benbour 12 Posted April 5, 2019 Posted April 5, 2019 Hi guys. I have a bit of a dumb question here. Why can't I play my live TV when I access my server by my WAN IP? It shows I have Premiere in the server dashboard, but when I go to play live tv, it says I need premiere to unlock that feature. Thanks
BAlGaInTl 288 Posted April 5, 2019 Posted April 5, 2019 It should work remotely if you have a valid premier key. You are probalby going to be asked to submit a log file so that the developers can have a look at what's going on. Check out this thead for more info on that: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ 1
benbour 12 Posted April 5, 2019 Author Posted April 5, 2019 (edited) Log attached embyserver.7z Edited April 5, 2019 by benbour
ebr 16313 Posted April 5, 2019 Posted April 5, 2019 Where is the remote location? The device doing the playback will also need to be able to get to mb3admin.com to validate.
ebr 16313 Posted April 6, 2019 Posted April 6, 2019 ... from my office. Most corporate networks will block unknown sites.
benbour 12 Posted April 6, 2019 Author Posted April 6, 2019 yup, it is indeed blocked. I'll add it to my firewall's white list and hopefully that solves it.
