Nisten 15 Posted May 3, 2019 Posted May 3, 2019 (edited) To answer the OP's question, No. There are 3 rokus in my house. A roku 2 (hardwired with auto bitrate), a roku TV (2.4 ghz wifi with custom bitrate), and a roku streaming stick (2.4 ghz wifi with custom bitrate). All rokus navigate and operate smoothly quite frequently unless there's a occasional network issue or ffmpeg issue However the roku 2 with the hardwired connection rarely encounters any issue since it either direct plays or direct streams the media i have Edited May 3, 2019 by Nisten
Jason'sEmby 29 Posted May 26, 2019 Posted May 26, 2019 Not sure if this is already been answered. But my Hisense Roku TV does the same thing. It's not just emby, it's also Plex that does it and other applications. Not sure what causes it because Netflix and Amazon work perfectly fine. Almost seems like the remote won't even register to the infrared. Hard resetting the TV does not work. Solution I put another Roku Premier on the Roku TV, problem fixed. Don't think it has anything to do with Emby:)
Luke 42242 Posted May 27, 2019 Posted May 27, 2019 Not sure if this is already been answered. But my Hisense Roku TV does the same thing. It's not just emby, it's also Plex that does it and other applications. Not sure what causes it because Netflix and Amazon work perfectly fine. Almost seems like the remote won't even register to the infrared. Hard resetting the TV does not work. Solution I put another Roku Premier on the Roku TV, problem fixed. Don't think it has anything to do with Emby:) Interesting, thanks for the info !
Phuein 0 Posted May 27, 2019 Author Posted May 27, 2019 (edited) Not sure if this is already been answered. But my Hisense Roku TV does the same thing. It's not just emby, it's also Plex that does it and other applications. Not sure what causes it because Netflix and Amazon work perfectly fine. Almost seems like the remote won't even register to the infrared. Hard resetting the TV does not work. Solution I put another Roku Premier on the Roku TV, problem fixed. Don't think it has anything to do with Emby:) Hey, can you share your specific TV model? Be best to avoid that one. Edited May 27, 2019 by Phuein
Jason'sEmby 29 Posted May 27, 2019 Posted May 27, 2019 It's a Hisense 50 in Roku TV. When I get a chance I'll get you a model number. It seems like it doesn't do it when the TV when connected on a local network but when it's doing remote access it interferes with a couple apps.
Jason'sEmby 29 Posted May 29, 2019 Posted May 29, 2019 Hey, can you share your specific TV model? Be best to avoid that one. See picture 1
