bnwbass 3 Posted May 13, 2014 Posted May 13, 2014 Hello all, I have an interesting problem that have never encountered, I have been using MB for about 5 years now and very familiar with the interface and most features. I have stayed current on all the new releases etc. So heres the issue WMP will start the movie file and play for about 10-15 seconds and then close reverting back to the MBC theme screen. What I have done: uninstalled and reinstalled ffdshow, LAV, uninstalled and reinstalled media center and media player uninstalled and reinstalled MBC and MB3 server clean registry scanned windows for any media playback issues Same result, I am now to point if re-installing the win 7 OS. Does anyone have advice before I blow the OS away? thx bw
bnwbass 3 Posted May 13, 2014 Author Posted May 13, 2014 No.external setup, just installed codec and filters from MBT installation but I am using MBC interface.
ebr 16334 Posted May 13, 2014 Posted May 13, 2014 Okay, so you aren't using WMP - you are using the internal WMC player (which is not exactly the same). Does it behave this way on all content or only some?
