CBers 7554 Posted August 31, 2020 Posted August 31, 2020 9 minutes ago, Everbrave said: I’m using the beta! Of the mobile app?
ebr 16338 Posted August 31, 2020 Posted August 31, 2020 1 hour ago, Everbrave said: I’m using the beta! On 8/1/2020 at 11:40 AM, ebr said: You could test the beta of the mobile app (posted in the testing section). You said you were using the Android TV app...
Carlo 4561 Posted August 31, 2020 Posted August 31, 2020 5 hours ago, Everbrave said: I’m using the beta! Hi, What version do you currently have? Thanks
Everbrave 62 Posted August 31, 2020 Posted August 31, 2020 11 hours ago, ebr said: You said you were using the Android TV app... Oh, now I see what you mean. Nvidia Shield TV is an Android TV device, can I still run the mobile app on it?
Everbrave 62 Posted August 31, 2020 Posted August 31, 2020 6 hours ago, cayars said: Hi, What version do you currently have? Thanks Emby for Android TV , version 1.8.28g
Everbrave 62 Posted August 31, 2020 Posted August 31, 2020 12 hours ago, CBers said: Of the mobile app? No, sorry I was confused; in fact Nvidia shield does not show the mobile app at all at Google store!
Everbrave 62 Posted August 31, 2020 Posted August 31, 2020 11 hours ago, ebr said: You said you were using the Android TV app... Yes, Google store doesn’t show any other app for Nvidia shield TV
ebr 16338 Posted September 1, 2020 Posted September 1, 2020 Hi. You would have to side-load it from the thread in the testing section of the forum.
Everbrave 62 Posted September 1, 2020 Posted September 1, 2020 (edited) 11 hours ago, ebr said: Hi. You would have to side-load it from the thread in the testing section of the forum. Would you recommend the mobile app over the Android TV app? EDIT: I installed the latest mobile app (beta .32) and it does not play 4K, HEVC, HDR very well, it just stops after 30 sec. or so; the TV app works on nvidia shield TV perfectly! As for the VoSub, I removed them; not so often in my Lib. Edited September 1, 2020 by Everbrave additional info.
Luke 42246 Posted September 1, 2020 Posted September 1, 2020 2 hours ago, Everbrave said: Would you recommend the mobile app over the Android TV app? EDIT: I installed the latest mobile app (beta .32) and it does not play 4K, HEVC, HDR very well, it just stops after 30 sec. or so; the TV app works on nvidia shield TV perfectly! As for the VoSub, I removed them; not so often in my Lib. Let's look at an example. Thanks.
ebr 16338 Posted September 1, 2020 Posted September 1, 2020 42 minutes ago, Luke said: Let's look at an example. Thanks. In the other thread, please .
