MediaExplorer 2 Posted May 15, 2014 Posted May 15, 2014 I have MBS 3.0.5238.39498 and MediaMonkey 4 installed. MBS can't find MM as a DLNA target but it can play to WMP without any problem. I have used WMP as a source to check whether MM DLNA play to function is ok and it works flawless. Please advise.
Luke 42237 Posted May 15, 2014 Posted May 15, 2014 We haven't heard many reports abuot media monkey, so i doubt many people have tested that. we can take a look at it.
MediaExplorer 2 Posted June 21, 2014 Author Posted June 21, 2014 Apologies for the delay in reply. Here's an update to the issue: I now have the latest MBS Version 3.0.5271.29451. I have also found a workaround to DLNA issues on MediaMonkey website. Both these tweaks seem to have done the trick.
BATTLE DONKEY 98 Posted June 21, 2014 Posted June 21, 2014 Apologies for the delay in reply. Here's an update to the issue: I now have the latest MBS Version 3.0.5271.29451. I have also found a workaround to DLNA issues on MediaMonkey website. Both these tweaks seem to have done the trick. I don't use mediamonkey but can u maybe post these tweaks for other people who might be having issues as well
Luke 42237 Posted June 22, 2014 Posted June 22, 2014 Please retry on the latest dev build and let me know if your workarounds are still needed. (And please indicate what they are as I'm curious) http://mediabrowser.tv/community/index.php?/topic/8103-30528119818/?p=108531 I tested successfully with Media Monkey.
MediaExplorer 2 Posted June 22, 2014 Author Posted June 22, 2014 I followed MM wiki advice and set my DLNA server IP Port to 4000 (not sure if it's allowed to embed link to other forum but here is the link http://www.mediamonkey.com/wiki/index.php/WebHelp:Setting_UPnP/DLNA_Media_Servers/4.0). I'll try the dev build and see what happens. Thanks @@Luke
MediaExplorer 2 Posted August 28, 2014 Author Posted August 28, 2014 Hi, I am now on MBS 3.0.5347.22095. DLNA audio playback on MM is working perfectly with MBS. However, I had to create a custom DLNA profile of MM and tweaked couple of settings to get video playback on MM: 1. Supported Media Types: Audio and Video selected 2. Add direct play profiles: Container - All, Video Codec - All, Audio Codec - All Video playback successful with mp4 and mkv. Hope this helps anyone stumbling across this post. 1
Luke 42237 Posted August 28, 2014 Posted August 28, 2014 Hi, I am now on MBS 3.0.5347.22095. DLNA audio playback on MM is working perfectly with MBS. However, I had to create a custom DLNA profile of MM and tweaked couple of settings to get video playback on MM: 1. Supported Media Types: Audio and Video selected 2. Add direct play profiles: Container - All, Video Codec - All, Audio Codec - All Video playback successful with mp4 and mkv. Hope this helps anyone stumbling across this post. cool i didn't know MM played video
