nyplayer 90 Posted April 11, 2019 Posted April 11, 2019 Why does emby not recognize these as TVShows ??? It should be able to ? \TVShows\Law & Order (1990) - S09E10 - Hate -6279852-0.ts \TVShows\The Unit (2006) - S01E01 - First Responders -6276314-0.ts
Happy2Play 9806 Posted April 11, 2019 Posted April 11, 2019 Why does emby not recognize these as TVShows ??? It should be able to ? \TVShows\Law & Order (1990) - S09E10 - Hate -6279852-0.ts \TVShows\The Unit (2006) - S01E01 - First Responders -6276314-0.ts Emby requires a Series folder. At some point they would like to support this no structure loose episodes structure.
nyplayer 90 Posted April 11, 2019 Author Posted April 11, 2019 (edited) Emby requires a Series folder. At some point they would like to support this no structure loose episodes structure. Too bad that is the way Sage records … back to Plex. I was hoping to be able play Sage Recordings in EMBY.... so for now will use Plex. Edited April 11, 2019 by nyplayer
Deathsquirrel 745 Posted April 11, 2019 Posted April 11, 2019 Too bad that is the way Sage records … back to Plex. I was hoping to be able play Sage Recordings in EMBY.... so for now will use Plex. You can play them but you'll need to setup a tool to move them into separate series for each folder automatically first.
nyplayer 90 Posted April 11, 2019 Author Posted April 11, 2019 (edited) You can play them but you'll need to setup a tool to move them into separate series for each folder automatically first. I do not want to do that because then SageTV will no recognize them.... I am happy for now using Plex. SageTV is the only DVR that will let me record all New Shows that are airing now and the future on OTA HD Broadcast channels during Prime Time without knowing the titles..... So I needed a way to view these remotely... as I will be away from home for a bit. Edited April 11, 2019 by nyplayer
