PossumsDad 4 Posted March 21, 2019 Posted March 21, 2019 (edited) I have 2 Haupauge tuner cards in my system. I have a quad card and a 2250 dual tuner. I installed wintv 8.5 and it saw both cards just fine. I can watch all channels with no problem. When I setup Emby for live tv it sees both cards just fine. I save each one and go to setup the guide provider. I tried to use the emby guide but no go. I chose all of the settings but when it went to refresh the guide the green bar only went about 5% and vanished. I can go to livetv and nothing appears under programs. The guide is there but is empty. The grid is there but no channel icons and no programs. I can go to channels & all of the channels are there with their names. I can click on a channel & it will tune the channel & I can watch TV. Any help would be greatly appreciated. I have the DVR working in Plex but would love to use Emby instead. Edited March 21, 2019 by PossumsDad
Solution Luke 42237 Posted March 21, 2019 Solution Posted March 21, 2019 Hi there, have you checked the mapping tool to see if tuner channels are mapped to guide channels? 1
PossumsDad 4 Posted March 21, 2019 Author Posted March 21, 2019 Thank you for your help. None of the channels were mapped to guide data. Once I did that everything populated with data. Again Thanks 1
