BobbyDing 56 Posted May 12, 2019 Posted May 12, 2019 (edited) I can see the difficulty in automating a hide function that covers all use cases. How about (as a temp workaround) adding a manual hide/unhide a show folder on the server only. Basically Emby dropping in and removing a .ignore into the show folder when you check and uncheck the option. It's not as nice as fully automated, but at least you can temporarily hide unused folders of your choice. Then also maybe there could be another selection to tell Emby to unhide automatically if a new show file appears within the folder(s)? I'm guessing this would not be user specific. Or would this not work? Edited. .ignore was what I meant to say. Edited May 14, 2019 by BobbyDing 1
Luke 42287 Posted May 12, 2019 Posted May 12, 2019 I can see the difficulty in automating a hide function that covers all use cases. How about (as a temp workaround) adding a manual hide/unhide a show folder on the server only. Basically Emby dropping in and removing a .file into the show folder when you check and uncheck the option. It's not as nice as fully automated, but at least you can temporarily hide unused folders of your choice. Then also maybe there could be another selection to tell Emby to unhide automatically if a new show file appears within the folder(s)? I'm guessing this would not be user specific. Or would this not work? Hi, we already support this via ".ignore" files.
daedalus 434 Posted May 12, 2019 Posted May 12, 2019 I can see the difficulty in automating a hide function that covers all use cases. How about (as a temp workaround) adding a manual hide/unhide a show folder on the server only. Basically Emby dropping in and removing a .file into the show folder when you check and uncheck the option. It's not as nice as fully automated, but at least you can temporarily hide unused folders of your choice. Then also maybe there could be another selection to tell Emby to unhide automatically if a new show file appears within the folder(s)? I'm guessing this would not be user specific. Or would this not work? so you suggest an option as temp workaround for an option ? and we don't want an automated version of anything, we just want a manual switch to decide
daedalus 434 Posted June 2, 2019 Posted June 2, 2019 any decisions made upon this? it's really annoying, especially for auto organize purpose, and nearly "everyone" posted here wants to be able to see them again 2
Luke 42287 Posted June 2, 2019 Posted June 2, 2019 The current behavior allows us to support more non-standard folder structures than we were able to before, so that's why the change was made.
LqHnyBear 24 Posted June 2, 2019 Posted June 2, 2019 This also appears to affect upcoming in tv shows if they have no prior episodes/season folder, they won't show up in upcoming either until an episode is downloaded. The program I use to fetch my shows creates a file called tvshow.nfo. Could you just look for that file or understand that if it's in a tv series library, it's a tv show? 3
daedalus 434 Posted June 2, 2019 Posted June 2, 2019 The current behavior allows us to support more non-standard folder structures than we were able to before, so that's why the change was made. i still don't get this, but ok than for gods sake make it a f*** option with a warning, that when activated recognition of "non-standard folder structures" is limited by not supporting both i think you are sacrificing more than you gain, but what does i know 1
daedalus 434 Posted July 8, 2019 Posted July 8, 2019 any news on this? current behavior is actually super annoying 2
daedalus 434 Posted September 18, 2019 Posted September 18, 2019 so i managed a way to over come this ignorace just place an empty textfile named S01E01.strm file in any series that you want to keep visible but keep in mind, if you use the auto organize plugin, place the strm file in the same structure you want your episodes get sorted in, cause if the structures differ, emby silently ignores the stetting of the plugin and mimics the one on the filesystem
MBSki 1116 Posted December 28, 2019 Posted December 28, 2019 Luke, can a feature be added to the auto organize plug-in to delete empty folders in a main library? I don't want to use auto organize to copy or move files from a "recorded" directory. I just want to do clean up on the empty folders left behind when I delete the last episode of a show from within an app. I've tried to do this by setting my watch directory to the same directory as my tv show library, and checking extended clean, but it doesn't get rid of the empty folders. I'm assuming that's because it only applies to files that it's actually moved, not just any random empty folder.
Luke 42287 Posted December 28, 2019 Posted December 28, 2019 Luke, can a feature be added to the auto organize plug-in to delete empty folders in a main library? I don't want to use auto organize to copy or move files from a "recorded" directory. I just want to do clean up on the empty folders left behind when I delete the last episode of a show from within an app. I've tried to do this by setting my watch directory to the same directory as my tv show library, and checking extended clean, but it doesn't get rid of the empty folders. I'm assuming that's because it only applies to files that it's actually moved, not just any random empty folder. It would be a great option for a community contributor to add to AutoOrganize: https://github.com/MediaBrowser/Emby.AutoOrganize Thanks !
CBers 7571 Posted October 24, 2020 Posted October 24, 2020 @LukeAn old thread I know, but any chance of having a user option to be able to see empty shows please? As you have it now, actors in shows that are hidden, don't have that show associated to them. In the new search functionality, I can't search the NCIS shows in my library, as they are currently empty. Empty shows also do not show up in the upcoming list, if it is empty. Would be nice to have the option of showing empty show folders or not please. Thanks. 1
Luke 42287 Posted October 24, 2020 Posted October 24, 2020 It's not an easy throw-in. Some things are going to have to be reworked first, but yes we can get to this.
daedalus 434 Posted October 25, 2020 Posted October 25, 2020 so just to wrap this up, first you willingly removed empty folder support completely, instead of just adding an option to hide them, jsut because some users cried, cause they see sth that is actually present on their filesystem, then refused for 2 years to bring it back or change anything and now one comment on a resurrected thread is enough to confirming to change everything back to what was there in the first place? 1 1
Happy2Play 9814 Posted October 25, 2020 Posted October 25, 2020 I ensure the Series/Show has a Specials or Season X folder to allow the empty Shows to remain. Same for adding New/future Shows. 3
CBers 7571 Posted October 27, 2020 Posted October 27, 2020 On 25/10/2020 at 01:29, Happy2Play said: I ensure the Series/Show has a Specials or Season X folder to allow the empty Shows to remain. Same for adding New/future Shows. Thanks H2P, that seems to be a workaround until @Luke adds an option.
CBers 7571 Posted November 21, 2020 Posted November 21, 2020 On 25/10/2020 at 00:22, Luke said: It's not an easy throw-in. Some things are going to have to be reworked first, but yes we can get to this. What sort of timescale for this please Luke? In the current beta cycle? Thanks.
CBers 7571 Posted November 20, 2023 Posted November 20, 2023 (edited) On 25/10/2020 at 00:10, CBers said: @LukeAn old thread I know, but any chance of having a user option to be able to see empty shows please? As you have it now, actors in shows that are hidden, don't have that show associated to them. In the new search functionality, I can't search the NCIS shows in my library, as they are currently empty. Empty shows also do not show up in the upcoming list, if it is empty. Would be nice to have the option of showing empty show folders or not please. Thanks. On 25/10/2020 at 00:22, Luke said: It's not an easy throw-in. Some things are going to have to be reworked first, but yes we can get to this. Sorry to resurrect an old thread, but is there any update on this please @Luke? Looking for new season episodes for certain shows in Upcoming, but nothing shows up as they are currently empty, such as Doctor Who. I do have shows that have content in Upcoming that don't start until March 2024, so I know it's working as it should. I'd just like to include all shows, whether they are empty or not, in Upcoming, especially Christmas Specials. Thanks. Edited November 20, 2023 by CBers
Luke 42287 Posted November 20, 2023 Posted November 20, 2023 1 hour ago, CBers said: Sorry to resurrect an old thread, but is there any update on this please @Luke? Looking for new season episodes for certain shows in Upcoming, but nothing shows up as they are currently empty, such as Doctor Who. I do have shows that have content in Upcoming that don't start until March 2024, so I know it's working as it should. I'd just like to include all shows, whether they are empty or not, in Upcoming, especially Christmas Specials. Thanks. What empty folder is showing up that you would prefer to be hidden?
CBers 7571 Posted November 20, 2023 Posted November 20, 2023 7 minutes ago, Luke said: What empty folder is showing up that you would prefer to be hidden? You have it the wrong way around. If I have an empty folder for a TV show, i.e. there isn't a season folder or any episodes, then that show doesn't appear in the TV library. That's OK, although rather annoying, but it then extends to the Upcoming screen where future episodes of the TV show aren't listed due to the TV show folder being empty. I would like to see Upcoming episodes of all TV shows, whether the current folder is empty or not. This would also be the case for any new TV shows, where just the TV show folder exists. Sorry if I wasn't clear originally.
Luke 42287 Posted November 20, 2023 Posted November 20, 2023 8 hours ago, CBers said: You have it the wrong way around. If I have an empty folder for a TV show, i.e. there isn't a season folder or any episodes, then that show doesn't appear in the TV library. That's OK, although rather annoying, but it then extends to the Upcoming screen where future episodes of the TV show aren't listed due to the TV show folder being empty. I would like to see Upcoming episodes of all TV shows, whether the current folder is empty or not. This would also be the case for any new TV shows, where just the TV show folder exists. Sorry if I wasn't clear originally. Right there needs to be at least some content for the series, either an episode or season.
DarWun 357 Posted November 20, 2023 Posted November 20, 2023 (edited) 10 hours ago, CBers said: You have it the wrong way around. If I have an empty folder for a TV show, i.e. there isn't a season folder or any episodes, then that show doesn't appear in the TV library. That's OK, although rather annoying, but it then extends to the Upcoming screen where future episodes of the TV show aren't listed due to the TV show folder being empty. I would like to see Upcoming episodes of all TV shows, whether the current folder is empty or not. This would also be the case for any new TV shows, where just the TV show folder exists. Sorry if I wasn't clear originally. What I've been doing to get around this issue is creating an empty folder for the next Season in each series folder as soon as I've finished watching the current season. By doing that, the Upcoming list populates for the new episodes as soon as TVDB is updated to include the episodes. One thing I've noticed with the recent changes is that Specials now show up in the Upcoming list. I have an empty folder for Doctor Who Season 14 in the main series folder for when Season 14 starts airing next year. I noticed over the weekend that the three new specials that start airing this weekend are in the Upcoming list. That was pleasant surprise. I don't recall the past specials for Doctor Who showing up in the list until they were physically in my library. Edited November 20, 2023 by DarWun 1
CBers 7571 Posted November 20, 2023 Posted November 20, 2023 (edited) 3 hours ago, Luke said: Right there needs to be at least some content for the series, either an episode or season. Why? You have a TV show stored in the database, which has a valid TVDB/IMDb number, so you just need to process it like everything else. This has been a bugbear of mine since empty folders were hidden. Edited November 20, 2023 by CBers 1
CBers 7571 Posted November 20, 2023 Posted November 20, 2023 1 hour ago, DarWun said: What I've been doing to get around this issue is creating an empty folder for the next Season in each series folder as soon as I've finished watching the current season. I know how to get around the issue, but I shouldn't have to. 1
