justmejustme 3 Posted March 25, 2019 Posted March 25, 2019 (edited) When I sync a show that's encoded in Dolby Digital+, I can't hear the audio when I play it back in offline mode on my Chromebook running the Android Emby app. I hear small parts, like it's playing just the L/R channels or maybe the rear channels, but no dialogue. I sync at 8 or 12 Mbps quality. I'm on a Pixelbook with the Android Emby app. Is there a way to play the file internally or transcode it to Stereo during Sync? Edited March 25, 2019 by justmejustme
justmejustme 3 Posted March 25, 2019 Author Posted March 25, 2019 Note: I installed MX player and set the Emby option to enable external video player. The audio played fully.
Luke 42244 Posted March 29, 2019 Posted March 29, 2019 How did you sync it? did you select to force download the original file?
justmejustme 3 Posted March 31, 2019 Author Posted March 31, 2019 No, I just choose Sync from the menu.
Luke 42244 Posted April 1, 2019 Posted April 1, 2019 Can you please try this version and let me know how it compares: https://www.dropbox.com/s/9am2hgfcj403j8d/MediaBrowser.Mobile-googlearmv7-release.apk?dl=0 Thanks.
justmejustme 3 Posted April 1, 2019 Author Posted April 1, 2019 It looks like I can't sideload Android apps on a Chromebook without first enabling "Developer Mode" - which wipes and resets my Pixelbook back to factory.... https://www.androidcentral.com/how-enable-developer-mode-chrome-os Nothing's ever easy, right? Can you please try this version and let me know how it compares: https://www.dropbox.com/s/9am2hgfcj403j8d/MediaBrowser.Mobile-googlearmv7-release.apk?dl=0 Thanks.
ginsengbomb 5 Posted April 15, 2019 Posted April 15, 2019 I'm having this problem as well, and am also on a Pixelbook. It's intermittent, too; only seems to affect some content. Same approach in terms of using sync and not downloading the original file (largely because some of my movie files would eat up way too much storage on my Pixelbook). FWIW I have no issue with wiping my Pixelbook to test something if there's a non-zero chance it addresses the issue, although won't be able to for a week or so. Luke what is the Dropbox link you shared above?
Luke 42244 Posted April 15, 2019 Posted April 15, 2019 Please try again with the next app update. Thanks.
justmejustme 3 Posted April 15, 2019 Author Posted April 15, 2019 Please try again with the next app update. Thanks. Will do - do I need to resync my media first or is this just a player change?
aptalca 71 Posted April 19, 2019 Posted April 19, 2019 On samsung chromebook plus v1, beta channel, updated to latest stable emby app yesterday and it seems to have fixed the sound channel issue. I now hear the center channel correctly. Thanks
justmejustme 3 Posted April 25, 2019 Author Posted April 25, 2019 Please try again with the next app update. Thanks. On my Pixelbook on the Emby Beta channel, yes, I can now hear center-channel audio on the episodes I mentioned earlier. However, I had to switch back to using the external player (VLC) because now the audio is out of sync with the video. I am using wired headphones. No audio sync issues in VLC with the same files. Switching back and forth between internal and external player is not easy, since I can't change the preferences while offline on the bus... so I have to startup my hotspot, re-start Emby, change my setting, turn my hotspot back off because if I don't a sync will use my entire dataplan.... then try it again.
