Errno 104 Connection reset by peer Embycon 1.9.3
killride
Hello,
I'm not able to see something using embycon 1.9.3 on kodi 18.1
When I try to start a movie, I've the Errno 104 error.
Emby serveur is in 4.0.2.0 and I have this error in the server.log
Any idea?
Thanks
2019-04-15 09:34:14.194 Error SessionManager: Error in event handler
*** Error Report ***
Version: 4.0.2.0
Command line: C:\Users\Administrateur\Desktop\EmbyV2\system\EmbyServer.dll -noautorunwebapp
Operating system: Microsoft Windows NT 6.2.9200.0
64-Bit OS: True
64-Bit Process: True
User Interactive: True
Processor count: 4
Program data path: C:\Users\Administrateur\Desktop\EmbyV2\programdata
Application directory: C:\Users\Administrateur\Desktop\EmbyV2\system
System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object.
   at playback_reporting.EventMonitorEntryPoint._sessionManager_PlaybackProgress(Object sender, PlaybackProgressEventArgs e)
   at MediaBrowser.Common.Events.EventHelper.FireEventIfNotNull[T](EventHandler`1 handler, Object sender, T args, ILogger logger)
Source: playback_reporting
TargetSite: Void _sessionManager_PlaybackProgress(System.Object, MediaBrowser.Controller.Library.PlaybackProgressEventArgs)
Try removing the playback reporting plugin.
Guest
