jdpg2 8 Posted May 15, 2014 Posted May 15, 2014 (edited) Trying to configure my WHS2011 to run MB3 Server. I had it running without issue when installed on Win7 and playing on that physical machine, but it would not stream Bluray .iso images to any of my other devices Just installed it to WHS2011 and DVD's will play without issue but Blurays wont play on the server or stream to any other devices (both win 7, win 8.1 and windows phone). The log files show an issue which I have attached. MB3 Server Version 3.0.5238.39498 Windows Server 2011 Anyone have an idea?? MB3S_Log.txt Edited May 15, 2014 by jdpg2
jdpg2 8 Posted May 15, 2014 Author Posted May 15, 2014 All sorted... I purged all of the metadata and then gave FFProbeProvider a chance to run against my entire library and that seems to have sorted it out. One thing I have noticed is if I get a "Failed to Play" message from the Windows 8.1 app, if I change the audio that usually gets it to play. 1
Luke 42178 Posted May 16, 2014 Posted May 16, 2014 nice work. we're doing our best with iso' and folder rips but they're some tricky business.
jdpg2 8 Posted May 16, 2014 Author Posted May 16, 2014 (edited) What gets me is that they were working fine up until recently. Also the error with the mounting (in the attached file) is something new. Edited May 15, 2014 by jdpg2
jdpg2 8 Posted May 16, 2014 Author Posted May 16, 2014 (edited) I also just noticed that there is no media info (other than the file path ) via the dashboard for my bluray.iso files but my dvd.iso files all appear to have everything. I have purged and refreshed my meta data several times but it still doesn't appear to be refreshing my Blu-ray metadata. Edited May 15, 2014 by jdpg2
ebr 16305 Posted May 16, 2014 Posted May 16, 2014 Probing BD ISOs is a bit of a crap shoot but the lack of that information is why we cannot stream them. I highly suggest moving away from the ISO format.
jdpg2 8 Posted May 16, 2014 Author Posted May 16, 2014 Quick question... what starts the probe sweep and where does it store its json files with the media info used to stream? Is it possible to.force a re probe of the media?
