Kodi_Newcomer 27 Posted April 19, 2019 Posted April 19, 2019 (edited) Hello Com, i have buyed Premiere and will use the inbuild live tv feature, for this i have a m3u list this will work in other players, but here i can see nothing, i can make channel mapping for epg but i cant see channels or epg in live tv section.. Here is the log and an example for the m3u file Log.txt #EXTM3U #EXTINF:-1,RTL DE http://magiptv.123tv.to:8080/xxxxx/xxxxx/81 #EXTINF:-1,RTL FHD DE http://magiptv.123tv.to:8080/xxxxx/xxxxx/4184 #EXTINF:-1,RTL II DE http://magiptv.123tv.to:8080/xxxxxxx/xxxxx/9348 #EXTINF:-1,RTL II HD DE http://magiptv.123tv.to:8080/xxxxxx/xxxxx/79 #EXTINF:-1,RTL II FHD DE http://magiptv.123tv.to:8080/xxxxx/xxxxx/3932 #EXTINF:-1,ProSieben DE http://magiptv.123tv.to:8080/xxxxx/xxxxx/3180 Greet's Edited April 19, 2019 by Kodi_Newcomer 1
Luke 42245 Posted April 19, 2019 Posted April 19, 2019 How did you configure this in Emby, as an m3u file, or url?
Kodi_Newcomer 27 Posted April 19, 2019 Author Posted April 19, 2019 Its an m3u File in this File ist Looks like a Post over you.
Luke 42245 Posted April 19, 2019 Posted April 19, 2019 It's working fine here. Perhaps you didn't wait for the guide refresh process to finish?
Kodi_Newcomer 27 Posted April 20, 2019 Author Posted April 20, 2019 Hm maybe, i will have a look on the Top of the Server Site, how far the process would be. Is it possible to record this live tv content like sat content ?
Luke 42245 Posted April 20, 2019 Posted April 20, 2019 Yes it is possible to record. You can monitor the progress of refreshing the guide on the live tv setup screen as well as the scheduled tasks screen. Please let us know if this helps. Thanks.
Kodi_Newcomer 27 Posted April 21, 2019 Author Posted April 21, 2019 (edited) Yes it is possible to record. You can monitor the progress of refreshing the guide on the live tv setup screen as well as the scheduled tasks screen. Please let us know if this helps. Thanks. Did you mean this progess bar ? He is there some seconds and after this he is gone, without a green bar. So i think its finished. ok it seems to be work now. Is there a folder for channel logos ? Or must i edit every channel on the UI to give him an one channel logo ? So when there was an folder i can put all my logos there with the same name of the channel and emby can use it by itself ? Can i use tvg-id= to give the channels a number for direct call by push this number on the remote ? Edited April 21, 2019 by Kodi_Newcomer
Luke 42245 Posted April 21, 2019 Posted April 21, 2019 Can i use tvg-id= Use tvg-chno for channel number. 1
Kodi_Newcomer 27 Posted April 21, 2019 Author Posted April 21, 2019 Hm it works but very unstable. Some Channels work some not. After testing, channels how worked did not work again.
Luke 42245 Posted April 21, 2019 Posted April 21, 2019 We're happy to help. Please see how to report a problem: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
Kodi_Newcomer 27 Posted June 12, 2019 Author Posted June 12, 2019 Hm, i have installed emby on my Intel Nuc, with Debian. I buy Premiere, load the m3u File and add the epg xmltv for the progam. I pair some channels with the guide data and let complete the import. After this i see nothing on the live tv section. At my other test, there was dvbviewer on the other server, so i think, the channels i have seen, are from this. But here i will try that emby use his one live tv. But i cant get it working. I dont know what im doing wrong. Maybe this is a problem ? #EXTINF:-1 group-title="Free TV HD+ IPTV",ProSieben HD I have export the Channel List from DVBViewer.
Luke 42245 Posted June 12, 2019 Posted June 12, 2019 But i cant get it working Hi, what does this mean? What are you having a problem with?
Kodi_Newcomer 27 Posted June 12, 2019 Author Posted June 12, 2019 (edited) i see no channel, no epg data, nothing. Here is a log, i forgot it. Log (1).txt Did it only works, when he has collect the guide data ? Without, i can't see the channel names ? Edited June 12, 2019 by Kodi_Newcomer
Luke 42245 Posted June 12, 2019 Posted June 12, 2019 Are you sure you entered your premiere key into your server?
Kodi_Newcomer 27 Posted June 13, 2019 Author Posted June 13, 2019 Are you sure you entered your premiere key into your server? Hm i think so.
Luke 42245 Posted June 13, 2019 Posted June 13, 2019 Can you try removing it and then adding it again? Thanks. 1
Kodi_Newcomer 27 Posted June 13, 2019 Author Posted June 13, 2019 Can you try removing it and then adding it again? Thanks. You mean the premiere key ? Or the m3u List ?
Kodi_Newcomer 27 Posted June 13, 2019 Author Posted June 13, 2019 The premiere key. It WORKS !!! Luke i thank you very much. Thx, thx, thx. After delet the key, restart the server and enter it again, he makes guide import and show'S me all the channels and some epg data. You are my men, thanks for the great Support !!
