IkeTaylor11 61 Posted June 10, 2019 Posted June 10, 2019 That is good news and gives me hope for the last channel button too. I might try the Flirc route with an Inteset remote. The Flirc allows a standard IR remote to be paired with the Shield. They are partnering with Inteset to do standard programming with their remotes. If I were to get these does Emby have the ability to process the keycode if its pressed on the remote? If I went with this option I would have to go back to using a separate keyboard again though.
ebr 16337 Posted June 10, 2019 Posted June 10, 2019 The next beta of the app will recognize the last channel button if you can make your remote send that to the device. 1
nick114 1 Posted July 28, 2019 Posted July 28, 2019 there is a plug in on kodi what can map keys on a remote it is called keymap editor the creator is takoi is there any way we can copy it for emby
IkeTaylor11 61 Posted August 14, 2019 Posted August 14, 2019 The next beta of the app will recognize the last channel button if you can make your remote send that to the device. did this ever make it into the latest beta? I found a software remote that has the ability to do last channel and was hoping to try it out tonight.
ebr 16337 Posted August 15, 2019 Posted August 15, 2019 did this ever make it into the latest beta? I found a software remote that has the ability to do last channel and was hoping to try it out tonight. It is in the current release of the app. Thanks.
pünktchen 1411 Posted August 15, 2019 Posted August 15, 2019 @@ebr can you make number zero act as last channel please?
IkeTaylor11 61 Posted August 15, 2019 Posted August 15, 2019 @@ebr can you make number zero act as last channel please? Can’t do that. The number pad is used to enter channel numbers in the live TV guide. It would stop that from working. Sent from my iPhone using Tapatalk
pünktchen 1411 Posted August 15, 2019 Posted August 15, 2019 Can’t do that. The number pad is used to enter channel numbers in the live TV guide. It would stop that from working. Sent from my iPhone using Tapatalk I mean when there's nothing on screen, no guide, no osd, no channellist.Btw. zero alone doesn't work correctly anyway. I have a channel with number 0 but this ignored.
IkeTaylor11 61 Posted August 16, 2019 Posted August 16, 2019 It is in the current release of the app. Thanks. It works!!!!! I can use my Sony TV remote with CEC and when I hit the "jump" button it goes back to the previous channel. Now I just wish I could find an Android remote with that damn button on it.
IkeTaylor11 61 Posted August 16, 2019 Posted August 16, 2019 @@ebr this is the best thing ever. I was able to program a button on my third party remote with my shield. I now have a dedicated previous channel button on the remote I use everyday with my shield. Thank you for getting this added into Emby. Sent from my iPhone using Tapatalk
Sammy 791 Posted August 16, 2019 Posted August 16, 2019 It works!!!!! I can use my Sony TV remote with CEC and when I hit the "jump" button it goes back to the previous channel. Now I just wish I could find an Android remote with that damn button on it. @@ebr this is the best thing ever. I was able to program a button on my third party remote with my shield. I now have a dedicated previous channel button on the remote I use everyday with my shield. Thank you for getting this added into Emby. Sent from my iPhone using Tapatalk Do you guys care to share a bit more? I'd like to get the correct settings in my Harmony 900's and Harmony Elite to do this too! What model Sony TV? Maybe I can emulate that for my ShieldTV's. What third party remote? Something to try too? TIA Sent from my SM-G960U1 using Tapatalk
IkeTaylor11 61 Posted August 16, 2019 Posted August 16, 2019 (edited) Channel up and down should be the next! Yes, I 2nd this. I actually thought it had this already, but it doesn't work. @@ebr can you add the following keycodes into the next version of Emby. KEYCODE_CHANNEL_DOWN public static final int KEYCODE_CHANNEL_DOWN Key code constant: Channel down key. On TV remotes, decrements the television channel. * @apiSince 11 Constant Value: 167 (0x000000a7) KEYCODE_CHANNEL_UP public static final int KEYCODE_CHANNEL_UP Key code constant: Channel up key. On TV remotes, increments the television channel. * @apiSince 11 Constant Value: 166 (0x000000a6) Edited August 16, 2019 by IkeTaylor11
IkeTaylor11 61 Posted August 16, 2019 Posted August 16, 2019 Do you guys care to share a bit more? I'd like to get the correct settings in my Harmony 900's and Harmony Elite to do this too! What model Sony TV? Maybe I can emulate that for my ShieldTV's. What third party remote? Something to try too? TIA Sent from my SM-G960U1 using Tapatalk Any TV remote that has a "last", "jump", "chnl rtn" button on it should work for you to test with or program a button on your Shield 3rd party remote. I used my Sony remote with CEC enabled and it worked fine. I just don't want to use multiple remotes. I currently have the remote in the link below as the remote I use with my Shield. It works amazing and every button is programmable on it. https://www.aliexpress.com/item/32796705881.html I am going to be purchasing the remote listed below to test this weekend. It has more physical buttons, including a previous channel button. Hopefully I don't have to do any button programming with it. But, I will update here once I know. https://www.amazon.com/dp/B07KMLZKNV/?coliid=I3R86G2XBUF2IH&colid=2TT8Q5LR8SV9W&psc=1&ref_=lv_ov_lig_dp_it 1
Sammy 791 Posted August 16, 2019 Posted August 16, 2019 Any TV remote that has a "last", "jump", "chnl rtn" button on it should work for you to test with or program a button on your Shield 3rd party remote. I used my Sony remote with CEC enabled and it worked fine. I just don't want to use multiple remotes. I currently have the remote in the link below as the remote I use with my Shield. It works amazing and every button is programmable on it. https://www.aliexpress.com/item/32796705881.html I am going to be purchasing the remote listed below to test this weekend. It has more physical buttons, including a previous channel button. Hopefully I don't have to do any button programming with it. But, I will update here once I know. https://www.amazon.com/dp/B07KMLZKNV/?coliid=I3R86G2XBUF2IH&colid=2TT8Q5LR8SV9W&psc=1&ref_=lv_ov_lig_dp_it Does that first remote need any button mapping? It is cheap enough to grab one to use to program my Harmony remotes. I have seven TVs run by Shield TV and one run by Fire TV. It would get a little bit expensive to buy one for each TV especially since I already have all these Harmony 900 remotes and one Harmony Elite remote that works great with Alexa and can be used to control my lights and thermostats also with my Vera Plus home automation controller. Sent from my SM-G960U1 using Tapatalk
IkeTaylor11 61 Posted August 16, 2019 Posted August 16, 2019 Does that first remote need any button mapping? It is cheap enough to grab one to use to program my Harmony remotes. I have seven TVs run by Shield TV and one run by Fire TV. It would get a little bit expensive to buy one for each TV especially since I already have all these Harmony 900 remotes and one Harmony Elite remote that works great with Alexa and can be used to control my lights and thermostats also with my Vera Plus home automation controller. Sent from my SM-G960U1 using Tapatalk you shouldnt need any other remotes since you have a harmony. just hit the previous channel button on the harmony remote, it should send the correct keycode to the Shield and change the channel. The aliexpress remote I have does not have a physical previous channel button, I programmed a button on it from the previous channel button on my tv remote. 1
ebr 16337 Posted August 16, 2019 Posted August 16, 2019 Yes, I 2nd this. I actually thought it had this already, but it doesn't work. @@ebr can you add the following keycodes into the next version of Emby. KEYCODE_CHANNEL_DOWN public static final int KEYCODE_CHANNEL_DOWN Key code constant: Channel down key. On TV remotes, decrements the television channel. * @apiSince 11 Constant Value: 167 (0x000000a7) KEYCODE_CHANNEL_UP public static final int KEYCODE_CHANNEL_UP Key code constant: Channel up key. On TV remotes, increments the television channel. * @apiSince 11 Constant Value: 166 (0x000000a6) I still don't want to do this until we can speed up channel changing to be consistently within a second or two. However, when we get there, one question is where does that go? Does it always go to the next lowest channel number or does it go to the previous one how your channels are currently sorted?
IkeTaylor11 61 Posted August 16, 2019 Posted August 16, 2019 I still don't want to do this until we can speed up channel changing to be consistently within a second or two. However, when we get there, one question is where does that go? Does it always go to the next lowest channel number or does it go to the previous one how your channels are currently sorted? To me it would make sense for it to follow the channel order that is shown in the programming guide screen. So if you put your favorites first in the guide then channel up or down would incorporate those in the order. 2
Sammy 791 Posted August 16, 2019 Posted August 16, 2019 you shouldnt need any other remotes since you have a harmony. just hit the previous channel button on the harmony remote, it should send the correct keycode to the Shield and change the channel. The aliexpress remote I have does not have a physical previous channel button, I programmed a button on it from the previous channel button on my tv remote.I guess I need some assistance with my Harmony's, ShieldTV and Emby.. I have three scenarios. 1. Harmony Elite with Hub controlling a 2017 ShieldTV via Harmony Bluetooth Keyboard mapping. 2. Harmony 900 controlling 2017 ShieldTV via FLIRC USB Dongle. 3. Harmony 900 controlling 2015 ShieldTV via its native IR receiver. Any assistance to properly set up each of these would be great! Thanks! Sent from my SM-G960U1 using Tapatalk
Sammy 791 Posted August 16, 2019 Posted August 16, 2019 To me it would make sense for it to follow the channel order that is shown in the programming guide screen. So if you put your favorites first in the guide then channel up or down would incorporate those in the order.I agree with this method of incorporation. Sent from my SM-G960U1 using Tapatalk
IkeTaylor11 61 Posted August 16, 2019 Posted August 16, 2019 (edited) I guess I need some assistance with my Harmony's, ShieldTV and Emby.. I have three scenarios. 1. Harmony Elite with Hub controlling a 2017 ShieldTV via Harmony Bluetooth Keyboard mapping. 2. Harmony 900 controlling 2017 ShieldTV via FLIRC USB Dongle. 3. Harmony 900 controlling 2015 ShieldTV via its native IR receiver. Any assistance to properly set up each of these would be great! Thanks! Sent from my SM-G960U1 using Tapatalk This isn’t the place for this. Start a new thread and ask for help. Someone might know how to configure what you need to do. I do not use harmony remotes or flirc. Not sure why you would even be having an issue though. Just push the previous channel button on your remote. That should be all. Your best bet would be to reach out to Harmony support since its their remote you are trying to use. Has nothing to do with Emby or the Shield. Its remote control logic. Sent from my iPhone using Tapatalk Edited August 16, 2019 by IkeTaylor11
Sammy 791 Posted August 16, 2019 Posted August 16, 2019 This isn’t the place for this. Start a new thread and ask for help. Someone might know how to configure what you need to do. I do not use harmony remotes or flirc. Not sure why you would even be having an issue though. Just push the previous channel button on your remote. That should be all. Your best bet would be to reach out to Harmony support since its their remote you are trying to use. Has nothing to do with Emby or the Shield. Its remote control logic. Sent from my iPhone using Tapatalk You don't really have to be rude about it. Jeez. This discussion is all about setting up Emby to work with remotes and very much fits. Having the remote send the correct codes to control Emby on the ShieldTV is the discussion here. BTW, there is no Previous Channel button on my Harmony Remotes as it returns to the previous screen in AndroidTV as it is mapped as a Back button.
IkeTaylor11 61 Posted August 16, 2019 Posted August 16, 2019 You don't really have to be rude about it. Jeez. This discussion is all about setting up Emby to work with remotes and very much fits. Having the remote send the correct codes to control Emby on the ShieldTV is the discussion here. BTW, there is no Previous Channel button on my Harmony Remotes as it returns to the previous screen in AndroidTV as it is mapped as a Back button. I wasn't being rude at all, just helps to keep threads on topic. This thread was about allowing specific buttons on remotes to work inside Emby. That has been accomplished and has been tested and verified to work. Emby isn't going to help you setup your remote, that would be insane. There are thousands or remote types that people use. Emby can interpret the button press correctly, hence the issue is complete. If you don't have a previous channel button on your remote then you would need to program a button with android keycode 229 for Emby to interpret. As I said reach out to Harmony and ask them how to do it.
pünktchen 1411 Posted August 18, 2019 Posted August 18, 2019 I still don't want to do this until we can speed up channel changing to be consistently within a second or two. However, when we get there... It is already. At least with the direct play option. Of course it's not with timeshifting enabled and you will never get there as long as you are using ffmpeg to create the buffer file. So please give us now channel up and down!
IkeTaylor11 61 Posted August 19, 2019 Posted August 19, 2019 @@ebr is it possible to assign multiple keycodes for previous channel? I would like keycode 133 (F3) to work as previous channel just like keycode 229 does now. The new buzz tv remote (arq-100) has 133 as the keycode programmed to the previous channel button. Sent from my iPhone using Tapatalk
