psuhammer 0 Posted April 12, 2019 Posted April 12, 2019 (edited) I recently bought a one month license for Emby to kick the tires on it as I am having issues with Plex on an Nvidia Shield when trying to play back UHD HDR content consistently. Of course I am having issues with Emby, too. My problem is that some of my UHD Blu Ray MKV files will play fine and HDR is recognized and properly displayed, other movies appear washed out and will NOT play properly with Emby. Here are two that will not and one that does. Can someone tell me if they see a reason why they would not? Aquaman - washed out HDR and app doesn't recognize the file typeSaving Private Ryan - washed out HDR and app doesn't recognize the file typeInfinity War - plays ok except for all green blockiness part way through the film. This also happens in Plex which means it must be an Nvidia Shield issue. The Plex app DOES properly play them, if it matters. EDIT - I wonder if it has to do with subtitles? I noticed that Infinity War does not have them but the others do. Is that throwing the Emby client for a loop? PrivateRyan.txt Infinity War.txt aquaman.txt Edited April 12, 2019 by psuhammer
Guest asrequested Posted April 12, 2019 Posted April 12, 2019 https://emby.media/community/index.php?/topic/60362-shield-atv-hdr/ https://github.com/google/ExoPlayer/issues/5096
psuhammer 0 Posted April 12, 2019 Author Posted April 12, 2019 (edited) Thanks! But my files are not cropped or transcoded, just taking a mux of the original 2160p film. Edited April 12, 2019 by psuhammer
Guest asrequested Posted April 12, 2019 Posted April 12, 2019 (edited) Can you post a screenshot of the media info? Edited April 12, 2019 by Doofus
psuhammer 0 Posted April 12, 2019 Author Posted April 12, 2019 (edited) I am assuming you want to see this? Here is one pic from a UHD mkv movie that is recognized and one that is not in the Emby client. Keep in mind that both are taken from a Blu Ray disk and just remuxed to an MKV. No transcoding. And both handled via the same app (CloneBD). Also, both play fine in Plex. and the other that does not: Edited April 12, 2019 by psuhammer
Guest asrequested Posted April 12, 2019 Posted April 12, 2019 If you scroll down, you should see the file details.
psuhammer 0 Posted April 12, 2019 Author Posted April 12, 2019 Maybe mine is missing something. Are you saying to scroll down on the screens I posted above? If I do, there is only chapter, cast and related movies sections.
Luke 42213 Posted April 12, 2019 Posted April 12, 2019 Can you open that one in the web app, click the 3-dot menu and refresh the metadata? Then restart the android tv app and see if anything changes. If not, please attach the emby server log. thanks !
Happy2Play 9802 Posted April 12, 2019 Posted April 12, 2019 (edited) The Aquaman screenshot shows Video <Unknown> and no audio track, so it would appear to be a metadata media info issue to me. Maybe failed ffprobe? Edited April 12, 2019 by Happy2Play
Guest asrequested Posted April 12, 2019 Posted April 12, 2019 The Aquaman screenshot shows Video <Unknown> and no audio track, so it would appear to be a metadata issue to me. Maybe failed ffprobe? I was thinking something similar.
psuhammer 0 Posted April 13, 2019 Author Posted April 13, 2019 (edited) The Aquaman screenshot shows Video <Unknown> and no audio track, so it would appear to be a metadata media info issue to me. Maybe failed ffprobe? I am assuming Plex uses something different than FFmpeg as it can see the metadata for the file properly. Is there a way to resolve this? Can you open that one in the web app, click the 3-dot menu and refresh the metadata? Then restart the android tv app and see if anything changes. If not, please attach the emby server log. thanks ! No bueno. Here is the log. For what it is worth, the web client also doesn't recognize the file video or audio. EmbyServerLog.txt Edited April 13, 2019 by psuhammer
Happy2Play 9802 Posted April 13, 2019 Posted April 13, 2019 The log shows ffprobe erroring on the file, so I can only assume there is a issue in the header information of the file. A dev will have to comment further. 2019-04-12 20:55:52.274 Error App: Error in ffprobe *** Error Report *** Version: 4.0.3.0 Command line: C:\Users\robcr\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 12 Program data path: C:\Users\robcr\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\robcr\AppData\Roaming\Emby-Server\system System.Exception: System.Exception: ffprobe failed for file:"G:\Movies\Aquaman 4k.mkv" - streams and format are both null: { ffprobe version 4.0.2-emby_2018_12_09-g5abbb1430d+238 Copyright (c) 2007-2018 the FFmpeg developers built with gcc 8.2.1 (Rev1, Built by MSYS2 project) 20181207 configuration: --disable-autodetect --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --enable-sdl2 --disable-debug --enable-ffnvcodec --enable-nvdec --enable-gmp --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwavpack --enable-libwebp --enable-libxml2 --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libaom --enable-version3 --enable-libzvbi --enable-gnutls --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++ --extra-cflags=-DLIBXML_STATIC --extra-libs=-liconv libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100 The tags at index 6 refer to a non-existent track 7. [dvdsub @ 000001c8837b2000] [IMGUTILS @ 0000002b555ff2d0] Picture size 0x0 is invalid [matroska,webm @ 000001c88379e880] Failed to open codec in avformat_find_stream_info Input #0, matroska,webm, from 'file:G:\Movies\Aquaman 4k.mkv': Metadata: title : Main feature #3 ENCODER : Lavf57.3.100 Duration: 02:23:19.39, start: 0.000000, bitrate: 59560 kb/s Chapter #0:0: start 0.000000, end 668.292622 Metadata: title : chapter 1 Chapter #0:1: start 668.292622, end 1330.620956 Metadata: title : chapter 2 Chapter #0:2: start 1330.620956, end 1810.016533 Metadata: title : chapter 3 Chapter #0:3: start 1810.016533, end 2427.716956 Metadata: title : chapter 4 Chapter #0:4: start 2427.716956, end 3023.645622 Metadata: title : chapter 5 Chapter #0:5: start 3023.645622, end 3674.754400 Metadata: title : chapter 6 Chapter #0:6: start 3674.754400, end 4136.090289 Metadata: title : chapter 7 Chapter #0:7: start 4136.090289, end 4900.270356 Metadata: title : chapter 8 Chapter #0:8: start 4900.270356, end 5689.433733 Metadata: title : chapter 9 Chapter #0:9: start 5689.433733, end 5976.428778 Metadata: title : chapter 10 Chapter #0:10: start 5976.428778, end 6571.815244 Metadata: title : chapter 11 Chapter #0:11: start 6571.815244, end 7295.538244 Metadata: title : chapter 12 Chapter #0:12: start 7295.538244, end 7818.894400 Metadata: title : chapter 13 Chapter #0:13: start 7818.894400, end 8599.132200 Metadata: title : chapter 14 Chapter #0:14: start 8599.132200, end 8599.392000 Metadata: title : chapter 15 Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc (default) Stream #0:1(eng): Audio: truehd, 48000 Hz, 7.1, s32 (24 bit) (default) Metadata: title : English Stream #0:2(eng): Audio: dts (DTS-HD MA), 48000 Hz, 5.1(side), s16p Metadata: title : English Stream #0:3(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s Metadata: title : English Stream #0:4(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s Metadata: title : English Stream #0:5(eng): Subtitle: dvd_subtitle Metadata: title : English [dvdsub @ 000001c883c97240] [IMGUTILS @ 0000002b555ff5e0] Picture size 0x0 is invalid Could not open codec for input stream 5 at Emby.Server.MediaEncoding.Encoder.MediaEncoder.GetMediaInfoInternal(String inputPath, String primaryPath, MediaProtocol protocol, Boolean extractChapters, String probeSizeArgument, Boolean isAudio, Boolean forceEnableLogging, CancellationToken cancellationToken) at MediaBrowser.Providers.MediaInfo.FFProbeVideoInfo.ProbeVideo[T](T item, MetadataRefreshOptions options, LibraryOptions libraryOptions, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.RunCustomProvider(ICustomMetadataProvider`1 provider, TItemType item, String logName, MetadataRefreshOptions options, RefreshResult refreshResult, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() at Emby.Server.MediaEncoding.Encoder.MediaEncoder.GetMediaInfoInternal(String inputPath, String primaryPath, MediaProtocol protocol, Boolean extractChapters, String probeSizeArgument, Boolean isAudio, Boolean forceEnableLogging, CancellationToken cancellationToken) at MediaBrowser.Providers.MediaInfo.FFProbeVideoInfo.ProbeVideo[T](T item, MetadataRefreshOptions options, LibraryOptions libraryOptions, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.RunCustomProvider(ICustomMetadataProvider`1 provider, TItemType item, String logName, MetadataRefreshOptions options, RefreshResult refreshResult, CancellationToken cancellationToken)
psuhammer 0 Posted April 13, 2019 Author Posted April 13, 2019 Interesting. And yet, MediaInfo is able to see the information without error.
Guest asrequested Posted April 13, 2019 Posted April 13, 2019 It's probably a bad mux. But back to the original issue. If the file is directly played, whatever is playing it shouldn't be subject to the server metadata. It's handled by the player. But.... because of a bad mux, that may actually be why it doesn't play correctly. Try running it through mkvtoolnix. And try another scan.
psuhammer 0 Posted April 13, 2019 Author Posted April 13, 2019 Will do. I am still perplexed why this will play correctly in different players.
Guest asrequested Posted April 13, 2019 Posted April 13, 2019 Will do. I am still perplexed why this will play correctly in different players. That's the thing with weird muxes, some players will be ok, others won't. I've come across so many files made with makemkv that are weird muxes, who knows why????
Luke 42213 Posted April 13, 2019 Posted April 13, 2019 Strange. We're about to release emby server 4.1. can you try this again once available? Thanks.
psuhammer 0 Posted April 13, 2019 Author Posted April 13, 2019 Strange. We're about to release emby server 4.1. can you try this again once available? Thanks. Sure will, thanks!
spants 0 Posted July 24, 2019 Posted July 24, 2019 Still has a problem with 4.1.1.0 I think it is specifically a problem with the parsing of 4k HEVC (Main 10 HDR) films - they all fail but play ok on Plex. Attached are clips of plex and emby - the latter shows no video info.
Luke 42213 Posted July 24, 2019 Posted July 24, 2019 Still has a problem with 4.1.1.0 I think it is specifically a problem with the parsing of 4k HEVC (Main 10 HDR) films - they all fail but play ok on Plex. Attached are clips of plex and emby - the latter shows no video info. Hi there @@spants, please attach the information requested in how to report a media playback issue. thanks !
paralepepipedo 1 Posted May 9, 2020 Posted May 9, 2020 hello could you solve the problem, same thing happens with some files with x265 codec, Bsplayer does not play them, but VLC does. the film is not show them on android tv, or on the webpage, but even on the mobile app it even plays. attached images and in the android cellphone It occurred to me to change the name of the folder because I thought it was very long and believe it or not it was the solution. the old path the new path
Luke 42213 Posted May 10, 2020 Posted May 10, 2020 hello could you solve the problem, same thing happens with some files with x265 codec, Bsplayer does not play them, but VLC does. the film is not show them on android tv, or on the webpage, but even on the mobile app it even plays. attached images and in the android cellphone It occurred to me to change the name of the folder because I thought it was very long and believe it or not it was the solution. the old path the new path Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks !
