IkeTaylor11 61 Posted September 5, 2019 Posted September 5, 2019 Wait - I thought the whole reason i added that was because your remote was sending that for previous channel...? if you can program it, why not just use the proper previous channel code? You added F3 keycode for me. The remote I use has a physical button for last channel and it programmed to F3. I would like both keycodes to remain in the software. I have been playing around with a button remapper to make a button function with keycode 266, but it requires a manual adb entry every time I reboot my shield. Having both keycodes allows for options when it comes to remotes. Sent from my iPhone using Tapatalk 1
ebr 16337 Posted September 5, 2019 Posted September 5, 2019 You added F3 keycode for me. The remote I use has a physical button for last channel and it programmed to F3. I would like both keycodes to remain in the software. I have been playing around with a button remapper to make a button function with keycode 266, but it requires a manual adb entry every time I reboot my shield. Having both keycodes allows for options when it comes to remotes. Sent from my iPhone using Tapatalk Okay, sorry, got y'all mixed up. Still, if anyone is manually programming a button, use the proper previous channel code instead of F3.
IkeTaylor11 61 Posted September 5, 2019 Posted September 5, 2019 Okay, sorry, got y'all mixed up. Still, if anyone is manually programming a button, use the proper previous channel code instead of F3. Yes I agree with that. Did both keycodes make it into the GA release for the ATV app yet? Or do I need to continue using the beta app? Sent from my iPhone using Tapatalk
Sammy 791 Posted September 5, 2019 Posted September 5, 2019 Harmony Elite has all of F1 to F12. I mapped F3 to Previous Channel. Not sure how to map the numerical codes such as 133 etc in the Harmony though.. Sent from my SM-G960U1 using Tapatalk
ebr 16337 Posted September 5, 2019 Posted September 5, 2019 Harmony Elite has all of F1 to F12. I mapped F3 to Previous Channel. Not sure how to map the numerical codes such as 133 etc in the Harmony though.. Not really following that... why does Fx come into play at all. Can't you just map a button on the remote to "Previous Channel" (which would be the proper code)? 1
pünktchen 1411 Posted September 5, 2019 Posted September 5, 2019 You have to choose a specific device that remote buttons you want to assign to the Harmony buttons. Android is not device. 1
Sammy 791 Posted September 5, 2019 Posted September 5, 2019 Yes. The device type is Media Center PC, Manufacturer is Nvidia and the device is Shield. The command for Prev Channel and several others do not exist in the Harmony Elite code set unfortunately. Harmony Elite and Hub are paired to the ShieldTV as a Harmony Bluetooth KEYBOARD so most keyboard keys are available. That said, Harmony 900 doesn't connect as a Bluetooth keyboard but rather an IR remote. I'll need to see if it has the F# key codes, either natively 2015 model or via FLIRC on the 2017 model, and report back. Sent from my SM-G960U1 using Tapatalk 1
Sammy 791 Posted September 5, 2019 Posted September 5, 2019 That said, I know that the numerical keys work with FLIRC and Device = Kodi on my 2017's but do not work via IR and native ShieldTV on my one 2015. Rather than continue to chase that I will probably get another FLIRC since Logitech doesn't seem to get it working even though I sent them the pronto hex codes.. Sent from my SM-G960U1 using Tapatalk
Sammy 791 Posted September 6, 2019 Posted September 6, 2019 There are no F# keys in the native implementation of the ShieldTV on the Harmony 900 keyset (or any other Harmony IR remote) for the 2015 model. I still haven't had the chance to check on the FLIRC/Kodi implementation on my 2017 models. I'm thinking I can teach Harmony to have it from one of those el cheapo remotes. Input? Thanks.
pünktchen 1411 Posted September 6, 2019 Posted September 6, 2019 I think beside the native Android keycodes @@ebr you really should implement some simple pc keyboard keycodes. And with simple i don't mean something like F3 that only one user requested! Something like this: H -> Homescreen G -> Guide I -> Info C -> Contextmenu P -> Play/Pause R -> Record S -> Subtitle Track selection A -> Audio Track selection L -> Last Channel Page Up -> TV Channel up Page Down -> TV Channel down Left -> Skip Back Right -> Skip Forward Ctrl+Left -> Previous Chapter Ctrl+Right -> Next Chapter Alt+Left -> Previous Track Alt+Right -> Next Track This could also be used then in Emby Theater. 5
Sammy 791 Posted September 6, 2019 Posted September 6, 2019 I think beside the native Android keycodes @@ebr you really should implement some simple pc keyboard keycodes. And with simple i don't mean something like F3 that only one user requested! Something like this: H -> Homescreen G -> Guide I -> Info C -> Contextmenu P -> Play/Pause R -> Record S -> Subtitle Track selection A -> Audio Track selection L -> Last Channel Page Up -> TV Channel up Page Down -> TV Channel down Left -> Skip Back Right -> Skip Forward Ctrl+Left -> Previous Chapter Ctrl+Right -> Next Chapter Alt+Left -> Previous Track Alt+Right -> Next Track This could also be used then in Emby Theater. Sounds good. I'm not sure if Harmony Elite sends those or not. I'll check and report back. Sent from my SM-G960U1 using Tapatalk
tadr 1 Posted January 15, 2020 Posted January 15, 2020 I think beside the native Android keycodes @@ebr you really should implement some simple pc keyboard keycodes. And with simple i don't mean something like F3 that only one user requested! Something like this: H -> Homescreen G -> Guide I -> Info C -> Contextmenu P -> Play/Pause R -> Record S -> Subtitle Track selection A -> Audio Track selection L -> Last Channel Page Up -> TV Channel up Page Down -> TV Channel down Left -> Skip Back Right -> Skip Forward Ctrl+Left -> Previous Chapter Ctrl+Right -> Next Chapter Alt+Left -> Previous Track Alt+Right -> Next Track This could also be used then in Emby Theater. Agreed - and it would be nice for these to be consistent with Emby Theater.. There are a few others that should be included as well, like Recorded TV/Recordings. See https://github.com/MediaBrowser/Wiki/wiki/Keyboard%20and%20Remote%20Support If keyboard shortcuts are implemented, then everyone using FLIRC's (myself and it sounds like many others) can just use the FLIRC software to program any arbitrary IR command on their harmony remotes (or any other remote) to send any of the keyboard shortcuts. Adding keyboard shortcuts like these would make the Android client much more usable with a remote and generally make it more friendly for new users and users transitioning from Windows Media Center. 1
Dan_Austin 71 Posted February 12, 2020 Posted February 12, 2020 Pronto.... wow, that's been a while . Sadly none of the customizable remotes have tools even close to what ProntoEdit was capable of. I like my Harmony, but the tools are horrific. No ability to edit direct IR hex codes. Cannot export/import device profiles to share. Setup the devices in such an order to have the wrong one be the default for an activity, delete and start over. On topic- I bought a 2019 Shield in part due to this thread, hoping to avoid the limited functionality inherent in most streaming device remotes. I am largely pleased with the results. If a few more of the gaming controller buttons, or F-keys, could be mapped to features like guide it would be icing on the cake. It would require either an in app help screen with the map or at least a knowledgebase article, but well worth it. 1
Sammy 791 Posted May 5, 2020 Posted May 5, 2020 (edited) @@ebr Any progress here? It's been over a year now. I'm setting up a new FLIRC and ran across this post on the FLIRC forums. Would it be possible to use the command line utility to map these android keycodes using the builtin hid conversion support? Info keyCommon on TV remotes to show additional information related to what iscurrently being viewedKEYCODE_INFO = 165 Guide keyOn TV remotes, shows a programming guideKEYCODE_GUIDE = 172 Red “programmable” keyOn TV remotes, acts as a contextual/programmable keyKEYCODE_PROG_RED = 183 Green “programmable” keyOn TV remotes, actsas a contextual/programmable keyKEYCODE_PROG_GREEN = 184 Yellow “programmable” keyOn TV remotes, acts as a contextual/programmable keyKEYCODE_PROG_YELLOW = 185 Blue “programmable” keyOn TV remotes, acts as a contextual/programmable keyKEYCODE_PROG_BLUE = 186 http://forum.flirc.tv/index.php?/topic/3746-how-would-i-use-flirc-util-to-map-these-android-key-codes/ Edited May 5, 2020 by Sammy
learch74 8 Posted July 4, 2022 Posted July 4, 2022 Any chance the keymap feature has been implemented? Using a firecube, and the one thing I'm missing is previous channel, channel up and down. Would love to add it. I'm using a USB keyboard/airmouse/remote combo and it works great and was cheap. I tied a Harmony and couldn't get the firecube to work the way I wanted. My remote has 4 button's I'd like to map. 209 to the F3 Key, 092 Channel up and 093 channel down. I've tried editing the /system/usr/keylayout file, but Amazon has locked it down for editing with the updates they pushed. Wish I had blocked updates sooner. If it's possible to map the keys please let me know.
ebr 16337 Posted July 4, 2022 Posted July 4, 2022 Hi. The Fire app will respond to the prev channel button on a proper TV remote already so you just need to send that code.
Luke 42245 Posted July 4, 2022 Posted July 4, 2022 Also improvements to channel up/down support across more Emby apps is planned for future updates. Thanks.
learch74 8 Posted July 4, 2022 Posted July 4, 2022 8 hours ago, ebr said: Hi. The Fire app will respond to the prev channel button on a proper TV remote already so you just need to send that code. Do you know what remote I need? The default one has no back key. IS there a specific remote I should get?
ebr 16337 Posted July 4, 2022 Posted July 4, 2022 1 hour ago, learch74 said: Do you know what remote I need? The default one has no back key. IS there a specific remote I should get? Hi. You don't want "back" you want KEYCODE_LAST_CHANNEL in Android terms.
learch74 8 Posted July 6, 2022 Posted July 6, 2022 On 7/4/2022 at 8:36 PM, ebr said: Hi. You don't want "back" you want KEYCODE_LAST_CHANNEL in Android terms. I found a remote that works amazing with the firecube, it's the Buzztv ARQ100 all the live tv keys work, number, go back, channel up and down! YAY! 1
heula 192 Posted April 24, 2023 Posted April 24, 2023 In Kodi there is a keymap.xml where we can set several keys to do things such as next subtitle or search subtitle and much more. There is also a addon called keymap editor which can do the same thing in a different way. Is there a way I can set a F1 - F12 key for my Nvidia Shield TV in combination with my harmony companion remote to do things like that? I would like to add a F key to cycle through available subtitles and open search when no subtitle is available. https://kodi.wiki/view/Keymap Thanks.
crusher11 1143 Posted July 18, 2023 Posted July 18, 2023 The one thing I miss after moving from LG to Android TV is being able to skip to the next/previous chapter with one button press instead of having to pull up the OSD and pick out the chapter I want.
