stablizershock 0 Posted March 28, 2019 Posted March 28, 2019 Hi! here is my current Emby setup. Emby Server is running on Windows and linked to Google Drive for media accessed via Google File Stream. It's running great. But I want to switch to Android so can anyone tell me how to link my Gdrive account in order to access the media from there in Emby Server for Android is there an app equivalent to Google File-stream for Android? Thanks in advance.
chivigoku 0 Posted March 28, 2019 Posted March 28, 2019 (edited) Hi! here is my current Emby setup. Emby Server is running on Windows and linked to Google Drive for media accessed via Google File Stream. It's running great. But I want to switch to Android so can anyone tell me how to link my Gdrive account in order to access the media from there in Emby Server for Android is there an app equivalent to Google File-stream for Android? Thanks in advance. Hi there, Looking for the same. As far as I know, we can use .strm and then add them to any folder. However I used gdrive addon from Kodi but does not work. Let see if @@ddurdle can help us Edited March 28, 2019 by chivigoku
drikosv8 25 Posted March 31, 2019 Posted March 31, 2019 (edited) Friend @ddurdle In this GoogleDrive-VideoStream-0.1.33, is asking for user and password in Cygwin, how to solve? Thank you Example Job [Create new scheduled task] job #2 username=GritePlay folder=griteplay@gmail.com every 1 mins looking for changes -- last run status: 2019-03-31 17:38:17.456001 - Username: Password: + job #3 username=GritePlay folder=m4rflix@gmail.com every 1 mins looking for changes -- last run status: 2019-03-31 17:37:17.394868 - Username: Password: + Edited March 31, 2019 by drikosv8
ddurdle 75 Posted April 3, 2019 Posted April 3, 2019 @drikosv8, did you set a username/password in the configuration page? If so, you need to make sure whatever the hostname you used, is in the /etc/hosts file, resolving to 127.0.0.1. 1
ddurdle 75 Posted April 3, 2019 Posted April 3, 2019 You can also update your job to use 127.0.0.1 instead of whatever hostname you defined. You can update the job using python setup.py.
Solution EODCrafter 186 Posted April 4, 2019 Solution Posted April 4, 2019 (edited) Hi! here is my current Emby setup. Emby Server is running on Windows and linked to Google Drive for media accessed via Google File Stream. It's running great. But I want to switch to Android so can anyone tell me how to link my Gdrive account in order to access the media from there in Emby Server for Android is there an app equivalent to Google File-stream for Android? Thanks in advance. Round - a - bout way, but I exported the .strm files with Kodi after adding Google Drive Plugin, Then Linked Emby Library to these files. They look like this in Windows but it works the same..... Edited April 4, 2019 by EODCrafter 1
stablizershock 0 Posted April 4, 2019 Author Posted April 4, 2019 Is there a proper step by step guide anywhere? From this what I get is Install Kodi than install Gdrive plugin. How to generate strm files via Kodi? How to link strm file to Emby (Just locate it to the folder path where strm files are located?
EODCrafter 186 Posted April 4, 2019 Posted April 4, 2019 (edited) Is there a proper step by step guide anywhere? From this what I get is Install Kodi than install Gdrive plugin. How to generate strm files via Kodi? How to link strm file to Emby (Just locate it to the folder path where strm files are located? Just added it, Only part I left out was clicking on the Addon Google Drive for Kodi. Be sure to click Save/Run as the final Step. Yes, In the Server Panel Library for Emby, Just Point Emby to this Folder IE TV, and Emby will import all your TV Shows. Edited April 4, 2019 by EODCrafter
stablizershock 0 Posted April 4, 2019 Author Posted April 4, 2019 Thank you for step by step process. I was able to generate the strm files and linked emby library to that folder and it picks up the movies, but when I try to play it I am getting he following error.
EODCrafter 186 Posted April 4, 2019 Posted April 4, 2019 (edited) Thank you for step by step process. I was able to generate the strm files and linked emby library to that folder and it picks up the movies, but when I try to play it I am getting he following error. Another user reported this issue, Really strange cause they Play in my Emby just fine. Edited April 4, 2019 by EODCrafter
drikosv8 25 Posted April 4, 2019 Posted April 4, 2019 @drikosv8, did you set a username/password in the configuration page? If so, you need to make sure whatever the hostname you used, is in the /etc/hosts file, resolving to 127.0.0.1. @@ddurdle Thank you friend. It worked! Great work you're doing.
drikosv8 25 Posted April 5, 2019 Posted April 5, 2019 (edited) @ ddurdle Friend After I put https in the plugin, it keeps me picking up the user screen and password, I can not get into the options, what did I do wrong? Username: Password: Very thanks Edited April 6, 2019 by drikosv8
stablizershock 0 Posted April 5, 2019 Author Posted April 5, 2019 Can you please send me step by step guide?
EODCrafter 186 Posted April 5, 2019 Posted April 5, 2019 (edited) Can you please send me step by step guide? I asked on the other Post identical to this one, where I admitted my fault....Why is Mapping the Drive not working? Edited April 5, 2019 by EODCrafter
drikosv8 25 Posted April 5, 2019 Posted April 5, 2019 (edited) Can some friend help me put my ssl certificate in the googledrive-videstream plug-in? Username: Password: Edited April 6, 2019 by drikosv8
drikosv8 25 Posted April 7, 2019 Posted April 7, 2019 Friend @@ddurdle and friends I need your help a lot, I am 3 days and I still can not solve this problem with ssl in the plugin. I have already installed the ssl certificate, but when I open the web interface with the python command default.py ./gdrive.db 443 ./mycert.pem, the scheduler does not export new strm and also after I add user and password in the plugin, it is no longer possible to navigate the web interface, it always asks for a password and it only stays in the main screen. In the plugin panel and in the scheduler only just written "exception". Please help me!! Thank you
ddurdle 75 Posted April 7, 2019 Posted April 7, 2019 (edited) i can't support your certificate issues. Also, if you are going to user a username/password, you MUST make sure the HOSTNAME that you define the scheduled job IS WHITELISTED in the /etc/hosts file to ADDRESS 127.0.0.1 OTHERWISE YOU GET THE EXCEPTION ERROR -- AUTHORIZATION NOT GRANTED. Edited April 7, 2019 by ddurdle 1
drikosv8 25 Posted April 7, 2019 Posted April 7, 2019 (edited) Eu não posso ter seus próprios problemas de certificado. Além disso, se você está cadastrando-se gratuitamente no fórum usando o nome de usuário / senha. Você deve ter certeza de que HOSTNAME que você está definindo o trabalho agendado está listado no arquivo / etc / hosts para ENDEREÇO 127.0.0.1 caso você recebeu o erro de exceção - Autorização não concedido. @ Thank you for taking the time to help me, my friend. I've looked at everything, and I still have the problem. 127.0.0.1 https: // myplugin: 8443 The certificate is correct, because the green padlock appears informing that the page is safe. More I have received the message below and does not export the strm, even without password and login, it happens the same. trabalho # 5 nome de usuário = pasta GritePlay = m4rflix@gmail.com - última execução status: 2019-04-07 02: 16: 08.352888 - exceção Edited April 7, 2019 by drikosv8
ddurdle 75 Posted April 24, 2019 Posted April 24, 2019 I haven't tested it with SSL. I would suggest removing the username and password setting as it sounds like it is not compatible with your SSL setup. 1
drikosv8 25 Posted April 24, 2019 Posted April 24, 2019 Any chance of being compatible in the future?
drikosv8 25 Posted April 24, 2019 Posted April 24, 2019 @@ddurdle encrypt and decrypt How does it work? I was curious to know how it works and how to use it? Thank you friend
drikosv8 25 Posted May 14, 2019 Posted May 14, 2019 only encrypts the url parameters Any explanation how to do this? Sorry, I'd really like to learn. 1
pedro alex13 0 Posted August 8, 2019 Posted August 8, 2019 O Emby Server está sendo executado no Windows e vinculado ao Google Drive para mídia acessada pelo Google File Stream. Está correndo muito bem. Mas eu quero mudar para o Android assim alguém pode me dizer como vincular minha conta do GDrive, a fim de acessar a mídia a partir daí em Emby Server para Android existe um aplicativo equivalente ao Google File-stream para Android? alguem já conseguiu?
EODCrafter 186 Posted August 9, 2019 Posted August 9, 2019 O Emby Server está sendo executado no Windows e vinculado ao Google Drive para mídia acessada pelo Google File Stream. Está correndo muito bem. Mas eu quero mudar para o Android assim alguém pode me dizer como vincular minha conta do GDrive, a fim de acessar a mídia a partir daí em Emby Server para Android existe um aplicativo equivalente ao Google File-stream para Android? alguem já conseguiu? You'd Probably get a better response if you Google-Translate that....JS
