Carlo 4561 Posted April 14, 2019 Posted April 14, 2019 (edited) Yea, I don't find the "Emby Guide" to be useful or Practical at all. I want the Channels Numbered the way I like, not Numbered so they Match the Gracenote Guides.....Not sure why this was thought to be a good idea, It makes sense if you are using OTA or Cable because you know the channel numbers upfront. M3U files are a game changer. Nothing wrong with having auto matching on channel number if it's an OPTION that can be turned off for M3U files. I have ~500 channels in XTeVe/Emby and the guide refresh takes around 4 minutes. Lucky SOB. I've got to many EPG sources. 7 at present but really need to add 2 or 3 more EPGs to get the channels covered I've got. I'm sure that's the biggest source of my issue. # of channels (OTA, Cable + M3U fileS) plus the different EPGs. That's a lot of data to process. Couldn't imagine how long it would take without SSDs or if it wasn't an i7. Edited April 14, 2019 by cayars 1
EODCrafter 181 Posted April 14, 2019 Author Posted April 14, 2019 (edited) I'll give you Mates a Morning Laugh..... Good 'ole Spinning RPM Hard Drive...it is 1TB though Edited April 14, 2019 by EODCrafter 1
Carlo 4561 Posted April 14, 2019 Posted April 14, 2019 That's not that bad processor wise. Could use a bit more storage however.
EODCrafter 181 Posted April 14, 2019 Author Posted April 14, 2019 That's not that bad processor wise. Could use a bit more storage however. I don't Download anything and I got a Unlimited GDrive
EODCrafter 181 Posted April 15, 2019 Author Posted April 15, 2019 Seems to be a Bug in Getting this to Work Properly..... @@marmei is looking into it!
EODCrafter 181 Posted April 15, 2019 Author Posted April 15, 2019 Figured this out.....Since My Original m3u that I load in xTeVe already had these channels, I had to add a Unique Group Title to these channels so I could Parse them separately.....otherwise xTeVe will get confused and deactivate some at Random....Let me know if you need help with this.....
