tuvx 15 Posted April 13, 2019 Posted April 13, 2019 (edited) I have noticed an issue when playing back a few movies using the Fire TV app where I get static for audio. Playing on a PC via the Emby web interface or on the Fire TV with Kodi has no issues. Any ideas whats wrong? Edited April 13, 2019 by tuvx
Luke 42246 Posted April 13, 2019 Posted April 13, 2019 HI there, can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
tuvx 15 Posted April 13, 2019 Author Posted April 13, 2019 (edited) I did, the log was attached. There was no other log. embyserver.txt Edited April 13, 2019 by tuvx
Luke 42246 Posted April 13, 2019 Posted April 13, 2019 Please also supply a copy of the media info from the bottom of the web app detail screen. Thanks.
tuvx 15 Posted April 13, 2019 Author Posted April 13, 2019 (edited) Media Info Video Title1080p H264 CodecH264 AVCYes ProfileHigh Level41 Resolution1920x1080 Aspect ratio16:9 AnamorphicNo InterlacedNo Framerate23.976 Bitrate29,711 kbps Bit depth8 bit Pixel formatyuv420p Ref frames1 NAL4 Audio TitleEng PCM_S24LE 5.1 Default Languageeng CodecPCM_S24LE Layout5.1 Channels6 ch Bitrate6,912 kbps Sample rate48,000 Hz Bit depth24 bit DefaultYes Audio TitleEng Dolby Digital 5.1 Languageeng CodecAC3 Layout5.1 Channels6 ch Bitrate640 kbps Sample rate48,000 Hz DefaultNo Subtitle TitleEng Languageeng CodecPGSSUB DefaultNo ForcedNo ExternalNo Containermkv Path\\AUX-Data\Movies 2\Pirates of the Carribean - At Worlds End\Pirates of the Carribean - At Worlds End.mkv Size35808 MB Edited April 13, 2019 by tuvx
ebr 16338 Posted April 13, 2019 Posted April 13, 2019 So is that 24bit AAC...? I know anything higher than 16bit FLAC is a problem. This must be the same thing.
tuvx 15 Posted April 13, 2019 Author Posted April 13, 2019 When you say it is a problem, I am going to assume it is with the Emby app, as the same file plays fine using Kodi on the FIre TV. Is a plan to fix the issue in the works (I have a number of videos that use this codex at 24-bit)?
ebr 16338 Posted April 13, 2019 Posted April 13, 2019 Hi. Yes we'll have to look at how the app handles it. More than likely, this audio will need to be transcoded.
tuvx 15 Posted April 13, 2019 Author Posted April 13, 2019 Thank you. Out of curiosity, does the emby for kodi addon use emby for transcoding, or is that just for library organizing?
ebr 16338 Posted April 14, 2019 Posted April 14, 2019 Kodi handles most playback without the server transcoding (Kodi transcodes internally).
