useless_exec 0 Posted April 7, 2019 Posted April 7, 2019 I am having the worst time with installing emby on my debian 9 machine. I added emby to a group with read/write/execute access. There aren't any files in the folders yet because I my ISP will charge me extra if I go over my allocated limit. Here's some output from the terminal from my limited searches on google. groups emby returns emby : emby video chlor groups chlor returns chlor : chlor cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner ls -l /media/chlor/NAS/ shows the following: total 56drwxr-xr-x 2 chlor chlor 4096 Apr 6 17:08 Applicationsdrwxr-xr-x 2 chlor chlor 4096 Apr 6 17:08 Comicsdrwxr-xr-x 2 chlor chlor 4096 Apr 6 17:08 Documentariesdrwxr-xr-x 2 chlor chlor 4096 Apr 6 17:08 E-booksdrwxr-xr-x 2 chlor chlor 4096 Apr 6 17:09 Gamesdrwx------ 2 chlor root 16384 Mar 21 19:29 lost+founddrwxr-xr-x 2 chlor chlor 4096 Apr 6 17:09 Magazinesdrwxr-xr-x 2 chlor chlor 4096 Apr 6 17:09 Miscdrwxrwxrwx 2 chlor chlor 4096 Apr 6 17:09 Moviesdrwxr-xr-x 3 chlor chlor 4096 Apr 6 19:18 Musicdrwxr-xr-x 2 chlor chlor 4096 Apr 6 17:09 TV I have read through other searches that changing whichever user actually run emby can have effect but since that has been changed and updated several times I can not make happen easily. I go to locahost: 8096 and try to pick out the used folders I want like Movies or TV. I get an error that the path is not valid. The path IS valid. I can open a folder to it and use properties and see the path is right. I can CD to the directory and the folders are there like one expects. Is there a place I edit to make this happen or what suggestions can be made to work? Thanks and sorry for english, I am trying to learn.
Luke 42246 Posted April 8, 2019 Posted April 8, 2019 Hi there, where exactly does it say path cannot be found?
Luke 42246 Posted April 11, 2019 Posted April 11, 2019 Hi there, can you please attach the emby server log? Thanks.
