xtress 0 Posted April 1, 2019 Posted April 1, 2019 Al reproducir las peliculas tengo continuos cortes y no se que hacer, he probado varias configuraciones del menu y nada se entrecortan las pelis, al reproducir desde cualquier otro dispositivo sin problema gracias
ebr 16333 Posted April 2, 2019 Posted April 2, 2019 Hi. Please try lowering the in-app quality setting and see if that improves it.
xtress 0 Posted April 2, 2019 Author Posted April 2, 2019 How i can do that? Enviado desde mi iPhone utilizando Tapatalk
ebr 16333 Posted April 2, 2019 Posted April 2, 2019 Please look in the "Playback Settings" in the Fire TV app. Thanks.
xtress 0 Posted April 2, 2019 Author Posted April 2, 2019 I have tried Edith the bitrate settings, i dont see any option about quality Enviado desde mi iPhone utilizando Tapatalk
ebr 16333 Posted April 2, 2019 Posted April 2, 2019 I have tried Edith the bitrate settings, i dont see any option about quality Enviado desde mi iPhone utilizando Tapatalk Hi. Yes, that is the same thing. You have tried lowering it significantly? Like go down to 1Mb and then raise it up until you see the problem.
xtress 0 Posted April 2, 2019 Author Posted April 2, 2019 Thanks with 1mb that’s work correctly, and this depend of the film quality? If I change this option, is changes for all the films? Thanks Enviado desde mi iPhone utilizando Tapatalk
Luke 42239 Posted April 3, 2019 Posted April 3, 2019 Yes it will be for all videos. Now that you're seeing success with 1 mbps, you can try raising the value as you can until you run into the problem again. Please let us know if this helps. Thanks !
