clarkss12 304 Posted March 20, 2019 Posted March 20, 2019 (edited) I am trying to transition from the HDHomeRun DVR to the Emby DVR, but it is quite painful to find shows that I like to record. Using the guide under Android is too painful to use. IF I go to "Grit" channel and try to scroll horizontally for about 12 hours, it bounces me back to the top of the guide. I have then scroll down vertically through about 21 channels and do it again. I have to repeat this process for each block of 10 hours........... I can provide a video clip if needed. This has only been tested on my Nvidia Shield. Been happening forever, but too lazy to report it. Here is a video clip showing how I keep getting ** zapped ** back to the top of the guide. https://www.dropbox.com/s/afdpg6km5e3wtoz/Emby%20guide.mp4?dl=0 Edit: for what ever reason, the data that is showing in my Grit channel (38.2), is wrong while doing the fast scrolling. But by closing the guide and re-opening it again, the correct shows are displayed. Grit is a western channel. Edited March 20, 2019 by clarkss12
Luke 42246 Posted March 20, 2019 Posted March 20, 2019 We are working on improving the performance of the guide, thanks.
clarkss12 304 Posted March 20, 2019 Author Posted March 20, 2019 We are working on improving the performance of the guide, thanks. The guide is fantastic, but a few tweaks will make it perfect........... You guys are doing a fantastic job.............. Thanks.
maegibbons 1287 Posted March 21, 2019 Posted March 21, 2019 The bouncing back to the top was reported by myself and acknowledged as an issue several weeks ago. Unfortunately no fix has been forthcoming. Which makes guide navigation useless. Krs Marks
clarkss12 304 Posted March 25, 2019 Author Posted March 25, 2019 Problem solved with version 1.6.98g. thanks a lot guys!!!
BillOatman 597 Posted March 26, 2019 Posted March 26, 2019 Problem solved with version 1.6.98g. thanks a lot guys!!! Test version, right?
clarkss12 304 Posted March 26, 2019 Author Posted March 26, 2019 Test version, right? Heck, I don't know if it is beta or stable version. All I know, is that Emby updates the Android app quite often. I check the Google Play Store every day or so, and there is usually an update.
clarkss12 304 Posted March 26, 2019 Author Posted March 26, 2019 I am in heaven, right now. With the horizontal scroll function working correctly, I have been scheduling lots of old western movies on the Grit OTA channel.
BuddahKat 17 Posted April 1, 2019 Posted April 1, 2019 (edited) deleted post Edited April 1, 2019 by BuddahKat
