Guest Posted April 9, 2019 Posted April 9, 2019 Pokemon.The.Movie.2000.1999.1080p.BluRay.REMUX.PCM2.0.H.264-PRAGMA.mkv Is the filename Im guessing its getting confused by the 2000 and 1999 year as it always gets detected as the FIRST pokemon movie not 2nd
Happy2Play 9806 Posted April 9, 2019 Posted April 9, 2019 What is the complete folder structure? If your media is not in a media named folders the queries appear to be slightly different. media in flat structure (no item folder) "C:\Users\Media\Desktop\Videos\Movies - DB\Pokemon.The.Movie.2000.1999.1080p.BluRay.REMUX.PCM2.0.H.264-PRAGMA.ext" 2019-04-08 17:53:36.525 Info App: MovieDbProvider: Finding id for item: Pokemon.The.Movie verses in item folder "C:\Users\Media\Desktop\Videos\Movies - DB\Pokemon.The.Movie.2000.1999.1080p.BluRay.REMUX.PCM2.0.H.264-PRAGMA\Pokemon.The.Movie.2000.1999.1080p.BluRay.REMUX.PCM2.0.H.264-PRAGMA.ext" or ""C:\Users\Media\Desktop\Videos\Movies - DB\Pokémon The Movie 2000 (1999)\Pokemon.The.Movie.2000.1999.1080p.BluRay.REMUX.PCM2.0.H.264-PRAGMA.ext" 2019-04-08 17:57:41.848 Info App: MovieDbProvider: Finding id for item: Pokemon The Movie 2000
Guest Posted April 9, 2019 Posted April 9, 2019 What is the complete folder structure? If your media is not in a media named folders the queries appear to be slightly different. media in flat structure (no item folder) "C:\Users\Media\Desktop\Videos\Movies - DB\Pokemon.The.Movie.2000.1999.1080p.BluRay.REMUX.PCM2.0.H.264-PRAGMA.ext" 2019-04-08 17:53:36.525 Info App: MovieDbProvider: Finding id for item: Pokemon.The.Movie verses in item folder "C:\Users\Media\Desktop\Videos\Movies - DB\Pokemon.The.Movie.2000.1999.1080p.BluRay.REMUX.PCM2.0.H.264-PRAGMA\Pokemon.The.Movie.2000.1999.1080p.BluRay.REMUX.PCM2.0.H.264-PRAGMA.ext" or ""C:\Users\Media\Desktop\Videos\Movies - DB\Pokémon The Movie 2000 (1999)\Pokemon.The.Movie.2000.1999.1080p.BluRay.REMUX.PCM2.0.H.264-PRAGMA.ext" 2019-04-08 17:57:41.848 Info App: MovieDbProvider: Finding id for item: Pokemon The Movie 2000 F:\Movies\2. BluRay REMUX\Pokemon.The.Movie.2000.1999.1080p.BluRay.REMUX.PCM2.0.H.264-PRAGMA.mkv is where its located and where emby is finding the file from
Luke 42217 Posted April 9, 2019 Posted April 9, 2019 Hi there, if you name the file to match the title on MovieDb, then you shouldn't have any issues.
daedalus 434 Posted April 9, 2019 Posted April 9, 2019 that doesn't answer why the querys differ when it's inside a folder or not
Luke 42217 Posted April 9, 2019 Posted April 9, 2019 When it's not in it's own folder we have to try and parse the file name and that's going to be a tricky exactly given the two years in the name.
Guest Posted April 9, 2019 Posted April 9, 2019 When it's not in it's own folder we have to try and parse the file name and that's going to be a tricky exactly given the two years in the name. Right but regardless the two years are after the first movie, which doesnt explain why its matching the first movie. I guess its falling back to that.
Senna 368 Posted April 9, 2019 Posted April 9, 2019 Hi there, if you name the file to match the title on MovieDb, then you shouldn't have any issues. I also see troubles for some titles, because Emby favors the results from TheMovieDBcollection instead of TheMovieDB. Example: Furious (2017) Emby picks up as title : The Fate of the Furious (2017) When I do an Identify and pick the right movie, I still see on correct movie page (Furious 2017) an URL after Links, referring to wrong collection : https://www.themoviedb.org/collection/9485 The other URL's on that page go to the right movie: https://trakt.tv/movies/furious-2017 https://www.themoviedb.org/movie/415381 https://www.imdb.com/title/tt6054874/ Above was tested from strm library, where all strm's are in same folder.
daedalus 434 Posted April 9, 2019 Posted April 9, 2019 (edited) When it's not in it's own folder we have to try and parse the file name and that's going to be a tricky exactly given the two years in the name. not really tricky, why not just pickup not the first thing that appears to be a year but the last? cause the most cases the last on is the intended release year Edited April 9, 2019 by daedalus
Luke 42217 Posted April 9, 2019 Posted April 9, 2019 I also see troubles for some titles, because Emby favors the results from TheMovieDBcollection instead of TheMovieDB. Example: Furious (2017) Emby picks up as title : The Fate of the Furious (2017) When I do an Identify and pick the right movie, I still see on correct movie page (Furious 2017) an URL after Links, referring to wrong collection : https://www.themoviedb.org/collection/9485 The other URL's on that page go to the right movie: https://trakt.tv/movies/furious-2017 https://www.themoviedb.org/movie/415381 https://www.imdb.com/title/tt6054874/ Above was tested from strm library, where all strm's are in same folder. This is not correct. When identifying a movie, the collection id plays zero role. In fact, that id has no role in the core emby server at all. It is only the autoboxsets plugin that uses it.
Luke 42217 Posted April 9, 2019 Posted April 9, 2019 not really tricky, why not just pickup not the first thing that appears to be a year but the last? cause the most cases the last on is the intended release year To give you a complete answer i would have to dive into all of our naming schemes, but no, it's not that simple when you take into consideration all of the different things we have to support. It becomes very easy to accidentally mis-interpret one thing as another. For this reason, anytime you have a tricky example such as this, you can make things easier for yourself by aligning your naming with moviedb: moviename (year).mkv
Senna 368 Posted April 9, 2019 Posted April 9, 2019 This is not correct. When identifying a movie, the collection id plays zero role. In fact, that id has no role in the core emby server at all. It is only the autoboxsets plugin that uses it.I'm not using the Autoboxsets plugin, but is that wrong link fetched for the Autoboxset plugin ? For this reason, anytime you have a tricky example such as this, you can make things easier for yourself by aligning your naming with moviedb: moviename (year).mkv The example I gave was following your template: Furious (2017).strm But Emby still gets it wrong for that movie.
Luke 42217 Posted April 9, 2019 Posted April 9, 2019 wrong link fetched for autoboxsets plugin? what do you mean by that?
Luke 42217 Posted April 9, 2019 Posted April 9, 2019 Regarding furious, i think what you meant to say is that MovieDb gets it wrong, because when you search for Furious, it is not the first result: https://www.themoviedb.org/search/movie?query=Furious&language=en So this will need to be reported to them. Thanks. 1
daedalus 434 Posted April 9, 2019 Posted April 9, 2019 and why you don't add the year to the query? https://www.themoviedb.org/search/movie?query=Furious%202017&language=en
Luke 42217 Posted April 9, 2019 Posted April 9, 2019 and why you don't add the year to the query? https://www.themoviedb.org/search/movie?query=Furious%202017&language=en That's adding the year into the search phrase which is not a good thing to do. They have a dedicated parameter that can be used with the search api to supply the year. But if you look at the results in my link above it would not matter because there are two titles with Furious in the name for 2017.
daedalus 434 Posted April 9, 2019 Posted April 9, 2019 (edited) forget this didn't read carefully the problem Edited April 9, 2019 by daedalus
Luke 42217 Posted April 9, 2019 Posted April 9, 2019 https://www.themoviedb.org/search/movie?query=Furious%20y:2017&language=en first result is that one we search for year in search string gives an even better result in this case But the second result is the correct one, not the first. And no, the year should not be part of the search text because that can make things difficult for the search engine for titles that have numbers in the name.
