MisterAngelus 7 Posted April 11, 2019 Posted April 11, 2019 Is it possible to pause a conversion while in progress?.. as far as I can tell it's not but I'm just making sure.. if not might be an idea for a later release
Luke 42217 Posted April 11, 2019 Posted April 11, 2019 Hi, simply stop the scheduled task, then it will run again later.
MisterAngelus 7 Posted November 1, 2019 Author Posted November 1, 2019 if your in the middle of a large conversion ... one that will take a very long time stooping the task and restarting is not reasonable cause then it will start over from 0% again also would it be possible to add a timer on conversions a time remaining perhaps
