Teddy 100 Posted April 7, 2019 Posted April 7, 2019 Luke, I would need your help for Emby Server to recognize a new USB Tuner that is recognized as AF9015 BDA Filter from the ServerWMC app.Since Windows Media Center is recognized and it is working well and I can see all the channels but from EmbyServer when I try to add a new tuner I receive the message "No new devices found, To add a new tuner, close this dialog and enter the device information manually" .I've tried it manually with Hauppauge and Other but it keeps saying "No devices found.....".My only interest to recognize the tuner on Emby Server is so that my wife can watch TV Live on her tablet with the app through EmbyServer. Any idea how to solve this or edit some file to fix it?Thanks in advance embyserver.txt Live TV Tuner Setup.bmp ServerWMC 1.bmp ServerWMC 2.bmp
Luke 42217 Posted April 7, 2019 Posted April 7, 2019 That's not the way it works for plugins at this time. you just install the plugin, refresh the guide, and that's it.
Teddy 100 Posted April 7, 2019 Author Posted April 7, 2019 I'm sorry Luke but I think that until Emby Server recognize the tuner this will not work even from the web application. The Emby Server guide and channels are recognized by the installed ServerWMC app (it takes the WMC data). When I try to reproduce a channel, the "wheel" of progress remains that way to infinity. Guide 1.bmp Guide 2.bmp Playing a channel.bmp TV Sources.bmp
Luke 42217 Posted April 7, 2019 Posted April 7, 2019 That's not the way it works for the plugins. They will never show in the tuner list.
Solution Teddy 100 Posted April 8, 2019 Author Solution Posted April 8, 2019 Luke, finally the problem has been solved by uninstalling EmbyServer and ServerWMC and doing a fresh installation.I do not know why but it's fixed.Thanks to support.
