rapteev 20 Posted March 22, 2019 Posted March 22, 2019 Hi Angelblue I am on latest betas for emby server and emby for kodi. Not sure if is a server or plugin problem, but after latest updates cover art do not show on emby for kodi where it previously do. Thanks
Angelblue05 4132 Posted March 22, 2019 Posted March 22, 2019 Make sure the setting to enable enhanced artwork is enabled under the add-on settings > sync. Please install this build. Try to repair your library that contains cover art. Does it work then? plugin.video.emby-4.0.14b.zip
