jeramie 0 Posted April 8, 2019 Posted April 8, 2019 (edited) I have an hdhomerun quad and an IPTV subscription that i've connected to emby. The iptv provider has over 4000 channels, obviously i wouldn't want all of those included. I seem to be missing where you filter out groups of channels, like i don't want any of the Spanish channels, how do i tell it not to import those from the m3u url? Is there a channel limit for emby live tv? sometimes when i open up the guide it loads perfectly fine.. and fast.. other times it just sits there. i check the server and its not overloaded or anything. Thanks a lot EDIT: Also, it doesn't appear that all the channels show up in the guide when it does load up fine.. seems to load about a 1000 of them give or take. Edited April 8, 2019 by jeramie
Luke 42245 Posted April 8, 2019 Posted April 8, 2019 Hi there, right now you'd have to just edit the m3u. We plan to expand our channel management features in an upcoming update to allow you to better control this. Thanks.
jeramie 0 Posted April 8, 2019 Author Posted April 8, 2019 (edited) thanks for the info, i think i'll use xteve (i've used it for plex for a while) and filter through that. hopefully it works well with emby. What about a channel limit? does emby have a practical channel limitation like plex's ~480 limit? EDIT: so i notice that many of my channels don't appear in the guide grid, but if i search for them emby finds them fine. it seems like approx 500 channels show up in the grid. Edited April 8, 2019 by jeramie
Luke 42245 Posted April 8, 2019 Posted April 8, 2019 We don't have any channel limit that we're enforcing, but that number seems like a reasonable limit to me. 1
jeramie 0 Posted April 8, 2019 Author Posted April 8, 2019 Thanks for all your answers Luke, i really appreciate it.
Solution Spaceboy 2573 Posted April 8, 2019 Solution Posted April 8, 2019 thanks for the info, i think i'll use xteve (i've used it for plex for a while) and filter through that. hopefully it works well with emby. What about a channel limit? does emby have a practical channel limitation like plex's ~480 limit? EDIT: so i notice that many of my channels don't appear in the guide grid, but if i search for them emby finds them fine. it seems like approx 500 channels show up in the grid. theres no limit. There are two rather obscure arrows right at the bottom of the grid screen that will take you to the next X channels. 2
jeramie 0 Posted April 8, 2019 Author Posted April 8, 2019 theres no limit. There are two rather obscure arrows right at the bottom of the grid screen that will take you to the next X channels. oh wow i didn't even see those! lol thanks a lot spaceboy!
