Riggs 312 Posted April 18, 2019 Posted April 18, 2019 I open this because I am not sure IF it this is a bug, o it is what it is. I have many movies, I NEVER use the Cinema mode. I can live without that. Anyway, the thing is that what I assume that if I do not use this feature, the button that appears next to the play button is enough (1 Trailer), but no, it turns out that in many movies below the actors a row of trailers appears, which many of them It may seem great, but in my case, I do not see trailers inside Emby APP for the simple fact that you open YouTube and the truth does not interest me either. So with the only trailer I'm happy (just in case).Is this a bug? I really have not found a way to disappear that row of trailers.Thanks in advance.
ebr 16313 Posted April 18, 2019 Posted April 18, 2019 Hi. I believe those trailers are sourced from Tmdb. I don't believe there is any way to not retrieve them other than disabling that provider (which you probably don't want to do). 1
Riggs 312 Posted April 19, 2019 Author Posted April 19, 2019 Hi. I believe those trailers are sourced from Tmdb. I don't believe there is any way to not retrieve them other than disabling that provider (which you probably don't want to do). Hi, thanks for let me know, maybe a filter is needed at server side, in the advance settings of the libraries on some part close of around image fetchers or inside it. A special request is needed? Thanks.
