justmejustme 3 Posted March 27, 2019 Posted March 27, 2019 When I start Emby while offline (WiFi off or WiFi disconnected), Emby is very flaky and slow. If you press Home and then select Settings, none of those buttons work. You have to actually connect WiFi to be able to enter the individual settings screens to change such items as Playback->Enable External Video Players To reproduce on your Pixelbook: Turn WiFi off like you're on a bus w/o WiFi Start Emby Press Home Press Hamburger->Settings Select Playback Wait until time ends for the spinning disc.
Luke 42244 Posted March 27, 2019 Posted March 27, 2019 Hi,yes many of these settings are saved on the server so we'll need to rework them a bit for offline mode. thanks.
justmejustme 3 Posted March 27, 2019 Author Posted March 27, 2019 That would be great, it makes it much harder to use on a bus or plane when WiFi is just not available. Hi,yes many of these settings are saved on the server so we'll need to rework them a bit for offline mode. thanks.
