Sammy 791 Posted August 19, 2019 Posted August 19, 2019 @@ebr is it possible to assign multiple keycodes for previous channel? I would like keycode 133 (F3) to work as previous channel just like keycode 229 does now. The new buzz tv remote (arq-100) has 133 as the keycode programmed to the previous channel button. Sent from my iPhone using Tapatalk What Windows Shortcut corresponds to Key Code 229? I've got my set up working with Harmony 900's BTW.
IkeTaylor11 61 Posted August 19, 2019 Posted August 19, 2019 What Windows Shortcut corresponds to Key Code 229? I have no idea, not sure there even is one. Keycode 229 is and android button code, not windows. It’s sent from the remote button and mapped with the .kl file in android. You can use gamepad tester in android to see what key codes are sent from each button. Sent from my iPhone using Tapatalk
Sammy 791 Posted August 21, 2019 Posted August 21, 2019 Please post any issues in the appropriate testing thread but this would be a configuration issue with those remotes - not the app. Thanks. I got it figured out all by me self. Is there a possibility to map "Next Chapter" and "Previous Chapter" to Skip Forward >>| and Skip Back |<< in ShieldTV / Kodi, respectively? Thanks.
Sammy 791 Posted August 21, 2019 Posted August 21, 2019 Basically it would be nice to support the kodi keymapping in Emby on Android / Shield TV.. https://kodi.wiki/index.php?title=Keymap#Actions 1
Spaceboy 2573 Posted August 22, 2019 Posted August 22, 2019 I got it figured out all by me self. it would be nice if you could post that 1
Sammy 791 Posted August 22, 2019 Posted August 22, 2019 (edited) it would be nice if you could post that I set up my flirc as a Kodi device and then in the Logitech Harmony software I told my remote the device was a Media Center PC with a manufacturer of flirc and a device name of Kodi. I'm still searching for a solution to my 2015 Shield TV which is set up with it's internal IR receiver and not using a USB flirc device. I may need the spring for another flirc if I don't find an appropriate solution. Sent from my SM-G960U1 using Tapatalk Edited August 22, 2019 by Sammy 1
ebr 16337 Posted August 22, 2019 Posted August 22, 2019 We should be able to use the number keys to enter 3 or 4 digit channels for TV channel changes. You can do that now. Have you tried it?
Sammy 791 Posted August 22, 2019 Posted August 22, 2019 You can do that now. Have you tried it?Yes I have and hence the reason I am redoing re-did my FLIRC and Harmony setup. Now to figure out this last 2015 ShieldTV w/o FLIRC. Maybe this I'd what the question above is about? Sent from my SM-G960U1 using Tapatalk
ebr 16337 Posted August 22, 2019 Posted August 22, 2019 Yes I have and hence the reason I am redoing re-did my FLIRC and Harmony setup. Now to figure out this last 2015 ShieldTV w/o FLIRC. Maybe this I'd what the question above is about? Sent from my SM-G960U1 using Tapatalk I was responding to kaytoniya who stated we needed that functionality. Thx.
Sammy 791 Posted August 22, 2019 Posted August 22, 2019 I was responding to kaytoniya who stated we needed that functionality. Thx.I know. Sorry. I meant to confirm that this works with the further caveat that your system needs to be configured to deal with excepting the remote codes. Sent from my SM-G960U1 using Tapatalk
IkeTaylor11 61 Posted August 22, 2019 Posted August 22, 2019 @@ebr did you see my request from a couple days ago (post 50)? Haven’t seen a response from you about it. Sent from my iPhone using Tapatalk
ebr 16337 Posted August 22, 2019 Posted August 22, 2019 @@ebr did you see my request from a couple days ago (post 50)? Haven’t seen a response from you about it. Try the beta that just went up.
Sammy 791 Posted August 22, 2019 Posted August 22, 2019 Try the beta that just went up.Are there customizable remote key mappings in the beta? Is it in the settings menu? Sent from my SM-G960U1 using Tapatalk
ebr 16337 Posted August 22, 2019 Posted August 22, 2019 Are there customizable remote key mappings in the beta? Is it in the settings menu? No. I was answering his specific question.
Sammy 791 Posted August 22, 2019 Posted August 22, 2019 No. I was answering his specific question.Okay, so if the key codes are revised will they still work otherwise? Maybe I am confused about the reason for this change. Thanks. Sent from my SM-G960U1 using Tapatalk
ebr 16337 Posted August 22, 2019 Posted August 22, 2019 Okay, so if the key codes are revised will they still work otherwise? Maybe I am confused about the reason for this change. Sorry, I'm not sure what you mean. Ike asked for F3 to be treated like previous channel and that is what was added. 1
Sammy 791 Posted August 22, 2019 Posted August 22, 2019 What would be nice is to be able to modify these like one used to be able to do in MPC-HC on Windows when MB 2.6 launched a movie with an external player. One day maybe on the ShieldTV?
Sammy 791 Posted August 22, 2019 Posted August 22, 2019 (edited) Sorry, I'm not sure what you mean. Ike asked for F3 to be treated like previous channel and that is what was added. So was this there before? Do I need to go into the Harmony Software and add it, maybe to the LCD touch screen? Pretty cool and thanks for adding it, I thought it was being changed from one code number to another and would remove functionality for others but now I see I was wrong.. Like I said above, having this as a user customizeable input in the AndroidTV / ShieldTV settings would be fantastic! Edited August 22, 2019 by Sammy
IkeTaylor11 61 Posted August 22, 2019 Posted August 22, 2019 Try the beta that just went up. Do I need the beta android client or do you mean the beta server? If it’s the client I gotta figure out how to get that. Have always run the stable version on my shield. Sent from my iPhone using Tapatalk
Sammy 791 Posted August 22, 2019 Posted August 22, 2019 I've never had an issue with the beta app that was not resolved with a restart or a force close.. https://emby.media/community/index.php?/topic/24350-android-open-beta-testing/
IkeTaylor11 61 Posted August 23, 2019 Posted August 23, 2019 (edited) *deleted* Edited August 23, 2019 by IkeTaylor11
IkeTaylor11 61 Posted August 23, 2019 Posted August 23, 2019 (edited) @@ebr If you are willing to make some more adjustments this new remote I am working with has the most functionality i've seen for an android remote. It would be very nice to map out all the buttons to get the most out of it in Emby. I have attached a picture of the remote for reference. Currently the buttons listed below do nothing, but they do have a keycode associated to them. Would you be willing to map them out to make this remote fully functional? If you think something might conflict let me know. Gear/Settings button (keycode_f8: 138) map to App Settings menu in Emby while in the Emby client app Record button (keycode_media_record: 130) map to start recording while watching a channel in Emby while in the Emby client app Server button (keycode_f4: 134) map to Switch Server menu in Emby while in the Emby client app Can you manipulate buttons when pressed on the home screen of android tv? I know you guys have a tie in to the home screen for certain functionality. If these buttons could launch particular parts of Emby from the home screen that would be amazing. PVR button (keycode_f9: 139) map to Recordings in Emby from home screen Guide button (keycode_f6: 136) map to tv guide in Emby from home screen VOD button (keycode_f7: 137) map to Movies library in Emby from home screen Live TV tutton (keycode_f5: 135) mape to last watched channel in Emby from home screen Not sure if any or all of this can be accomplished. But, if it can i think this would really set Emby apart. Also since most of the keycodes are just F function keys any keyboard would also be able to do the same tasks with the mappings. Edited August 23, 2019 by IkeTaylor11
pünktchen 1411 Posted August 23, 2019 Posted August 23, 2019 Live TV should be Live TV and Last should be Last Channel. Also VOD doesn't make sense. What if there is more than one movie library?
Sammy 791 Posted August 23, 2019 Posted August 23, 2019 (edited) So I used F3 from my Harmony Elite which is seen as a Bluetooth keyboard by ShieldTV and rather than go to the last channel it returned to the guide and then the ShieldTV was nonresponsive to remote inputs for a few seconds. After that all was well again but I was on the Guide with focus on the channel I had previously tuned.Sent from my SM-G960U1 using Tapatalk Edited August 23, 2019 by Sammy
Sammy 791 Posted August 23, 2019 Posted August 23, 2019 What Windows Shortcut corresponds to Key Code 229? I have no idea, not sure there even is one. Keycode 229 is and android button code, not windows. It’s sent from the remote button and mapped with the .kl file in android. You can use gamepad tester in android to see what key codes are sent from each button. Sent from my iPhone using Tapatalk I googled gamepad tester and the app I found only work with phones and tablets. Is there one for AndroidTV devices?
