How does Emby for Kodi handle multiple versions of a movie?
jonomite
I found some earlier posts on this but couldn't find a final answer. Does it support multiple versions of a movie in native mode?
Sent from my Nexus 5X using Tapatalk
Angelblue05
No. But in beta I added an Emby play option in the context menu to simulate add-on behavior so that you can select the version you want to play.
  • Like 1
jonomite
Thank you! So, when the current version of Emby for Kodi is released to stable, there will be a way to select different versions in native mode?
Angelblue05
Yes, that is correct.
  • Like 1
  • 3 weeks later...
So how do we have to name our Movies or do we have to store them seperately? Cause i need the Options for normal playback or 3D.
Guest
