rodainas 191 Posted July 19, 2021 Posted July 19, 2021 (edited) 14 minutes ago, GrimReaper76 said: Yeah, looks like it's getting IMDB Id irrespectively of scraper used: 2021-07-19 18:38:10,595 INFO [tmmpool-unnamed-task-T6-G2479] o.t.c.t.tasks.TvShowEpisodeScrapeTask:106 - ========================== 2021-07-19 18:38:10,595 INFO [tmmpool-unnamed-task-T6-G2479] o.t.c.t.tasks.TvShowEpisodeScrapeTask:107 - Scrape metadata with scraper: tmdb 2021-07-19 18:38:10,596 INFO [tmmpool-unnamed-task-T6-G2479] o.t.c.t.tasks.TvShowEpisodeScrapeTask:108 - TvShowEpisodeSearchAndScrapeOptions[tvShowIds={tmdb=62104, tvrage=44814, imdb=tt3909224, tvdb=284131},artworkScrapers={aniDB,fanart.tv,ffmpeg,IMDb.com,themoviedb.org,thetvdb.com},certificationCountry=US - United States,ids={tmdb=2907410, imdb=tt14664448, seasonNr=4, episodeNr=19},language=English,metadataScraper=themoviedb.org,releaseDateCountry=US,searchQuery=,searchResult=<null>,searchYear=-1,subtitleScrapers=[],trailerScrapers=[],type=TV_EPISODE] 2021-07-19 18:38:10,596 INFO [tmmpool-unnamed-task-T6-G2479] o.t.c.t.tasks.TvShowEpisodeScrapeTask:109 - ========================== Interesting thank you. So having done this comparisons of scraping with third party TMM and emby scraper, looking at api behavior and response to the specific case of episodes, we can conclude that emby scraper is no the problem it is just taking what TMDB api is sending. So@Bazzu85 is a TMDB api limitation not emby’s , it just doesnt send the IMDB id. Recommendation if you want imdb related info, use TMM. Edited July 19, 2021 by rodainas
Bazzu85 22 Posted July 19, 2021 Posted July 19, 2021 1 hour ago, rodainas said: Interesting thank you. So having done this comparisons of scraping with third party TMM and emby scraper, looking at api behavior and response to the specific case of episodes, we can conclude that emby scraper is no the problem it is just taking what TMDB api is sending. So@Bazzu85 is a TMDB api limitation not emby’s , it just doesnt send the IMDB id. Recommendation if you want imdb related info, use TMM. sorry but I don't want garbage (nfo) in my hdd BTW I wrote on tmdb support forum to get infos about the info lacks..
Carlo 4561 Posted July 19, 2021 Posted July 19, 2021 1 hour ago, Bazzu85 said: sorry but I don't want garbage (nfo) in my hdd BTW I wrote on tmdb support forum to get infos about the info lacks.. Keep in mind if you don't use NFO files and have a problem with your database or every have to reload you lose all custom meta-data edits you have ever made as Emby would have not way to reload that info. NFO files are anything but garbage but a backup to your meta-data if you ever need it. 2
Bazzu85 22 Posted July 19, 2021 Posted July 19, 2021 (edited) 35 minutes ago, cayars said: Keep in mind if you don't use NFO files and have a problem with your database or every have to reload you lose all custom meta-data edits you have ever made as Emby would have not way to reload that info. NFO files are anything but garbage but a backup to your meta-data if you ever need it. I know I know.. btw I received a reply on tmdb forum and the api CAN get the external id's. but have to be requested. I remembered that time ago I had requested an api key so i could test base example: https://api.themoviedb.org/3/tv/62104-nanatsu-no-taizai/season/4/episode/19?api_key=xxxxxxxxxxxxxxxxxxxxxxxx here's the result: {"air_date":"2021-05-19","crew":[],"episode_number":19,"guest_stars":[],"name":"The Struggle","overview":"\"Tenjo Tenka Yuigadokuson Goku\" (Ruby: The Ultimate One), which still burns beyond noon, ── Escanor, who fights by converting all his vitality into magical power, approaches the Demon King. However, Meliodas stands in front of the deadly Escanor. It is because he realizes that he could lose his life. However, Escanor refuses and is willing to take his life for his companion. Meliodas decides to fight together in front of the dark beast that the Demon King calls further! On the other hand, in the spiritual world of Zeldris, the real Gelda joins and the battle with the Demon King continues. Finally, Zeldris pulls out his sword and confronts the Demon King!","id":2907410,"production_code":"","season_number":4,"still_path":"/dyIMgpXBLGKIawT0izKvfRPIcPc.jpg","vote_average":8.0,"vote_count":1} example requesting external id's you have to append the string: &append_to_response=external_ids https://api.themoviedb.org/3/tv/62104-nanatsu-no-taizai/season/4/episode/19?api_key=xxxxxxxxxxxxxxxxxxxxxxxxxxxxx&append_to_response=external_ids here's the result: {"air_date":"2021-05-19","crew":[],"episode_number":19,"guest_stars":[],"name":"The Struggle","overview":"\"Tenjo Tenka Yuigadokuson Goku\" (Ruby: The Ultimate One), which still burns beyond noon, ── Escanor, who fights by converting all his vitality into magical power, approaches the Demon King. However, Meliodas stands in front of the deadly Escanor. It is because he realizes that he could lose his life. However, Escanor refuses and is willing to take his life for his companion. Meliodas decides to fight together in front of the dark beast that the Demon King calls further! On the other hand, in the spiritual world of Zeldris, the real Gelda joins and the battle with the Demon King continues. Finally, Zeldris pulls out his sword and confronts the Demon King!","id":2907410,"production_code":"","season_number":4,"still_path":"/dyIMgpXBLGKIawT0izKvfRPIcPc.jpg","vote_average":8.0,"vote_count":1,"external_ids":{"imdb_id":"tt14664448","freebase_mid":null,"freebase_id":null,"tvdb_id":null,"tvrage_id":null}} so.....I think that in emby plugin is missinn the append to response section.. Edited July 19, 2021 by Bazzu85
Carlo 4561 Posted July 19, 2021 Posted July 19, 2021 @Luke Can you check that out and possibly add this if possible?
Happy2Play 9814 Posted July 19, 2021 Posted July 19, 2021 (edited) 2 hours ago, cayars said: @Luke Can you check that out and possibly add this if possible? Per the cache folder and log the externalid is already gotten. Quote 2021-07-19 15:55:09.015 Info HttpClient: GET https://api.themoviedb.org/3/tv/62104/season/4?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=images,keywords,external_ids,credits,videos&language=en&include_image_language=en,null { "air_date": "2021-05-19T00:00:00.0000000Z", "episode_number": 19, "name": "The Struggle", "overview": "\"Tenjo Tenka Yuigadokuson Goku\" (Ruby: The Ultimate One), which still burns beyond noon, ── Escanor, who fights by converting all his vitality into magical power, approaches the Demon King. However, Meliodas stands in front of the deadly Escanor. It is because he realizes that he could lose his life. However, Escanor refuses and is willing to take his life for his companion. Meliodas decides to fight together in front of the dark beast that the Demon King calls further! On the other hand, in the spiritual world of Zeldris, the real Gelda joins and the battle with the Demon King continues. Finally, Zeldris pulls out his sword and confronts the Demon King!", "id": 2907410, "production_code": "", "season_number": 4, "still_path": "/dyIMgpXBLGKIawT0izKvfRPIcPc.jpg", "vote_average": 8, "vote_count": 1, "images": { "stills": [{ "aspect_ratio": 1.778, "file_path": "/dyIMgpXBLGKIawT0izKvfRPIcPc.jpg", "height": 1080, "vote_average": 0, "vote_count": 0, "width": 1920 } ] }, "external_ids": { "imdb_id": "tt14664448", "tvdb_id": 0, "tvrage_id": 0 }, "credits": { "cast": [{ "character": "Meliodas (voice)", "credit_id": "54f0b834925141796e008619", "id": 149894, "name": "Yuki Kaji", "profile_path": "/8wKdPV11IwowfwoqGqMMNt9hmp6.jpg", "order": 1 }, { "character": "Diane (voice)", "credit_id": "54f0b862c3a3686d580083b6", "id": 936275, "name": "Aoi Yuki", "profile_path": "/cIFTJFbPhN55T9WW2P064Wh8qty.jpg", "order": 2 }, { "character": "Ban (voice)", "credit_id": "54f0b87e925141795f0090d0", "id": 1154452, "name": "Tatsuhisa Suzuki", "profile_path": "/foytL2OreKzQcTNftz2qMgClKKg.jpg", "order": 3 }, { "character": "King (voice)", "credit_id": "54f0b8b3c3a3686d580083c0", "id": 131563, "name": "Jun Fukuyama", "profile_path": "/aadtVXCUS1oPqWraYW3ErO1Ajcg.jpg", "order": 4 }, { "character": "Hawk (voice)", "credit_id": "54f0b8c4c3a3686b9a006442", "id": 151182, "name": "Misaki Kuno", "profile_path": "/6qslBrgao1mthGJK3M9keUYyMIw.jpg", "order": 5 } ], "crew": [], "guest_stars": [] }, "videos": { "results": [] } } @Luke But yes it is true episode level is not reading this already known metadata from TMDB. Yes it is true this info is missing from TVDB do to no one adding it, but v3 api metadata does not appear to contain it. Edited July 20, 2021 by Happy2Play
Luke 42287 Posted July 20, 2021 Posted July 20, 2021 Yes we can update Moviedb to start capturing the imdb id for episodes. Thanks.
Bazzu85 22 Posted July 20, 2021 Posted July 20, 2021 7 hours ago, Happy2Play said: Per the cache folder and log the externalid is already gotten. { "air_date": "2021-05-19T00:00:00.0000000Z", "episode_number": 19, "name": "The Struggle", "overview": "\"Tenjo Tenka Yuigadokuson Goku\" (Ruby: The Ultimate One), which still burns beyond noon, ── Escanor, who fights by converting all his vitality into magical power, approaches the Demon King. However, Meliodas stands in front of the deadly Escanor. It is because he realizes that he could lose his life. However, Escanor refuses and is willing to take his life for his companion. Meliodas decides to fight together in front of the dark beast that the Demon King calls further! On the other hand, in the spiritual world of Zeldris, the real Gelda joins and the battle with the Demon King continues. Finally, Zeldris pulls out his sword and confronts the Demon King!", "id": 2907410, "production_code": "", "season_number": 4, "still_path": "/dyIMgpXBLGKIawT0izKvfRPIcPc.jpg", "vote_average": 8, "vote_count": 1, "images": { "stills": [{ "aspect_ratio": 1.778, "file_path": "/dyIMgpXBLGKIawT0izKvfRPIcPc.jpg", "height": 1080, "vote_average": 0, "vote_count": 0, "width": 1920 } ] }, "external_ids": { "imdb_id": "tt14664448", "tvdb_id": 0, "tvrage_id": 0 }, "credits": { "cast": [{ "character": "Meliodas (voice)", "credit_id": "54f0b834925141796e008619", "id": 149894, "name": "Yuki Kaji", "profile_path": "/8wKdPV11IwowfwoqGqMMNt9hmp6.jpg", "order": 1 }, { "character": "Diane (voice)", "credit_id": "54f0b862c3a3686d580083b6", "id": 936275, "name": "Aoi Yuki", "profile_path": "/cIFTJFbPhN55T9WW2P064Wh8qty.jpg", "order": 2 }, { "character": "Ban (voice)", "credit_id": "54f0b87e925141795f0090d0", "id": 1154452, "name": "Tatsuhisa Suzuki", "profile_path": "/foytL2OreKzQcTNftz2qMgClKKg.jpg", "order": 3 }, { "character": "King (voice)", "credit_id": "54f0b8b3c3a3686d580083c0", "id": 131563, "name": "Jun Fukuyama", "profile_path": "/aadtVXCUS1oPqWraYW3ErO1Ajcg.jpg", "order": 4 }, { "character": "Hawk (voice)", "credit_id": "54f0b8c4c3a3686b9a006442", "id": 151182, "name": "Misaki Kuno", "profile_path": "/6qslBrgao1mthGJK3M9keUYyMIw.jpg", "order": 5 } ], "crew": [], "guest_stars": [] }, "videos": { "results": [] } } @Luke But yes it is true episode level is not reading this already known metadata from TMDB. Yes it is true this info is missing from TVDB do to no one adding it, but v3 api metadata does not appear to contain it. Question: where do you found that request url? I searched the logs for reproduce it by myself but I didn't found it..
Happy2Play 9814 Posted July 20, 2021 Posted July 20, 2021 30 minutes ago, Bazzu85 said: Question: where do you found that request url? I searched the logs for reproduce it by myself but I didn't found it.. The was the url in my server log when I added that test episode. Looks like @Lukepushed a plugin update that resolves the issue. But looks like you have to Refresh Metadata to populate the filed (at least in my testing). <uniqueid type="Tvdb">8397876</uniqueid> <uniqueid type="Imdb">tt14664448</uniqueid>
Bazzu85 22 Posted July 20, 2021 Posted July 20, 2021 1 hour ago, Happy2Play said: The was the url in my server log when I added that test episode. Looks like @Lukepushed a plugin update that resolves the issue. But looks like you have to Refresh Metadata to populate the filed (at least in my testing). <uniqueid type="Tvdb">8397876</uniqueid> <uniqueid type="Imdb">tt14664448</uniqueid> Just updated the plugin and refreshed the metadata for the show. This is the configuration: - Primary scraper: tvdb (no imdb id) - Secondary scraper: tmdb (yes imdb id) The infos was taken now correctly from tvdb. The missing one (imdb id in this case) from tmdb thx @Luke to update the plugin.. now I check if there are other missing data.. 1
Bazzu85 22 Posted July 21, 2021 Posted July 21, 2021 question: why don't track additionally the tmdb id? talking about the next tvdb paying subscription many user will migrate to tmdb..so I think is time to invest in this provider a little more.. 2
Bazzu85 22 Posted July 21, 2021 Posted July 21, 2021 (edited) 23 minutes ago, Luke said: We do track the tmdb id For movies and shows main page, yes.. But not for single episodes.. only imdb e tvdb is showed in metadata Edit: ok I'll see that the tmdb id is unique for all season episodes. Example: https://www.themoviedb.org/tv/62104/season/4/episode/1 My starting question was because in the episodes page the related tmdb link was missing. Why don't generate it at this point? Edited July 21, 2021 by Bazzu85
Luke 42287 Posted July 21, 2021 Posted July 21, 2021 Quote Why don't generate it at this point? I guess it's just never been looked at before, but it can always be added.
Bazzu85 22 Posted July 21, 2021 Posted July 21, 2021 (edited) 2 hours ago, Luke said: I guess it's just never been looked at before, but it can always be added. can be a great implementation.. users now see only this: even if the episode is scraped from tmdb.. for not-english users that want to add translations, now have to go to main show page, click on tmdb link and search the episode page again.. and what about episodes group? example: are there a way to use it in emby? thx Edited July 21, 2021 by Bazzu85
Luke 42287 Posted July 21, 2021 Posted July 21, 2021 Episode groups are possible for the future Thanks. 1
GrimReaper 4926 Posted July 21, 2021 Posted July 21, 2021 1 minute ago, cayars said: This is what I have for The Big Bang Theory He's referring to TMDB links on episode level, which atm are not scraped (or, at least, not displayed). 1 1
Carlo 4561 Posted July 21, 2021 Posted July 21, 2021 OK, should have read that closer! Thanks for the heads up. 1
GrimReaper 4926 Posted July 21, 2021 Posted July 21, 2021 2 hours ago, Bazzu85 said: and what about episodes group? example: are there a way to use it in emby? Lend your support here:
shona_emby_plex 0 Posted March 31, 2023 Posted March 31, 2023 how can refresh ALL metadata from ALL libraries at the same time? i have too many libraries to refresh each library one at a time.
GrimReaper 4926 Posted March 31, 2023 Posted March 31, 2023 (edited) 2 minutes ago, shona_emby_plex said: how can refresh ALL metadata from ALL libraries at the same time? i have too many libraries to refresh each library one at a time. Multi-select all libraries (hover top-left on the library thumb on Home Screen)>three-dot menu top-right of the screen>Refresh Metadata Edited March 31, 2023 by GrimReaper
shona_emby_plex 0 Posted March 31, 2023 Posted March 31, 2023 3 minutes ago, GrimReaper said: Multi-select all libraries (hover top-left on the library thumb on Home Screen)>three-dot menu top-right of the screen>Refresh Metadata i dont see it
