jeremymeyers 4 Posted March 30, 2019 Posted March 30, 2019 This was not covered in the media stub wiki. does the media stub feature only feature "one movie per folder"? I'm trying to add my Lord Of The Rings Collection blu-rays like this /movies/Lord of the Rings/ /movies/Lord of the Rings/The Lord of the Rings The Fellowship of the Ring (2001).bluray.disc /movies/Lord of the Rings/The Lord of the Rings The Two Towers (2002).bluray.disc /movies/Lord of the Rings/The Lord of the Rings The Return of the King (2003).bluray.disc But Emby is displaying Fellowship of the Ring three times in my collection (even though the paths are unique and correct). Do I need to create separate folders for each movie even though they are just stubs?
Luke 42217 Posted March 31, 2019 Posted March 31, 2019 Hi, in your second screenshot, what list is that?
Happy2Play 9806 Posted March 31, 2019 Posted March 31, 2019 (edited) Best guess "Folder Name" identification instead of "File Name" identification. So the three items are all "Lord of the Rings" I bet if all the items were in same item named folders you would not see this issue. You would have to manually identify each item in this scenario. Open each item and you will see the files mis-identified Might need to add a note on this in the Wiki. Mis-identification will happen whenever Folder and Item are named differently, like example above. All items identified as "The Lord of the Rings The Fellowship of the Ring" do to all media in same named folder "Lord of the Rings". Edited March 31, 2019 by Happy2Play
