Loki93 2 Posted July 28, 2019 Posted July 28, 2019 I just did some testing with re-encoded movies that previously had this squeezing issue. I figured out that encoding assumes PAR 1:1 and therefor squeezes all movies that don't have PAR 1:1. The affected movies all had PARs like 65/45. Obviously the hardware encoders can't handle that. For re-encoding I used the following handbrake settings: Anamorphic: Off Modulus: 2 Keep aspect ratio: activated croping: custom (all values to zero) Maybe this will help people to avoid this squeezing issue until it's finally solved.
Loki93 2 Posted October 10, 2019 Posted October 10, 2019 Well, I need to check that as I did recoding on most of the affected movies with the previously posted settings. Therfore I didn't run into this issue again. Moreover I'm now using a FireTV 4k with the emby app. Hopefully I can do this during this weekend. Cheers. Gesendet von meinem G8341 mit Tapatalk
Loki93 2 Posted October 15, 2019 Posted October 15, 2019 Had the chance to re-test with non-PAR-1:1 content. The aspect ratio ist still squeezed to something like 4:3.
Luke 42203 Posted October 16, 2019 Posted October 16, 2019 Thanks for the feedback. We're still looking into this.
Luke 42203 Posted January 28, 2020 Posted January 28, 2020 @@Loki93 @@benaus Are you still running into this with the latest version?
softworkz 5129 Posted February 6, 2020 Posted February 6, 2020 @@benaus - For QuickSync, this will be fixed in the upcoming beta (.12)
benaus 4 Posted February 12, 2020 Author Posted February 12, 2020 @@benaus - For QuickSync, this will be fixed in the upcoming beta (.12) @@softworkz thank you very much for letting me know and thank you for all the work you put in 1
deffed 0 Posted May 23, 2020 Posted May 23, 2020 @@benaus - For QuickSync, this will be fixed in the upcoming beta (.12) Hi, I have the same aspect problems with non PAR 1:1 movies, is there any chance for a vaapi fix?
Luke 42203 Posted May 23, 2020 Posted May 23, 2020 Hi, I have the same aspect problems with non PAR 1:1 movies, is there any chance for a vaapi fix? hi @@deffed can we please look at an example? Thanks.
deffed 0 Posted May 23, 2020 Posted May 23, 2020 Example (2min / ~120MB) https://www.dropbox.com/s/ix3o5b0af0ucjin/2LDK%202004%20%281%29-001.mkv?dl=0 hardware_detection-63725841893.txt ffmpeg-transcode-91ecbc8a-79b7-4578-96d2-a6eee7bbb37c_1.txt ffmpeg-transcode-62dedbf0-9ca3-4916-9d38-d6c3810aab2b_1.txt
