xantios 0 Posted April 2, 2019 Posted April 2, 2019 Hi, Trying to get this up and running I have Ryzen 2400G which has the integrated video chip, for what i know that should be able to play along nicely with Emby ? now. i do have a additional GPU which is passed through to a VM for gaming. So my idea was to run games on my "big" GPU and run Emby transcoding on the integrated GPU. struggling along for almost 3 days now im kinda going insane so maybe someone can help out? Things i tried to do: - Added the emby user to the usergroup video - Updated everything, even instaleld the beta version of Emby - Tried to define the environment variables to point Emby to the GPU i wanted to use - Googled a lot Now, to save you all some time asking for logs: here is what i have vainfo libva info: VA-API version 1.4.0 libva info: va_getDriverName() returns -1 libva error: va_getDriverName() failed with unknown libva error,driver_name=(null) vaInitialize failed with error code -1 (unknown libva error),exit vainfo --display drm libva info: VA-API version 1.4.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so libva info: Found init function __vaDriverInit_1_4 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.4 (libva 2.4.0) vainfo: Driver version: Mesa Gallium driver 19.0.1 for AMD RAVEN (DRM 3.27.0, 5.0.0-8-generic, LLVM 8.0.0) vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice VAProfileHEVCMain10 : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointVLD VAProfileVP9Profile0 : VAEntrypointVLD VAProfileVP9Profile2 : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc Also attechted the hardware logging json file. There the both GPU's show up, but it doenst seem to "skip" the first GPU, forget about it and go on... Any clues on how i can get this running with hardware transcoding? Thanks ! emby.json.txt
Luke 42246 Posted April 3, 2019 Posted April 3, 2019 Hi there, have you gone through our hardware acceleration setup guide? https://github.com/MediaBrowser/Wiki/wiki/Hardware-Acceleration-Overview
xantios 0 Posted April 3, 2019 Author Posted April 3, 2019 (edited) Yes. multiple times. Update: reinstalled the entire box. still no bal. the hardware detection: "Error": { "Number": -1, "Message": "Failed to initialize VA /dev/dri/renderD128. Error -1" } however vainfo still seems to fine with it. Edited April 3, 2019 by xantios
xantios 0 Posted April 4, 2019 Author Posted April 4, 2019 What OS/Version is this? I tried Ubuntu 19.04 beta and Ubuntu 18.10 regarding Emby they don't seem to differ We'll look into this, thanks. Would be great Anything i can do to help? (Although i'm a web-developer, so i don't know if that helps?)
Luke 42246 Posted April 22, 2019 Posted April 22, 2019 @@xantios can you please try the 4.1 release? Does this make any difference? Thanks !
bigverm23 2 Posted April 23, 2019 Posted April 23, 2019 (edited) using a Ryzen 2200G here and there is no option for mine either under Hardware Acceleration... libva info: VA-API version 1.4.0libva info: va_getDriverName() returns 0libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.solibva info: Found init function __vaDriverInit_1_4libva info: va_openDriver() returns 0vainfo: VA-API version: 1.4 (libva 2.4.0)vainfo: Driver version: Mesa Gallium driver 19.0.2 for AMD RAVEN (DRM 3.27.0, 5.0.0-13-generic, LLVM 8.0.0)vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice VAProfileHEVCMain10 : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointVLD VAProfileVP9Profile0 : VAEntrypointVLD VAProfileVP9Profile2 : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc name of display: :0display: :0 screen: 0direct rendering: YesExtended renderer info (GLX_MESA_query_renderer): Vendor: X.Org (0x1002) Device: AMD RAVEN (DRM 3.27.0, 5.0.0-13-generic, LLVM 8.0.0) (0x15dd) Version: 19.0.2 Accelerated: yes Video memory: 256MB Unified memory: no Preferred profile: core (0x1) Max core profile version: 4.5 Max compat profile version: 4.5 Max GLES1 profile version: 1.1 Max GLES[23] profile version: 3.2Memory info (GL_ATI_meminfo): VBO free memory - total: 9 MB, largest block: 9 MB VBO free aux. memory - total: 2924 MB, largest block: 2924 MB Texture free memory - total: 9 MB, largest block: 9 MB Texture free aux. memory - total: 2924 MB, largest block: 2924 MB Renderbuffer free memory - total: 9 MB, largest block: 9 MB Renderbuffer free aux. memory - total: 2924 MB, largest block: 2924 MBMemory info (GL_NVX_gpu_memory_info): Dedicated video memory: 256 MB Total available memory: 3328 MB Currently available dedicated video memory: 9 MBOpenGL vendor string: X.OrgOpenGL renderer string: AMD RAVEN (DRM 3.27.0, 5.0.0-13-generic, LLVM 8.0.0)OpenGL core profile version string: 4.5 (Core Profile) Mesa 19.0.2OpenGL core profile shading language version string: 4.50OpenGL core profile context flags: (none)OpenGL core profile profile mask: core profileOpenGL version string: 4.5 (Compatibility Profile) Mesa 19.0.2OpenGL shading language version string: 4.50OpenGL context flags: (none)OpenGL profile mask: compatibility profileOpenGL ES profile version string: OpenGL ES 3.2 Mesa 19.0.2OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20 hardwaredetection.txt Edited April 23, 2019 by bigverm23
Gerrit507 24 Posted April 28, 2019 Posted April 28, 2019 (edited) I currently use a G4600 with Ubuntu 18.04 and docker and it's working fine so far but I want little more CPU power because I have quite a lot of containers running. That's why I wanted to upgrade to a 2400G. Did you guys have any luck to get this working? Have you installed the libva-mesa-driver package? https://wiki.archlinux.org/index.php/Hardware_video_acceleration#ATI/AMD This is also a helpful guide (in german though): https://wiki.ubuntuusers.de/Video-Dekodierung_beschleunigen/ Edited April 28, 2019 by Gerrit507
softworkz 5133 Posted April 28, 2019 Posted April 28, 2019 using a Ryzen 2200G here and there is no option for mine either under Hardware Acceleration... libva info: VA-API version 1.4.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so libva info: Found init function __vaDriverInit_1_4 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.4 (libva 2.4.0) vainfo: Driver version: Mesa Gallium driver 19.0.2 for AMD RAVEN (DRM 3.27.0, 5.0.0-13-generic, LLVM 8.0.0) vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice VAProfileHEVCMain10 : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointVLD VAProfileVP9Profile0 : VAEntrypointVLD VAProfileVP9Profile2 : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc name of display: :0 display: :0 screen: 0 direct rendering: Yes Extended renderer info (GLX_MESA_query_renderer): Vendor: X.Org (0x1002) Device: AMD RAVEN (DRM 3.27.0, 5.0.0-13-generic, LLVM 8.0.0) (0x15dd) Version: 19.0.2 Accelerated: yes Video memory: 256MB Unified memory: no Preferred profile: core (0x1) Max core profile version: 4.5 Max compat profile version: 4.5 Max GLES1 profile version: 1.1 Max GLES[23] profile version: 3.2 Memory info (GL_ATI_meminfo): VBO free memory - total: 9 MB, largest block: 9 MB VBO free aux. memory - total: 2924 MB, largest block: 2924 MB Texture free memory - total: 9 MB, largest block: 9 MB Texture free aux. memory - total: 2924 MB, largest block: 2924 MB Renderbuffer free memory - total: 9 MB, largest block: 9 MB Renderbuffer free aux. memory - total: 2924 MB, largest block: 2924 MB Memory info (GL_NVX_gpu_memory_info): Dedicated video memory: 256 MB Total available memory: 3328 MB Currently available dedicated video memory: 9 MB OpenGL vendor string: X.Org OpenGL renderer string: AMD RAVEN (DRM 3.27.0, 5.0.0-13-generic, LLVM 8.0.0) OpenGL core profile version string: 4.5 (Core Profile) Mesa 19.0.2 OpenGL core profile shading language version string: 4.50 OpenGL core profile context flags: (none) OpenGL core profile profile mask: core profile OpenGL version string: 4.5 (Compatibility Profile) Mesa 19.0.2 OpenGL shading language version string: 4.50 OpenGL context flags: (none) OpenGL profile mask: compatibility profile OpenGL ES profile version string: OpenGL ES 3.2 Mesa 19.0.2 OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20 @@Luke @@alucryd - It seems that ffdetect is unable to initialize libva for the AMD adapter. Any ideas?
alucryd 318 Posted April 29, 2019 Posted April 29, 2019 (edited) @@xantios @@bigverm23 Could you please try the following and post the output here? APP_DIR=/opt/emby-server export LD_LIBRARY_PATH=$APP_DIR/lib:$APP_DIR/lib/samba export LIBVA_DRIVERS_PATH=$APP_DIR/lib/dri:/usr/lib/x86_64-linux-gnu/dri:/usr/lib64/dri:/usr/lib/dri vainfo Edited April 29, 2019 by alucryd
bigverm23 2 Posted April 30, 2019 Posted April 30, 2019 @@xantios @@bigverm23 Could you please try the following and post the output here? APP_DIR=/opt/emby-server export LD_LIBRARY_PATH=$APP_DIR/lib:$APP_DIR/lib/samba export LIBVA_DRIVERS_PATH=$APP_DIR/lib/dri:/usr/lib/x86_64-linux-gnu/dri:/usr/lib64/dri:/usr/lib/dri vainfo where am I trying this exactly?
Luke 42246 Posted April 30, 2019 Posted April 30, 2019 In a terminal session. Do you know how to do that?
xantios 0 Posted April 30, 2019 Author Posted April 30, 2019 (edited) @@xantios @@bigverm23 Could you please try the following and post the output here? APP_DIR=/opt/emby-server export LD_LIBRARY_PATH=$APP_DIR/lib:$APP_DIR/lib/samba export LIBVA_DRIVERS_PATH=$APP_DIR/lib/dri:/usr/lib/x86_64-linux-gnu/dri:/usr/lib64/dri:/usr/lib/dri vainfo APP_DIR=/opt/emby-server export LD_LIBRARY_PATH=$APP_DIR/lib:$APP_DIR/lib/samba export LIBVA_DRIVERS_PATH=$APP_DIR/lib/dri:/usr/lib/x86_64-linux-gnu/dri:/usr/lib64/dri:/usr/lib/dri vainfo error: can't connect to X server! libva info: VA-API version 1.4.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /opt/emby-server/lib/dri/radeonsi_drv_video.so libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so libva info: Found init function __vaDriverInit_1_4 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.4 (libva 2.4.0) vainfo: Driver version: Mesa Gallium driver 19.0.2 for AMD RAVEN (DRM 3.27.0, 5.0.0-13-generic, LLVM 8.0.0) vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice VAProfileHEVCMain10 : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointVLD VAProfileVP9Profile0 : VAEntrypointVLD VAProfileVP9Profile2 : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc I currently use a G4600 with Ubuntu 18.04 and docker and it's working fine so far but I want little more CPU power because I have quite a lot of containers running. That's why I wanted to upgrade to a 2400G. Did you guys have any luck to get this working? Have you installed the libva-mesa-driver package? https://wiki.archlinux.org/index.php/Hardware_video_acceleration#ATI/AMD This is also a helpful guide (in german though): https://wiki.ubuntuusers.de/Video-Dekodierung_beschleunigen/ As a native Dutch speaker my German is rather rusty, but the language is similar enough to get a sense of what the guide is saying. I did install the libva-mesa-driver package already, currently trying to install the new release. edit: In the meanwhile updated to the latest Emby version. in the UI I still don't see any options when I switch to the "advanced" mode. Also checked the hardware detection log and there is no change as far as I can see (as a web-dev, im kinda used to read JSON files) Could it be (just a 'lucky guess') that Emby is probing the first device (index 0) instead of looping through them? because I have my primary GPU mapped to a VM (which is currently also running emby because I can't use my iGPU). If so; can I tell emby to dont be clever and just point it to a device? Edit 2: After updating I get the following output: APP_DIR=/opt/emby-server export LD_LIBRARY_PATH=$APP_DIR/lib:$APP_DIR/lib/samba export LIBVA_DRIVERS_PATH=$APP_DIR/lib/dri:/usr/lib/x86_64-linux-gnu/dri:/usr/lib64/dri:/usr/lib/dri vainfo error: can't connect to X server! libva info: VA-API version 1.3.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /opt/emby-server/lib/dri/radeonsi_drv_video.so libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so libva error: dlopen of /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so failed: /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so: undefined symbol: amdgpu_bo_list_create_raw libva info: Trying to open /usr/lib64/dri/radeonsi_drv_video.so libva info: Trying to open /usr/lib/dri/radeonsi_drv_video.so libva info: va_openDriver() returns -1 vaInitialize failed with error code -1 (unknown libva error),exit Edited April 30, 2019 by xantios
bigverm23 2 Posted May 1, 2019 Posted May 1, 2019 @@xantios @@bigverm23 Could you please try the following and post the output here? APP_DIR=/opt/emby-server export LD_LIBRARY_PATH=$APP_DIR/lib:$APP_DIR/lib/samba export LIBVA_DRIVERS_PATH=$APP_DIR/lib/dri:/usr/lib/x86_64-linux-gnu/dri:/usr/lib64/dri:/usr/lib/dri vainfo libva info: VA-API version 1.3.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /opt/emby-server/lib/dri/radeonsi_drv_video.so libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so libva error: dlopen of /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so failed: /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so: undefined symbol: amdgpu_bo_list_create_raw libva info: Trying to open /usr/lib64/dri/radeonsi_drv_video.so libva info: Trying to open /usr/lib/dri/radeonsi_drv_video.so libva info: va_openDriver() returns -1 vaInitialize failed with error code -1 (unknown libva error),exit
softworkz 5133 Posted May 1, 2019 Posted May 1, 2019 (edited) Could it be (just a 'lucky guess') that Emby is probing the first device (index 0) instead of looping through them? because I have my primary GPU mapped to a VM (which is currently also running emby because I can't use my iGPU). If so; can I tell emby to dont be clever and just point it to a device? Why would that be 'clever'? I'd say, that would be incredibly stupid... Look at the VAAPI section of the detection log that you posted. There you can see that it tries to open both devices. I would suggest to try to install this directly to the host machine instead of inside a VM. If you do, also disable the other VM(s)... Edited May 1, 2019 by softworkz
alucryd 318 Posted May 1, 2019 Posted May 1, 2019 Thanks guys, I may be able to get it working. Looks like Ubuntu finally ships a somewhat recent libva version, I'll update ours to the same version, it will ship with the next beta.
xantios 0 Posted May 1, 2019 Author Posted May 1, 2019 Why would that be 'clever'? I'd say, that would be incredibly stupid... Look at the VAAPI section of the detection log that you posted. There you can see that it tries to open both devices. I would suggest to try to install this directly to the host machine instead of inside a VM. If you do, also disable the other VM(s)... Admittedly, i might phrased that a bit weird. What i meant to say was: The detection log tells me its probing multiple devices, but maybe it doesn't know it can't use the Nvidia card so it fails? for debugging purposes it might be nice if I could tell Emby "Dont try, just use this specific device" Which is just a train of thought off course (Im obviously not familiar with the internal workings of Emby) Regarding my VM (singular): I'm running Emby on the host. (Ubuntu) the host has the Ryzen iGPU dedicated to it. the Nvidia GPU is passed to a VM (so it is not usable by the host) (using VFIO, KVM/Qemu) I'd say Emby would be fine ignoring the entire existence of the device. which if I interpreted your post(s) correctly it should? Thanks for the support by the way
softworkz 5133 Posted May 1, 2019 Posted May 1, 2019 Admittedly, i might phrased that a bit weird. What i meant to say was: The detection log tells me its probing multiple devices, but maybe it doesn't know it can't use the Nvidia card so it fails? for debugging purposes it might be nice if I could tell Emby "Dont try, just use this specific device" The detection process is accessing hardware devices in the exact same way as our included ffmpeg does. If it cannot be accessed during detection it won't work for transcoding. It might be a library mismatch problem though, as @@alucryd has stated above. I think your best bet might be to wait for the next beta and try again then.
Luke 42246 Posted May 9, 2019 Posted May 9, 2019 @@xantios can you try the beta server and let me know how that compares? thanks !
xantios 0 Posted May 18, 2019 Author Posted May 18, 2019 @@xantios can you try the beta server and let me know how that compares? thanks ! I just screamed right to my monitor something that would translate to: "I lived to see this happen" ( Dat ik het nog mee mag maken!) Luke, SoftWorkz you guys made my day!!
rutgerputter 0 Posted May 5, 2020 Posted May 5, 2020 Hi, I would like to jump on this thread for some help with my AMD 3200G APU. This is also a RAVEN GPU (Vega 8) like the 2400G and I got it to work with Jellyfin, but I want to use Emby as it is much better dealing with Live TV, DVR and transcoding media. I use a docker container based on Ubuntu Bionic 18.04 (linuxserverio). In this container I installed the vainfo and mesa-va-drivers to enable the GPU drivers. Kernel support is already there. But emby hardware detection still doesn't want to use the AMD GPU: "Devices": [ { "DeviceIndex": 0, "DeviceInfo": { "VendorId": 4098, "DeviceId": 5592, "SubsytemVendorId": 4098, "SubsytemDeviceId": 5592, "DevPath": "/sys/bus/pci/devices/0000:0e:00.0", "DrmCard": "/dev/dri/card0", "DrmRender": "/dev/dri/renderD128", "IsEnabled": 1, "IsBootVga": 1, "Error": { "Number": -1, "Message": "Failed to initialize VA /dev/dri/renderD128. Error -1" } The strange thing is that ffdetect in the emby folder can detect my vaenc and vadec devices just fine. I'm on the latest beta but Stable also doesn't work. Could you help shed some light on what I'm doing wrong? Rutger PS: my wainfo output:libva info: VA-API version 1.1.0libva info: va_getDriverName() returns 0libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.solibva info: Found init function __vaDriverInit_1_1libva info: va_openDriver() returns 0vainfo: VA-API version: 1.1 (libva 2.1.0)vainfo: Driver version: Mesa Gallium driver 19.2.8 for AMD RAVEN (DRM 3.36.0, 5.5.8-Unraid, LLVM 9.0.0)vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice VAProfileHEVCMain10 : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointVLD VAProfileVP9Profile0 : VAEntrypointVLD VAProfileVP9Profile2 : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc hardware_detection-63724305675.txt
