Bearbearbear 0 Posted April 11, 2019 Posted April 11, 2019 Windows 10 Installation that used to connect remotely without problem. Not sure what has changed but often I am unable to connect remotely and need new ideas for determining the issue. Emby Connect will sometimes not show my server and will ask me to add it manually (theres another button below asking me to sign in to emby connect even though I already am signed in. I don't know if this is a UI thing or it genuinely doesn't think I've signed in) -I can see another server I have access to on this screen so I have to be signed in, correct? I originally did not use my Dynamic DNS because everything worked flawlessly with Emby Connect. I could no longer connect remotely so I changed setting to connect the DDNS and things now at least work intermittently. Port is open on my router. Port is open in windows firewall Port shows accessible on CanYouSeeMe.org Can connect In-home without issue. Restarted computer - no effect. Installed stable release over beta - no effect Restarted modem and router - no effect Emby server is installed on a PC that never sleeps. Log files are very long so its hard to gain any insight. Ideas?
Luke 42221 Posted April 12, 2019 Posted April 12, 2019 Hi there, sorry to hear about this, although if you have a ddns, why use emby connect?
Bearbearbear 0 Posted April 12, 2019 Author Posted April 12, 2019 I never utilized the ddns until I started having issues. Do you have any ideas why the connection is not working consistently?
Luke 42221 Posted April 17, 2019 Posted April 17, 2019 @@Bearbearbear are you still having an issue with this?
Bearbearbear 0 Posted April 19, 2019 Author Posted April 19, 2019 @@Bearbearbear are you still having an issue with this? Thanks for the reply. I can report that I haven't had an incident of being unable to connect in the last couple of days. I think we can be satisfied its "fixed" if we can get through a week without issues. I'll report back.
Bearbearbear 0 Posted June 18, 2019 Author Posted June 18, 2019 I'm still having issues with this. It's driving me nuts. Do you have any other guidance?
Luke 42221 Posted June 19, 2019 Posted June 19, 2019 What is the root problem, that your remote IP is constantly changing?
Bearbearbear 0 Posted June 19, 2019 Author Posted June 19, 2019 What is the root problem, that your remote IP is constantly changing? The root problem is the intermittent remote connectivity; I don't think my remote IP changes more than any body elses. This problem still happens when I have the ddns setup so i'm not sure thats what would be the root issue.
Luke 42221 Posted June 20, 2019 Posted June 20, 2019 I would suggest checking out our Connection Troubleshooter: https://github.com/MediaBrowser/Wiki/wiki/Connectivity Please try the steps listed there and let us know which ones succeed and which ones do not. Thanks !
notla49285 48 Posted June 20, 2019 Posted June 20, 2019 If your IP does change, do you have any kind of service that's updating your DNS provider with the new IP?
