josenightbreed 4 Posted March 29, 2019 Posted March 29, 2019 Hi! My guide is not refreshing correctly under some conditions, I have my pc bios set up to boot turn on the pc at 7am daily, (I'm old school, i turn off my pc when i go to sleep lol), i made a task to refresh the guide at 9am daily because my iptv provider only gives me 24 hours of guide and the provider refreshes the guide at around 6:30pm so i have another schedule to refresh at 7pm. My problem is that while emby runs and functions as soon as the pc boots into windows without any user logged in, (that part makes me happy), the guide refresh at 9am does not work it seems because when i get up and log in to the pc, (after 9am mind you ... i'm old and cranky so don't judge me lol), i have to run the task manually or else i wont have a guide until the 7pm scheduled refresh which works perfectly well. Any help is appreciated! Log.txt
Luke 42245 Posted March 29, 2019 Posted March 29, 2019 Hi, if the PC is not turned on at 9am and Emby Server is not running, then the task will not execute. The fixed schedule tasks only execute at that time and no other time. It sounds like instead you will want to use an interval of every 24 hours, as that will do the type of checking needed to handle your scenario.
Carlo 4561 Posted March 29, 2019 Posted March 29, 2019 He said he turns on the PC at 7am. So it should be alive and well for the 9am scheduled task. @@josenightbreed the log file you uploaded doesn't cover the 9am timeslot so there isn't anything to check related to this issue. However, there are a lot of errors in your logs when trying to update theme songs. Can you post a screenshot of the schedule for the Guide Refresh?
Luke 42245 Posted March 29, 2019 Posted March 29, 2019 He said he turns on the PC at 7am. So it should be alive and well for the 9am scheduled task. @@josenightbreed the log file you uploaded doesn't cover the 9am timeslot so there isn't anything to check related to this issue. However, there are a lot of errors in your logs when trying to update theme songs. Can you post a screenshot of the schedule for the Guide Refresh? But he said this: the guide refresh at 9am does not work it seems because when i get up and log in to the pc, (after 9am mind you
josenightbreed 4 Posted March 29, 2019 Author Posted March 29, 2019 Here are the screenshots of the schedule for the Guide Refresh.
Carlo 4561 Posted March 29, 2019 Posted March 29, 2019 But he said this: And then he said this: My problem is that while emby runs and functions as soon as the pc boots into windows without any user logged in, (that part makes me happy), the guide refresh at 9am does not work it seems because when i get up and log in to the pc, (after 9am mind you ... i'm old and cranky so don't judge me lol)
Luke 42245 Posted March 29, 2019 Posted March 29, 2019 This log file starts at 10am, which means Emby Server was not running at 9am, therefore the scheduled task could not have run. You'll need to have Emby Server running at 9am if you want the task to run at that exact time.
josenightbreed 4 Posted March 29, 2019 Author Posted March 29, 2019 The log started at 10 because i restarted emby and xteve i guess??, and i have a task made to start xteve at windows startup too If you need a log from startup i can post the one when i log in in the morning tomorrow, if it starts with a time other than 7am then something really weird is going on mmm... could it be that emby is not actually starting to work until i physically log in? Darn it ... now i'm confused hehehe.
Luke 42245 Posted March 29, 2019 Posted March 29, 2019 mmm... could it be that emby is not actually starting to work until i physically log in? Yes exactly. You'd have to set it up as a windows service if that's what you want to do.
josenightbreed 4 Posted March 29, 2019 Author Posted March 29, 2019 Yes exactly. You'd have to set it up as a windows service if that's what you want to do. Setup as a service with nssm, Everything should be fine and dandy .... I hope hehehe ... Thanks everyone for your time.
josenightbreed 4 Posted March 30, 2019 Author Posted March 30, 2019 It seems it did not trigger even as a service. Any ideas? Log.txt
josenightbreed 4 Posted March 31, 2019 Author Posted March 31, 2019 at 9am as the scheduled task is set, the 7pm task is more like a cosmetic thing hehehe, i don't mind if the 7pm fails, but the 9am one is vital to have a guide for the day
Luke 42245 Posted April 4, 2019 Posted April 4, 2019 Try restarting the server and then see if it runs the next day at 9am. Please let us know if this helps. Thanks.
