weyb 25 Posted July 27, 2020 Author Posted July 27, 2020 Hi, I installed the update via the zipfile, I saw a note on my screen telling me Emby was updated, I updated the libraries ("mediatheques" in French) on Emby Web client on my PC, but the same TV series are missing : should I do smthg with Emby for Kodi (re-synchronize ? how ?) Regards
Luke 42240 Posted August 4, 2020 Posted August 4, 2020 @weyb yes I would do a sync from Kodi. @jachin99 can you explain how to start that manually? Thanks !
jachin99 88 Posted August 4, 2020 Posted August 4, 2020 (edited) On 7/27/2020 at 3:27 PM, weyb said: Hi, I installed the update via the zipfile, I saw a note on my screen telling me Emby was updated, I updated the libraries ("mediatheques" in French) on Emby Web client on my PC, but the same TV series are missing : should I do smthg with Emby for Kodi (re-synchronize ? how ?) Regards You can try to force a sync in emby for Kodi but I would reset your local database via emby for Kodi. There is an option to do either in the emby for Kodi settings I believe. E4k is comprised of at least four separate addons in Kodi so if you go to the my addons screen then you will have to find the emby for Kodi add-on that takes to the options screen. No can screenshot it or something if you need more help. Edited August 4, 2020 by jachin99
Tandhruil 27 Posted August 5, 2020 Posted August 5, 2020 On 27/07/2020 at 21:27, weyb said: Hi, I installed the update via the zipfile, I saw a note on my screen telling me Emby was updated, I updated the libraries ("mediatheques" in French) on Emby Web client on my PC, but the same TV series are missing : should I do smthg with Emby for Kodi (re-synchronize ? how ?) Regards Salut, Est ce que tu as essayé, via la médiathèque d'afficher par répertoire, de sélectionner le répertoire concerné, de faire un click droit et actualiser les fichier ? C'est ce que je fais pour actualiser certains fichiers
