Luke 42237 Posted April 6, 2020 Posted April 6, 2020 Well you said it crashed without any libraries so that's not a surprise.
BlueIronEye 0 Posted April 6, 2020 Posted April 6, 2020 (edited) No sorry, i edited my comment.. I was too fast. I thought that i have already deleted all my libaries. After i deleted the second libary it didnt crash. It showed no content. Sorry for the confusion Edited April 6, 2020 by BlueIronEye
Luke 42237 Posted April 6, 2020 Posted April 6, 2020 OK that's good news. That means it can connect, but then it doesn't like something about the content so it crashes. Let's try this. Please create one home videos library with a folder containing one single mp4 video. Like this mp4 for example: http://techslides.com/sample-webm-ogg-and-mp4-video-files-for-html5 Does it crash then?
Nadir Martin Perdomo 0 Posted April 6, 2020 Posted April 6, 2020 I have a question. I'm from Cuba and I'm using emby. I hava 80 client in my net, sometime my micro goes up and I do not know why it hapens. can I do something about this?
Luke 42237 Posted April 6, 2020 Posted April 6, 2020 I have a question. I'm from Cuba and I'm using emby. I hava 80 client in my net, sometime my micro goes up and I do not know why it hapens. can I do something about this? Hi, what do you mean by your micro goes up?
BlueIronEye 0 Posted April 6, 2020 Posted April 6, 2020 OK that's good news. That means it can connect, but then it doesn't like something about the content so it crashes. Let's try this. Please create one home videos library with a folder containing one single mp4 video. Like this mp4 for example: http://techslides.com/sample-webm-ogg-and-mp4-video-files-for-html5 Does it crash then? It does not crash! It worked. That means i have some content which the tv mioght not be able to read or to interpret`?
Luke 42237 Posted April 6, 2020 Posted April 6, 2020 Yes exactly. Or it may not like the way we're presenting some of your content to it, that's possible too.
BlueIronEye 0 Posted April 6, 2020 Posted April 6, 2020 Okay, so those are the playback formats the tv support accoridng to the manual. "Playback formats • Video Codec : AVI, MKV, HEVC, H.264/MPEG-4 AVC, MPEG1, MPEG2, MPEG4, WMV9/VC1, VP9, HEVC (H.265) • Audio Codec : MP3, WAV, AAC, WMA (v2 up to v9.2), WMA-PRO (v9 and v10) • Subtitles : - Format: SRT, SMI, SSA, SUB, ASS, TXT - Character encodings : UTF-8, Central Europe and Eastern Europe (Windows-1250), Cyrillic (Windows-1251), Greek (Windows-1253), Turkish (Windows-1254), Western Europe (Windows-1252) • Maximum Supported Data Rate : – MPEG-4 AVC (H.264) is supported up to High Profile @ L5.1. 30Mbps – H.265 (HEVC) is supported up to Main / Main 10 Profile up to Level 5.1 40Mbps – VC-1 is supported up to Advanced Profile @ L3" I just do a "quick" analyse of my files..I will give you feedback as soon as i have finished. I might need a script Thank you so far for your support !
BlueIronEye 0 Posted April 6, 2020 Posted April 6, 2020 (edited) okay, linux is great for all wondering: Recrusive Version find . -type f | sed -e 's/.*\.//' | sed -e 's/.*\///' | sort -u Source --->https://stackoverflow.com/questions/1842254/how-can-i-find-all-of-the-distinct-file-extensions-in-a-folder-hiera Those are the file extension: for the ibary "movies": avi db html idx img IMG iso jpg JPG log m2ts m3u mkv mp4 nfo png rar sfv srt ssa sub tmp txt for the libary "series": avi idx jpg mkv mp4 nfo r00 r01 r02 r03 r04 r05 r06 r07 r08 r09 r10 r11 r12 r14 r15 r16 r17 rar sfv SFV srt ssa sub url Do you think he might try to interprate all of the not supported extension? Edited April 6, 2020 by BlueIronEye
Luke 42237 Posted April 6, 2020 Posted April 6, 2020 It probably sees one unsupported file and that crashes the whole TV i guess.
BlueIronEye 0 Posted April 6, 2020 Posted April 6, 2020 Thats unfornutae. Is there a way to create a profile that shows only the supported extensions? (maybe if you add them manually to the profile)
BlueIronEye 0 Posted April 6, 2020 Posted April 6, 2020 wait. i just remember, that when i connect my HDD to my Fritzbox i can play my movies and series.
Luke 42237 Posted April 6, 2020 Posted April 6, 2020 Thats unfornutae. Is there a way to create a profile that shows only the supported extensions? (maybe if you add them manually to the profile) Yes, we just don't include one with the server. It's also possible that it could vary between Philips models/years.
BlueIronEye 0 Posted April 7, 2020 Posted April 7, 2020 wait. i just remember, that when i connect my HDD to my Fritzbox i can play my movies and series. But hoiw can this be explained?
Luke 42237 Posted April 7, 2020 Posted April 7, 2020 But hoiw can this be explained? Sorry I don't quite understand. What does that have to do with Philips?
BlueIronEye 0 Posted April 8, 2020 Posted April 8, 2020 (edited) Sorry I don't quite understand. What does that have to do with Philips? When I open the network menu of the Phillips TV, I have two DLNA servers to choose from: Emby and the fritz box. If I plug in the same hard disk, which was previously connected to the Emby server, to the Fritz box I can play the content from the hard disk without the tv crashing. If I now plug the hard disk to the emby server, the TV will crash. That means it has nothin to do with the file extensions, or am i wrong? Edited April 8, 2020 by BlueIronEye
Luke 42237 Posted April 9, 2020 Posted April 9, 2020 Does fritz box have any transcoding for file types that Philips doesn't support?
mfgea 0 Posted July 15, 2020 Posted July 15, 2020 I have about the same issue on a Philips TV. I have 2 LGs and none have this problem. When I activate DLNA in the TV, I can see the server, then I access the server and I see an infinite list of folders. I actually have only one Library, named "Joaqui"(my sons name) but in the list I see that name repeated infinitely, and that seems to crash the TV app. I have to power off and on the TV to see DLNA again.
Luke 42237 Posted July 20, 2020 Posted July 20, 2020 On 7/15/2020 at 5:08 PM, mfgea said: I have about the same issue on a Philips TV. I have 2 LGs and none have this problem. When I activate DLNA in the TV, I can see the server, then I access the server and I see an infinite list of folders. I actually have only one Library, named "Joaqui"(my sons name) but in the list I see that name repeated infinitely, and that seems to crash the TV app. I have to power off and on the TV to see DLNA again. How old is your Philips?
mfgea 0 Posted July 20, 2020 Posted July 20, 2020 1 hour ago, Luke said: How old is your Philips? I believe it's 2012/2013. The model is 32PFL3518G_77 (here's the link, sorry for the language, I'm from Argentina: https://www.philips.com.ar/c-p/32PFL3518G_77/3500-series-televisor-smart-led-delgado-con-digital-crystal-clear)
Luke 42237 Posted July 21, 2020 Posted July 21, 2020 Thanks. I think I will have to get my hands on a Philips so that I can test this personally.
mfgea 0 Posted July 21, 2020 Posted July 21, 2020 I don't have much experience on C# developing. I don't even use Windows (I'm on a Mac right now). But I do have some programming expertise. I might be able to help if you give me a little guidance. For starters: - Is there any docs on cross-compiling this for linux on a mac? (I'm running Emby on a Raspberry Pi 3, I write code in a Mac) - Which file exposes the DNLA folders?
Luke 42237 Posted July 24, 2020 Posted July 24, 2020 On 7/21/2020 at 11:55 AM, mfgea said: - Which file exposes the DNLA folders? What do you mean by this?
mfgea 0 Posted July 24, 2020 Posted July 24, 2020 I really don't know DLNA terminology, so I'll explain: When I connect to the server through DLNA, I first see a list of servers, after I select Emby I see a list of folders (which are the collections names). Where is that code? Which files? And after that (supposing that it works) I see folders like "Latest, "Genres", "Folders", etc.
Luke 42237 Posted August 4, 2020 Posted August 4, 2020 @mfgea It's in the Dlna plugin. I can give you access to that if you want to try and chase down the problem. I think this one is going to be really hard to find. There's probably something in our xml responses that needs to be tweaked specifically for Philips. It's probably going to require comparing xml responses to other software that does work with Philips, as well as looking at the sequence of communications from Philips to Emby server to see how far it gets before it gives us, and then trying to compare that something else that works. You could do that even before debugging the plugin, perhaps using something like wireshark to intercept responses and compare.
