jonomite 29 Posted April 15, 2019 Posted April 15, 2019 I have been trying to troubleshoot some movies that stubbornly would not appear in their boxsets. I poked around the data/collections folder and discovered quite a few boxsets that are not displaying at all (despite deleting all collections and reinstalling the plugin). I subsequently found some threads that have left me wondering whether I have a corrupt library.db file. I'm tempted to delete it but am wondering what will need to be restored when I do that. Will it simply be a matter of restarting emby and running a library scan? Or will I need to configure other settings as well? Sent from my Nexus 5X using Tapatalk
Solution Luke 42217 Posted April 15, 2019 Solution Posted April 15, 2019 Yes it is that simple, but that database also holds user watch data. 1
jonomite 29 Posted April 15, 2019 Author Posted April 15, 2019 Thanks @@Luke. Should I also delete library.db-shm and -wal? Or just .db? Sent from my Nexus 5X using Tapatalk
Luke 42217 Posted April 15, 2019 Posted April 15, 2019 Shutdown the server and then those files should go away. 1
