shdwkeeper 15 Posted July 30, 2021 Posted July 30, 2021 20 minutes ago, cayars said: Hi, Yes time shifting is supported on the Shield TV. Is it supported using the emby for android app instead of emby for shield?
shdwkeeper 15 Posted July 30, 2021 Posted July 30, 2021 For some reason using emby for android on the Shield it's only direct playing, how do I turn on live Seek mode?
Carlo 4561 Posted July 30, 2021 Posted July 30, 2021 You're right. Just playing a bit with this it seems it only allows pause/play but no rewind/FF. @Luke 1
shdwkeeper 15 Posted July 30, 2021 Posted July 30, 2021 24 minutes ago, cayars said: You're right. Just playing a bit with this it seems it only allows pause/play but no rewind/FF. @Luke Yup 1
shdwkeeper 15 Posted August 9, 2021 Posted August 9, 2021 On 7/30/2021 at 1:42 PM, cayars said: You're right. Just playing a bit with this it seems it only allows pause/play but no rewind/FF. @Luke Any idea?
Carlo 4561 Posted August 9, 2021 Posted August 9, 2021 Not at this time. The software needs to expand it's handling of this.
Luke 42246 Posted August 9, 2021 Posted August 9, 2021 Yes we will be adding that feature. Thanks for the feedback. 1
shdwkeeper 15 Posted September 5, 2021 Posted September 5, 2021 Emby for Android on the Shield, is there any way to display the Channel numbers when in Landscape mode? If I install Emby for Android and than open this app on my TV the channel numbers are hidden also the guide needs to be modified as it only shows 5 channels on my. Lots of wasted space, maybe take a look at Tivimates guide for some ideas on how to take advantage of the screen space.
Luke 42246 Posted September 6, 2021 Posted September 6, 2021 5 hours ago, shdwkeeper said: Emby for Android on the Shield, is there any way to display the Channel numbers when in Landscape mode? If I install Emby for Android and than open this app on my TV the channel numbers are hidden also the guide needs to be modified as it only shows 5 channels on my. Lots of wasted space, maybe take a look at Tivimates guide for some ideas on how to take advantage of the screen space. Hi, we'll look at working them in. Thanks.
