iamspartacus 40 Posted April 16, 2019 Posted April 16, 2019 (edited) I migrated to Emby over a year ago during the whole Plex privacy debacle but wound up switching back due to a few key missing features and the lacking nature of some of the clients. I'm giving it serious consideration again as my full time media server. I'm curious as to if any changes have been made with regard to integrating the commercial removal process or users are still 100% responsible for using their own commercial skip applications and scripts. I exclusively run docker containers so any insight into how that all plays would be welcome. Edited April 16, 2019 by iamspartacus
Luke 42244 Posted April 16, 2019 Posted April 16, 2019 It's something we're interested in for the future. Thanks.
jad3675 26 Posted April 17, 2019 Posted April 17, 2019 comskip is pretty easy to setup - you can use comchap and or comcut to completely automate the commercial removal process. FWIW, Plex uses comskip. John
groenator 13 Posted April 17, 2019 Posted April 17, 2019 I set up another container with a script to remove commercials, yhe container mounts the same emby volume used for recording and when a new recording is available emby will kick in the post-processing script which will remove the commercials. Unfortunately, I haven't had time to fully test the solution, I wont promise anything, but if I do have some time and make this work, I will share the solution here.
iamspartacus 40 Posted April 18, 2019 Author Posted April 18, 2019 comskip is pretty easy to setup - you can use comchap and or comcut to completely automate the commercial removal process. FWIW, Plex uses comskip. John Do you have any resources to this very easy setup of comskip in Linux? I set up another container with a script to remove commercials, yhe container mounts the same emby volume used for recording and when a new recording is available emby will kick in the post-processing script which will remove the commercials. Unfortunately, I haven't had time to fully test the solution, I wont promise anything, but if I do have some time and make this work, I will share the solution here. What container are you using for the commercial removal? I'd love to hear of your results.
jad3675 26 Posted April 18, 2019 Posted April 18, 2019 (edited) Do you have any resources to this very easy setup of comskip in Linux? You can follow the instructions on the github to build comskip for your system - https://github.com/erikkaashoek/Comskip - it'll throw some errors (which are superficial), but you'll get a compiled binary 'comskip' in the build directory. Copy it to /usr/local/bin. You'll need to find a comskip.ini that works for your environment. Next, you'll need to grab comchap/comcut from here - https://github.com/BrettSheleski/comchap - it's a shell script, essentially. Comcut does just that - it uses comskip to produce a file that has the commercials removed. Depending on your comskip.ini you may get great results. Comchap doesn't cut the commercials, it marks them as chapters and labels them as 'commercials' so you can select past them from the emby player. You can call the entire thing with a simple shell script from the 'post-processing' field in emby. You'll need to convert the recording from a .ts file to format that supports chapters first. I use ffmpeg to do that. Here's what the guts of my post-processing script look like. This is for an intel GPU - nvidia and AMD would have different options in ffmpeg. I also mark the commercials as chapters and don't remove them. #!/bin/bash MKV_NAME=$(echo ${FULL_PATH%%.??})".mkv" ffmpeg -hwaccel vaapi -vaapi_device /dev/dri/renderD128 -i "$FULL_PATH" -vf 'format=nv12,hwupload' -c:v h264_vaapi -c:a aac "$MKV_NAME" -async 1 -vsync 1 -max_muxing_queue_size 9999 2> /tmp/ffmpeg.log # Checks to make sure the conversion produced a real file, and removes the .ts file if it has. if [ -s "$MKV_NAME" ] then echo 'Removing old video file' $FULL_PATH rm -f "$FULL_PATH" comchap --lockfile=/tmp/comcut.lock --comskip-ini=/path/to/comskip.ini "$MKV_NAME" else echo 'MKV conversion appears to have failed! Removing Empty file.' rm -f "$MKV_NAME" VIDEO_NAME=$FULL_PATH fi John Edited April 18, 2019 by jad3675
groenator 13 Posted April 18, 2019 Posted April 18, 2019 Do you have any resources to this very easy setup of comskip in Linux? What container are you using for the commercial removal? I'd love to hear of your results. A simple ubuntu container with a shell script that will remove the commercials. The shell script is taken from this forum, if you would like I can share the content of the docker-compose and shell script.
iamspartacus 40 Posted April 18, 2019 Author Posted April 18, 2019 A simple ubuntu container with a shell script that will remove the commercials. The shell script is taken from this forum, if you would like I can share the content of the docker-compose and shell script. That would be much appreciated!
SkyBehind 23 Posted April 19, 2019 Posted April 19, 2019 A simple ubuntu container with a shell script that will remove the commercials. The shell script is taken from this forum, if you would like I can share the content of the docker-compose and shell script. +1
ap90033 0 Posted March 1, 2020 Posted March 1, 2020 very interested in this. I have both plex and emby prem. lifetime. I am using plex but interested in moving to emby. Not willing to give up easy commercial skip. I am moving from a win box to unraid so I already know plex would be easy and has it built in. I feel like emby has improved over the years and might be better except for removing commercials.
