Superfast ff speed
Ever since the last update, I've found that the ff or rwd is superspeed, makes it very hard to go back 10 seconds to catch what we missed.  Is there a way to change this setting, either on the ATV app, or on the server?
Also, is there a way to have it default to the way Kodi worked, on Kodi, I had a skip button, multiple presses advanced incrementally (5s, 15s, 60s, per press), and the same with the ffwd, press it once, 2x, 4x, 8x, 16x, etc, per press.
I'm using a Harmony One remote, so lots of buttons to configure for skip and scan fwd and rwd.
I'll have to take a look.
