Bazzu85 22 Posted May 6, 2019 Author Posted May 6, 2019 It appears to be related to the way we are sending the subs to the app but we're still trying to investigate. Thx If you need I can upload the file on my gdrive and send to you..
ebr 16338 Posted May 13, 2019 Posted May 13, 2019 I have been playing your sample for over 10 minutes on my Fire without any issues. Perhaps it is related to the specific device or network conditions somehow.
Bazzu85 22 Posted May 13, 2019 Author Posted May 13, 2019 Have you tried with subs enabled? Which version of firestick do you tried?
ebr 16338 Posted May 13, 2019 Posted May 13, 2019 Yes, I tried two different subtitles. This is with a normal Fire device as I don't have a current stick at the moment. We will obtain one and see if it behaves differently. Thanks.
ebr 16338 Posted May 16, 2019 Posted May 16, 2019 Okay, played your item for over 10 minutes on a Fire TV 4K stick with no issue. Subs on. Whatever this is appears to be fairly difficult to nail down and may be environmental somehow that we simply haven't identified yet.
Bazzu85 22 Posted May 16, 2019 Author Posted May 16, 2019 Okay, played your item for over 10 minutes on a Fire TV 4K stick with no issue. Subs on. Whatever this is appears to be fairly difficult to nail down and may be environmental somehow that we simply haven't identified yet. Hi, thx for your test.. I don't know how to help you with the test.. The only thing I'm thinking is about the device..here in italy we have only the full hd version of the firestick..tomorrow I try againg the movie to see If the problem is still present and I send you another log.. anyhow..watching the log you see this strange freeze?
Luke 42246 Posted May 17, 2019 Posted May 17, 2019 tomorrow I try againg the movie to see If the problem is still present How did it go?
Bazzu85 22 Posted May 18, 2019 Author Posted May 18, 2019 How did it go? Sorry but this week was very intensive.. I tried now playing for about 10 minutes.. 3 freezes (second one was about 1.35.07, third on 1.38.19, I don't remember first one) I made a video about third freeze: https://drive.google.com/open?id=14KCDwVBQlGrZMOZxYOQgQrDvFSyVLSzo I think the problem is related to the 1080p firestick version.. If I start the movie WITHOUT any subs, the play start immediatly and I have no freezes.. If I start the movie WITH subs, the play hangs a little and then start (the initial freeze is similar to the freeze during the play).. Anyway after the video I sent you the log (about 10 minutes from this post). The name is Bazzu85
ebr 16338 Posted May 18, 2019 Posted May 18, 2019 I cannot see anything unusual in your log (thanks for sending). You may be correct though and the stick simply is bogging down rendering both the video and the subs. I'll see if I can dig out an older stick to test with.
Bazzu85 22 Posted August 29, 2019 Author Posted August 29, 2019 I cannot see anything unusual in your log (thanks for sending). You may be correct though and the stick simply is bogging down rendering both the video and the subs. I'll see if I can dig out an older stick to test with. Hi, I'm watching a movie right now.. I have the exact same problems as month ago.. With default forced subs the movie freeze randomly for a while.. Disabling the subs the problem doesn't occurs.. In the past issue exam you find a problem sending the subs.. If you want I can send you the movie to test..
Bazzu85 22 Posted August 29, 2019 Author Posted August 29, 2019 That would be great, thanks. PM to you and @@ebr thx
