GGadmin 1 Posted March 30, 2019 Posted March 30, 2019 Ever since I've changed internet service provider im unable to access my emby externally. I've tried added port forwarding, manually added external ip address. Not sure what else to look at. Last time I've set it up,i just installed the app on my synology nas and that's it. I would really appreciate anybody's help and suggestions. Sent from my SM-N950F using Tapatalk
Luke 42242 Posted March 30, 2019 Posted March 30, 2019 Hi there @@GGadmin, I would suggest checking out our Connection Troubleshooter. Please try the steps listed there and let us know which ones succeed and which ones do not, then we can go from there. Thanks !
darkassassin07 674 Posted March 30, 2019 Posted March 30, 2019 One thing to note is some isps block certian ports before they even make it to your router. I use telus for example and they block port 80. Even if I open that port nothing actually makes it back to my network. A tool like: https://www.yougetsignal.com/tools/open-ports/ can help you test that
GGadmin 1 Posted March 31, 2019 Author Posted March 31, 2019 Thanks guys, I'll check out all your suggestions. Sent from my SM-N950F using Tapatalk
Solution GGadmin 1 Posted March 31, 2019 Author Solution Posted March 31, 2019 @@Luke @@darkassassin07 Thanks! It's working now. I had to correctly enable port 80 on my router. Sent from my SM-N950F using Tapatalk 1
