate":8000000,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":720,"Width":1280,"AverageFrameRate":59.94006,"RealFrameRate":59.94006,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"aac","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"AAC stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Profile":"LC","Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"Formats":[],"Bitrate":8192000,"RequiredHttpHeaders":{"User-Agent":"VLC/3.0.1"},"ReadAtNativeFramerate":false} User policy for Triple_p1925: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True C:\Users\Administrator\AppData\Roaming\Emby-Server\system\ffmpeg.exe -analyzeduration 3000000 -user_agent "VLC/3.0.1" -f hls -stream_loop -1 -multiple_requests 1 -reconnect_streamed 1 -reconnect_delay_max 2 -i "http://aika.dreamiptv.net:8080/live/QT1XLyk08v/70tOfMt6qG/104106.m3u8"-sn -c:v:0 copy -flags -global_header -fflags +genpts -vsync -1 -map_metadata -1 -map_chapters -1 -threads 1 -codec:a:0 copy -disposition:a:0 default -y "C:\Users\Administrator\AppData\Roaming\Emby-Server\programdata\transcoding-temp\0e7000257599da1161497f4215509d30.mkv" ffmpeg version 4.0.3-emby_2019_04_09-g5abbb1430d+449 Copyright © 2000-2018 the FFmpeg developers and softworkz for Emby LLC built with gcc 8.3.0 (Rev2, Built by MSYS2 project) Local Time: 14:41:47 T=0.000s T=0.031s [http @ 000000c10c470a40] HTTP error 403 Forbidden http://aika.dreamiptv.net:8080/live/QT1XLyk08v/70tOfMt6qG/104106.m3u8:Server returned 403 Forbidden (access denied)
ebr 16337 Posted April 21, 2019 Posted April 21, 2019 Some of these m3u streams have actual time limits in the url. Have you ensured you don't have that?
Efontaine 0 Posted April 21, 2019 Author Posted April 21, 2019 hmmm im not sure. how can i find that out?
Luke 42245 Posted May 5, 2019 Posted May 5, 2019 To answer the earlier question, it would be the server that is streaming the channel that is sending back the access denied response.
