Bazzu85 22 Posted April 7, 2019 Posted April 7, 2019 (edited) Hi as title, I watched with problems a movie on fire stick.. Randomly the movie freeze and after some seconds (varying) continue.. watching anime or tv shows (less heavy) give me no problem.. I attach some logs.. can you give me some feedback? Log 20190408.txt Log embyserver 20190408.txt Edited April 7, 2019 by Bazzu85
Luke 42246 Posted April 8, 2019 Posted April 8, 2019 Hi there, as a test, can you try turning off the server transcoding throttle feature? It will be in your server dashboard transcoding settings. Then please try to play again. Thanks !
Bazzu85 22 Posted April 8, 2019 Author Posted April 8, 2019 Hi, during the first hour of the movie I stopped and disabled the throttle and for about 30 minutes there were no freeze.. After that the freezes re started happening..
Bazzu85 22 Posted April 8, 2019 Author Posted April 8, 2019 As an additional info I watched the windows task manager when the freeze occurs and I can't see an unusual cpu use..
Luke 42246 Posted April 8, 2019 Posted April 8, 2019 Can you try lowering the in-app quality setting?
Bazzu85 22 Posted May 3, 2019 Author Posted May 3, 2019 (edited) Hi, I'm issuing again the problem on firestick app.. I attach some log..I tried playing with throttle enabled and disable.. after a couple of minute in both try the movie freezes for some seconds and continue.. can you please watch the log? first play start at 23:50:38.898 second play start at 23:52:56.332 Log emby server.txt Log remux 1.txt Log remux 2.txt Log remux 3.txt Log remux 4.txt Edited May 3, 2019 by Bazzu85
Bazzu85 22 Posted May 3, 2019 Author Posted May 3, 2019 (edited) This is a screenshot of the moment the movie freeze.. As you no problem with cpu because the transcode buffer is ok.. As additional test I tried lowering the resolution to 1.5mbps and after a couple of minute the movie freezes for a while.. I sended a log thruu the firestick app now.. Edited May 3, 2019 by Bazzu85
softworkz 5133 Posted May 4, 2019 Posted May 4, 2019 @@Luke - There are vtt subtitles involved in all cases, anything he could do to disable these?
Bazzu85 22 Posted May 4, 2019 Author Posted May 4, 2019 (edited) Vtt subs? What's these type of subs? here's the mediainfo for the file: Generale Unique ID : 16355845199938934940946733358973706115 (0xC4E056D99EBFC50D7B160A9B793DF83) Complete name : H:\Film\I\Iron Man - Collezione\[2013] Iron Man 3\Iron Man 3 (2013)\Iron Man 3 (2013) - BDrip.1080p.HEVC.AC3.ITA+ENG+SUB.mkv Format : Matroska Format version : Version 4 File size : 3,83 GiB Duration : 2 o 10 min Overall bit rate : 4.200 kb/s Encoded date : UTC 2019-01-14 13:00:10 Writing application : mkvmerge v28.2.0 ('The Awakening') 64-bit Writing library : libebml v1.3.6 + libmatroska v1.4.9 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 2 o 10 min Bit rate : 2.918 kb/s Width : 1.920 pixel Height : 800 pixel Display aspect ratio : 2,40:1 Frame rate mode : Costante Frame rate : 23,976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bit Bits/(Pixel*Frame) : 0.079 Stream size : 2,66 GiB (69%) Default : Si Forced : No Color range : Full Audio #1 ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 o 10 min Bit rate mode : Costante Bit rate : 640 kb/s Channel(s) : 6 canali Channel layout : L R C LFE Ls Rs Sampling rate : 48,0 kHz Frame rate : 31,250 FPS (1536 SPF) Bit depth : 16 bit Compression mode : Con perdita Stream size : 598MiB (15%) Title : Italiano Language : Italiano Service kind : Complete Main Default : No Forced : No Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 o 10 min Bit rate mode : Costante Bit rate : 640 kb/s Channel(s) : 6 canali Channel layout : L R C LFE Ls Rs Sampling rate : 48,0 kHz Frame rate : 31,250 FPS (1536 SPF) Bit depth : 16 bit Compression mode : Con perdita Stream size : 598MiB (15%) Title : Inglese Language : Inglese Service kind : Complete Main Default : No Forced : No Testo #1 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 4 min 3s Bit rate : 1 b/s Count of elements : 3 Stream size : 37,0 Byte (0%) Title : Italiano FORCED Language : Italiano Default : Si Forced : Si Testo #2 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 o 10 min Bit rate : 58 b/s Count of elements : 1724 Stream size : 56,2 KiB (0%) Title : Italiano Language : Italiano Default : No Forced : No Testo #3 ID : 6 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 o 10 min Bit rate : 61 b/s Count of elements : 1740 Stream size : 58,3 KiB (0%) Title : Inglese Language : Inglese Default : No Forced : No Menu 00:00:00.000 : en:00:00:00.000 00:04:52.751 : en:00:04:52.751 00:07:55.433 : en:00:07:55.433 00:12:12.440 : en:00:12:12.440 00:19:04.101 : en:00:19:04.101 00:23:47.885 : en:00:23:47.885 00:29:47.703 : en:00:29:47.703 00:39:46.384 : en:00:39:46.384 00:45:56.045 : en:00:45:56.045 00:59:19.639 : en:00:59:19.639 01:01:56.922 : en:01:01:56.922 01:09:24.452 : en:01:09:24.452 01:18:41.508 : en:01:18:41.508 01:23:52.945 : en:01:23:52.945 01:37:55.995 : en:01:37:55.995 01:56:18.305 : en:01:56:18.305 01:59:38.755 : en:01:59:38.755 the subs are all srt.. Edited May 4, 2019 by Bazzu85
Luke 42246 Posted May 4, 2019 Posted May 4, 2019 As additional test I tried lowering the resolution to 1.5mbps and after a couple of minute the movie freezes for a while.. Can you attach the ffmpeg log from this? thanks.
Bazzu85 22 Posted May 5, 2019 Author Posted May 5, 2019 Can you attach the ffmpeg log from this? thanks. Testing again the 1.5mbps freeze after a while.. I have 3 ffmpeg log (I don't know wich correspond to the 1.5mbps transcode but I think is first) I attach all these logs Log1.txt Log2.txt Log3.txt
Bazzu85 22 Posted May 5, 2019 Author Posted May 5, 2019 removing pause after a while another freeze (always with 1.5 transcode) I don't know why emby has 2 logs I attach a screen from emby server log Log4.txt Log5.txt
Luke 42246 Posted May 5, 2019 Posted May 5, 2019 As a test, can you try a similar video that doesn't have embedded subtitles and see how that compares? do you have any?
Bazzu85 22 Posted May 5, 2019 Author Posted May 5, 2019 As a test, can you try a similar video that doesn't have embedded subtitles and see how that compares? do you have any? I'll try to remux the file mantaining only the italian audio.. I'll update you soon..
Luke 42246 Posted May 5, 2019 Posted May 5, 2019 Well remuxing might fix it as well. You'd have to remux both with and without the subtitles in order to get an accurate comparison. Is this the only file giving you trouble?
Bazzu85 22 Posted May 5, 2019 Author Posted May 5, 2019 (edited) I tried to remux with mkvtoolnix with only italian track and no freeze..Now I'm watching the original file without selecting any subs, and no freeze.. Activating the forced subs after a while the freeze happens..I think the problem now is clear.. Additionally when the freeze appear, if I quickly change from forced sub to no sub the movie resume from freeze instantly... Edited May 5, 2019 by Bazzu85
Luke 42246 Posted May 5, 2019 Posted May 5, 2019 Can you try again to see if it's consistent? thanks.
Bazzu85 22 Posted May 5, 2019 Author Posted May 5, 2019 (edited) Can you try again to see if it's consistent? thanks.I tried 3/4 times.. When the sub is selected after a couple of minutes I have the freezes.. With no subs I played the movie for about 20 minutes without freeze.. Additionally when starting to play the movie with sub selected the movie hangs a while to start, starting with no subs the movie start immediately.. I tried another movie with forced subs and no problem detected.. The movie with problems played on chromecast has no problem.. Edited May 5, 2019 by Bazzu85
Luke 42246 Posted May 5, 2019 Posted May 5, 2019 Can you follow the instructions at the bottom here to submit an in-app log: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
Bazzu85 22 Posted May 5, 2019 Author Posted May 5, 2019 (edited) This is a screenshot of the moment the movie freeze.. As you no problem with cpu because the transcode buffer is ok.. As additional test I tried lowering the resolution to 1.5mbps and after a couple of minute the movie freezes for a while.. I sended a log thruu the firestick app now.. Can you follow the instructions at the bottom here to submit an in-app log: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks. as you see above I'd just sent a in-app log.. did you seen it on that timestamp? Edited May 5, 2019 by Bazzu85
Luke 42246 Posted May 5, 2019 Posted May 5, 2019 Reproduce your problem and then use this button to send the log. Then add the following information to your report in the forum: Exactly what you were doing and what happened. Include the name of whatever you played if it is a playback problem The time you sent the log The name of the Emby user on the local server that was logged in at the time
Bazzu85 22 Posted May 6, 2019 Author Posted May 6, 2019 The time is from my previously response.. The name is of the account is Bazzu85
ebr 16338 Posted May 6, 2019 Posted May 6, 2019 There appears to only be a tiny bit of playback in that log and I can't see anything that would necessarily indicate any problem on the app end.
Bazzu85 22 Posted May 6, 2019 Author Posted May 6, 2019 (edited) There appears to only be a tiny bit of playback in that log and I can't see anything that would necessarily indicate any problem on the app end. the log is about: 1. start play 2. after 2 minutes freeze 3. stop play 4. send log I think the problem is on the app side because on these specific file if I choose no subs the play has no freeze... playing on chromecast is ok.. Edited May 6, 2019 by Bazzu85
ebr 16338 Posted May 6, 2019 Posted May 6, 2019 It appears to be related to the way we are sending the subs to the app but we're still trying to investigate.
