xcesscivic 0 Posted April 20, 2019 Posted April 20, 2019 (edited) Anyone else getting a green screen when playing outsided of their network using emby connect? The sound is working fine but just no video. I've tried on a Fire TV app as well as the Android app on my phone. Appears to only happen during transcoding. Has to be the server update as it was working fine yesterday before I updated my server. Edited April 20, 2019 by xcesscivic
Happy2Play 9806 Posted April 20, 2019 Posted April 20, 2019 You will need to post or pm your server and ffmpeg logs.How to Report a Problem
xcesscivic 0 Posted April 20, 2019 Author Posted April 20, 2019 (edited) I PM'd logs to you Edited April 20, 2019 by xcesscivic
Luke 42217 Posted April 20, 2019 Posted April 20, 2019 Can you please add me to that private message? thanks !
Luke 42217 Posted April 20, 2019 Posted April 20, 2019 Can you install the latest video drivers for your hardware, then reboot your machine and try again? Thanks.
xcesscivic 0 Posted April 22, 2019 Author Posted April 22, 2019 Everything is up to date. Still having the same issue during transcoding. However I've found that if I change the quality settings a couple of times eventually I can get the video to play properly.
